denon mc6000 dj mixer blowing fuse
    Re: denon mc6000 dj mixer blowing fuse
    C792 (0.1 uF) is BEFORE the fuses so it does not matter if it is connected or not at this point.
    "2.5 amp, 32v ac 63v dc" That is fine.
    We need to see the pictures.
    The switch is off, Q700 and Q701 are out and it is still blowing fuses it has to be error some where especially the fuse does not blow if INPUT filter cap C773 is not in place.
    So as requested, the power supply is original? Pictures of the power supply? 12V 3A?
    • CapLeaker
      Leaking Member
      • 8168
      That doesn't make any sense to me either.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        only way to make sense is if the cap is shorted . in wrong way . or power supply reversed or AC . or if fuse is 2.5ma
          So far there are no pictures for us to see.
          • CapLeaker
            Leaking Member
            • 8168
            LOL @ the 2.5ma fuse!
            • benwrong
              • Jan 2017
              • 17
              • scotland
              #26
              cheers pete, just saw this now, will do as you mentioned in the morning. I discovered that by simulating circuit for c773, I soldered the fuse f700 negative terminal straight onto positive for cap (avoiding board completely) and caps neg straight onto earth(board) and doesn't blow fuse, switch on or off... strange as c773 terminals on board are earth .5 ohms and positive terminal open loop. the power line to c773 is OL as well....
              strangely with fuse f700 bypassing board and going straight through (removed) cap c773 to earth, the power line that f700 should feed is reading 2.6 v, though power has been isolated and should only flow through fuse and capacitor.... I tested power line for resistance between + & - board terminals of f700 with it disconnect and it is OL ..... is it possible I'm living in an electro-magnetic vortex? thanks!
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                #27
                be best to do your best to take photographic evidence of all this . and post it up here ..
                  Boy that does not making any sense, so you have the positive output of the power supply connected to one end of the fuse, another end of the fuse is connected to the Positive leg of the cap, the negative leg of the cap is then connected to the negative out put of the power supply, so the result should show 12vDC between the two legs of the cap.
                  When are we going to see the PICTURES?
                  At this point I would say measurement/operator error.
                  • benwrong
                    • Jan 2017
                    • 17
                    • scotland
                    #29
                    yeah, i would say that to!! im a single parent and really busy so just grabbing anytime i can at the moment, I don't use a smart phone or have a camera handy at the mo' but will get a shot of one tomo and post pics ;-) Apologies for my scattiness, free tomo morn so will get on it..... Also double checked replacement fuses ;-) def 2.5A
                    • benwrong
                      • Jan 2017
                      • 17
                      • scotland
                      #30
                      ps forgot to mention, 12vdc with isolated cap and fuse...
                        Bottom line, if you hook up the power supply + to the cap + leg through fuse, and the - of the power supply to the - leg of the cap then you should have 12VDC between the two legs of the cap, period!
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          #32
                          check the output polarity of the power supply .
                          • benwrong
                            • Jan 2017
                            • 17
                            • scotland
                            #33
                            Hi, apologies for taking so long, my life is a bit of a whirlwind at the moment. I've attached some pics (terminal on positive c773 appears to be missing but still makes contact from backside, and was blowing fuses before I broke that). Just to double check polarity test 12.56dcv, and 26.2acv and with test leads reversed -12.54dcv and 0acv.
                            Also in regards to my test of fuse straight to capacitor to earth ( positive from pin 1 of f700) that is blowing the fuse now though it didn't seem to before. Thanks again, all suggestions appreciated!
                            • petehall347
                              • Jan 2015
                              • 4426
                              • United Kingdom
                              #34
                              cap legs look shorted out
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                is the capacitor fitted the correct polarity ie positive and negitive
                                • CapLeaker
                                  Leaking Member
                                  • 8168
                                  take that switch out and feed power as usual
                                  • Francesc V.
                                    Help me to identify this Thermal fuse from my sister's mixer
                                    by Francesc V.
                                    Hi everyone:
                                    This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
                                    My understanding is that it should be (NC) normally closed and open at 85C?????
                                    Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
                                    Wording in the back......... "limitor 16", "T160".
                                    Thanks in advance,
                                    Francesc....
                                    03-18-2025, 05:48 AM
                                  • Dannyx
                                    UC3842 Power Adapter Blowing Fuse
                                    by Dannyx
                                    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                    12-05-2023, 12:06 PM
                                  • Tips
                                    Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                    by Tips
                                    Looking for some assistance please.
                                    Trying to repair a PD27AOQ samsung power board.
                                    Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                    Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                    Testing it the fuse blows immediately power is turned on.
                                    diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                    any assistance, guidance would be appreciated.
                                    04-11-2024, 11:24 AM
                                  • RogerH58
                                    Samsung 46" TV LE46B530 blowing fuse
                                    by RogerH58
                                    I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                    I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                    I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                    06-10-2023, 10:27 AM
                                  • corrize
                                    A funny fuse story – Lumix LX100 II
                                    by corrize
                                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                    10-19-2023, 09:58 AM
