Hooking up surround for 1970's stereo
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    A former co-worker/friend just moved and part of that was this big 70's kenwood stereo system with big speakers. I'm still not 100% sure it will continue working because its been in a cooled environment, it's has not been plugged in in 15 years.
    I get the premise, preamp as the hub which connects with just two rca cables to the main amp but there is also a surround amp with two smaller speakers. I've seen preamps with dual stereo outputs, this one only has one.
    Also is this 'control' thing that takes stereo cable that seems to connect up all the devices (Turntable, Tuner, Tape).
    It will be hooked up at the new house with JUST the preamp and amp hooked to the TV (having to use a toslink coax to rca adapter)
    how can I hook the surround stereo up? There is no second output from the preamp (though i've seen models online that do)
    Preamp: KC-208
    Amp: KM-208
    Surround Processor: SS-78
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Hooking up surround for 1970's stereo
    If you care about music, you need two separate systems. Surround sound processors are not made for critical listening of music. I've had several different processors from several different companies and won't listen to music on any of them. I still use my system from 1976, The surround sound is not much better than listening to music on an AM radio.
    For your question, how about a "Y" . https://www.amazon.com/Mediabridge-U...cable+splitter .
    sigpicThe Sky Is Falling
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      They use will use it for TV mainly
      • R_J
        • Jun 2012
        • 9594
        connect the tv out to the ss-78, line in, connect pre out to the preamp, preamp to main amp. ss-78 has its own speaker outputs, I'm sure there are otherways to do this
        • R_J
          • Jun 2012
          • 9594
          I mis-read the post
          are you trying to hook up the Kenwood 70's preamp/amp AND a seperate surround stereo to the tv?
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            well the surround in this case would be expanded stereo. (unless I got a toslink to rca surround converter and just hooked the back speakers to the surround)
            well the surround is its own amp to the back speakers, so I would think, the pre to the amp and surround amp (other kenwood preamps have two stereo outputs [4 connectors] for outputs to both) but this only has one
            the surround I would imagine would have to be hooked to the preamp somehow
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
              Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
              by momaka
              Boston Acoustics fans, this thread might not be for you.
              A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
              01-30-2022, 11:57 PM
              Philips F9217L-50R speakers – build quality impressions and DIY surround repair
              by momaka
              More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
              02-15-2022, 12:43 AM
            • DrDos
              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
              by DrDos
              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
              08-08-2025, 03:16 AM
            • Tarot Superstars
              Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
              by Tarot Superstars
              Hi.
              I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
              Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
              Where in the circuit is the best place to solder the 3 stereo input wires?
              This is the model and schematics:
              https://www.manualslib.com/manual/91...7l.html#manual
              10-31-2023, 03:23 AM
