JBL SCS125 6-Piece Complete Home Theater Speaker System repair.
  • capwizard
    • Jun 2016
    • 1991
    JBL SCS125 6-Piece Complete Home Theater Speaker System, subwoofer SUB125a turns on then cuts off repeatedly.
    SUB125/125aAmplifier/SubwooferSERVICE MANUAL
    https://www.manualslib.com/manual/69...bl-Sub125.html
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: JBL SCS125 6-Piece Complete Home Theater Speaker System repair.
    Could be a mismatch in the I/O signals.....output level to high for the inputs.......the output transistors overloading and breaking down due to poor solder connections.....improper cooling for the output transistors.....weak capacitor...de-coupling and/or power supply.
    • capwizard
      • Jun 2016
      • 1991
      "weak capacitor...de-coupling and/or power supply."
      After I changed all the capacitors and check all the Transistors. It is still doing the same thing relay clicks on and off???
      I spend too much time on this Amp, before I give it up, I jump the relay with 0.1 ohm resistors, Now, it works OK!
      • madan1
        • Nov 2016
        • 682
        • Bulgaria
        sounds familiar - https://www.youtube.com/watch?v=MwvjAtSr5t8
        • capwizard
          • Jun 2016
          • 1991
          Yes, The problems must be in the polyester film capacitors because I neglected them all. You should've told me. First!..................
            How did you come to that conclusion? That cap in the Youtube is for the Capacitive power supply, your JBL uses power transformer.
            That relay is for timer circuit that will put unit in standby after about 15 minutes if it does not detect audio input signal.
            So if you are going to by pass the relay contact, you should use jumpers.
            • capwizard
              • Jun 2016
              • 1991
              Because that is the only item I did not checked.
              "That relay is for timer circuit that will put unit in standby after about 15 minutes if it does not detect audio input signal.
              So if you are going to by pass the relay contact, you should use jumpers."
              WOW ! You know more than I thought.
                So you are going to test ALL the polyester caps or trying to find the cause of the problem using the schematic?
                "WOW ! You know more than I thought." I really do not know much at all! Some of the member think I am just a kid and need to learn more before swimming with the grown up in this forum.
                • capwizard
                  • Jun 2016
                  • 1991
                  No, It not gonna pay for my time and customer have been taken away This JBL amp which quality is very poor like Chinese product, If it made in USA, I will!
                  PS: Bill is $60. (For reference only) The JBL SCS125 PCB used a lot of transistors which needs the principle of transistor work theory is not easy for me to troubleshooting maybe is easy for budm, I think! look easy reality is not!
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    im still learning myself and trying to understand schematics etc but in electronics etc its constantly changing technology so we will always be learning i guess, budm as hes said before has a good few years in the electronics scene, i have only been doing this as a hobby for the last 10 years or so im glad of forums like this and members who take time to explain things for us, i have learnt a lot and like a lot of the projects you do too as im doing this on a budget so use the cheaper tools/equiptment side of things.
                    • capwizard
                      • Jun 2016
                      • 1991
                      Guests take things to repair, they do not have a lot of patience generally things have to be repaired within a week so I do not have a lot of time to test or use the instrument to do failure analysis.
                      PS: I have a friend he only repairs things quickly if it spends more than two hours he would stop and turn to something else to fix, because we all need to make at least $100 A day to pay Rent and overhead.
                      PS: Can you imagine a month average $1,2000. How many things I need to repair? A hobby turn into make living.................
                      • capwizard
                        • Jun 2016
                        • 1991
                        vinceroger69 Thank you, There is such a person you can let us continue to keep on doing, But I am more commercial guy and I often think if I was budm how much more money I can make?
                        PS: Before, How much money that KID makes an hour it will surprised you! All We need is your sincere support of us. Thank you.
                        PS: Let's compare that to Dirty Talk: one minute $4.99, 4 hours a day, 365 days a year, for 6 years is
                        4.99*60*4*365*6 = 2,622,744 > two million dollars. ................
                        • CapLeaker
                          Leaking Member
                          • 8188
                          subtract taxes, fees, rent, replacement equipment and your 2.6 million look like a mere 260.000 over that period. That makes about 43 Grand a year. That's it.
                          • capwizard
                            • Jun 2016
                            • 1991
                            I have an idea, We can reduce the cost , By using A Robot does Dirty Talk to any kind of language. ( Celled Google Talk at Night). It's like saying that sex always has a market for it. (There are roughly 6,500 spoken languages in the world today.).........I did not say " As a prostitute". ...... ....... ..... ...
