Should I power this thing up?(I HAVE NO VARIAC)
  • TechGeek
    replied
    Re: Should I power this thing up?(I HAVE NO VARIAC)
    Originally posted by rhomanski
    Don't remove those wires at all. Just move the board as easy as you can. Look up wire wrap. You can unsolder the pin if you have too.
    why not remove the wires from the pins? too much risk?
  • rhomanski
    replied
    Originally posted by stj
    no, but they are getting smaller.
    personally i just drill the chassis to hold a smaller mounting clamp or put a colar around the cap to bump up the diameter.
    That's what most people do. I try to keep them looking the same as new for the most part. I've rebuilt five examples of one amplifier already and have three more to do. Panasonic announced they were going to discontinue the cap I use. Since it has two caps for each channel, I ordered up about $300 worth of them caps while I could. Going up to 80v from 63v kept the diameter the same but the new were still about 10mm shorter than the original. It works though and they are solid black like the original elna.
  • TechGeek
    replied
    can we just get to the point of what I have most recently ASKED!?
  • RJARRRPCGP
    replied
    Originally posted by dmill89
    It looks like when the RS-1056 was made ~1977, Fisher was owned by Sanyo, like you said it isn't "bad" but isn't anything particularly "special" either.
    I have a 1995 and I think it's a Sanyo, too...
  • rhomanski
    replied
  • TechGeek
    replied
    hello?
  • TechGeek
    replied
    is it bad when I can drive intercom speakers that use a transformer and not have a problem?
    Also, how can I remove the non-soldered wires from the boards w/o cutting them?
  • TechGeek
    replied
    ok
    replied
  • TechGeek
    replied
    so super high value caps are becoming a rarity? or no?
  • rhomanski
    replied
    My Sansui power amp uses two 80v 22,000uF mounted in a metal ring. To keep the same diameter 77mm and close to the same height 100mm, I had to go up to 100v. Only two companies made them and nobody had the Panasonic. I bought Epcos from Farnell in London for $100 each. Mouser wanted $200 each for them. The new were 105mm tall and just cleared the top by a mm or two. Main thing is they work, not bad for forty year old technology.
  • TechGeek
    replied
    why'd they have the epic ides to use WHOPPING 10000mfd CAPS!?
  • kaboom
    replied
    Originally posted by TechGeek
    So pretty much everything except the PSU needs recapped?
    If you want. But I wasn't counting the tuner/IF, only the power amp, pre/tone amp, and prot relay board.
    FWIW, the following boards do the following functions in that unit:
    Bottom of chassis:
    Prot relay board- centrally located, near back
    Phono EQ amp- near rotary switch, in back near input jacks
    Volume, loudness, tone controls- two boards in front, behind control panel
    Top of chassis:
    Driver board- centrally located
    AM RF, IF, MPX- right side
    Minor-rail power supply & regulators- left side in front of transformer
    The two main-rail caps (10,000u 50V) can stay if not leaking. Yours look OK in the pix- check where the terminals pass thru the seal. The rectifier is bolted to the chassis- excellent. One thing the old "Fisher" Fishers had were small rectifiers, which were/are a common thing to upsize.
    This unit resembles some mid-70's Sansuis in how it assembled. You've got a mix of point-to-point and also boards, but the boards come out fairly easily. Nothing like the late 60's Fishers, which were rather "fun" and involved... been there, done that.
    For example. all you have to do to remove the tone ctl/volume/preamp boards is remove the nuts on the pots and the screws from the switches. They should pull out from behind the panel. Easy. You might have to desolder a few leads near the front of the driver board- don't know, can't see it. Take lots of pix and make diagrams if unsure. But once you recap the driver board, you won't be doing it again. Use Nichicon PW/HE or Panasonic FC/FR here.
  • TechGeek
    replied
  • kaboom
    replied
    I checked for DC on the outputs of A, B, and C, and I saw as high as 6VDC at full volume, one connection only. The protection circuit cut the outputs for a 1/4 second, brought the outputs back up and didn't bother to cut them out again. So it needs recapping?
    Three things need recapping.
    The DC protect relay board (not dropping out, even with DC on the outputs)
    The amp, because there are small caps which can upset the center points of both long-tailed pairs. Each dual-transistor, near the input, is an LTP, each with input and feedback nodes.
    The "low level" preamp-tone ctl board, which is putting DC into the power amp. There's leakage from one or more caps, leading to DC at the top of the volume control, which explains why it varies when you turn that pot. I have a Sansui 881 which did the very same thing, before I recapped it. You'd turn the vol pot UP, spkr cones moved out. Turn the vol pot down, from mid-range, the cones sucked IN. Don't worry, I used junk speakers.
    To verify the DC is getting into the amp via the preamp, remove the two "Control Out->Power Amp In" jumpers in the back of the unit. That ~6V should vanish. You noticed one channel gave 6V, but the other did not; the one that's dumping DC corresponds to that preamp channel with the offset.
    The output channels come into the prot board via R01 and R02 (10k). The audio is shunted by two 100u nonpolar caps (C01, C02); any remaining DC is supposed charge these up and trigger the Darlington-connected transistor pair (Q01-Q02); anytime DC is present on the spkr outputs, this shunts drive to the relay drivers Q03-Q04 dropping the speakers.
    C03 is part of a time delay that causes the relay to close some time after AC power is switched on. If leaky, the relay never closes (also happened on my Sansui); if open, you lose the delay-close.
    Looking at the R-C ratios in the triple tone control, they're pretty typical for better sounding Japanese tone ctls. Quite similar to my Sansui (again), you'll like the way it sounds, even if you're a "basshead." You've also got the loudness control... Judging by the B+/- voltages and size of the transformer, it's an easy 60-65WPC.
    This is a nice "hands on" project that you'll enjoy for years to come, unlike any win10 garbage. After fixing this unit, you're practically guaranteed to become a speaker builder.
  • TechGeek
    replied
  • kaboom
    replied
    If DC comes into the amp driver boards from other questionable caps further back, like in the tone controls and preamp, the power amp will amplify this DC if the input coupling caps (on driver boards) are leaky.
    You do NOT want to amplify DC and send it to the speakers; yes the prot ckt should pick this up, but you see those non polar lytics on the board with the relay? IF those non polar caps in the protection ckt are also leaky, the prot ckt won't pick up til the DC at the spkr terminals is higher than it would otherwise be.
    If the non polar caps on the prot board are shorted, it won't drop the spkr relay even with full DC on the output(s)!
    Also, for driving the "high side" of the power amp, there's either a discrete constant-current source or a "boostrap" network with an electrolytic (100-470u, 35-63V typically) and two resistors. If the cap opens up, the high side of the amp is poorly AC driven- you get distortion. If the cap shorts and depending on the bias chain, the output transistors can be over- or asymmetrically biased.
    If it were mine, I'd change the caps indicated in the power amp. I've shown one channel; you've got twice as many to change as the attached image shows. Also replace all the lytics on the prot relay board. Clean the bias pots (VR01 and compliment on the other channel)- if dirty or open, full bias is applied to the output transistors. This unit was from before the pots were wired such that an open was "failsafed" against. Bias current is obtained from a discrete CCS; no bootstrap ckt or cap in this one.
  • TechGeek
    replied
    Originally posted by kaboom
    SNIP
    Probably had power relatively recently, the caps are mostly good. But recap the driver boards at least.
    SNIP
    How come?
  • kaboom
    replied
    Originally posted by jiroy
    Rectifiers are primarily diodes , like one rectifier is composed from 4 diodes typically , so you measure rectifiers like a 4 diodes measuring ..
    Rectifiers are power diodes. To differentiate them from signal, switching, and varactor diodes.
    I powered it up, full line voltage... annnnnd it worked.
    Can't attach photos, Winblows 7 won't let me.
    What do you mean windows won't let you?? You're using IE? Can't think of a better way for windows to "interfere."
  • TechGeek
    replied
    I powered it up, full line voltage... annnnnd it worked. Can't attach photos, Winblows 7 won't let me.
