Pioneer A-449 amplifier repair, no sound (fixed)
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This good classic stereo amplifier with 2SA1302 / 2SC3281 pair had no sound at all. Power ±42V OK. Speaker relays don't activate. It's some kind of protection. I check power transistors output and I find -42V at Left channel. Right channel normal (0V). So it's a DC protection going on.
    No transistors shorted, neither finals or preamps.
    I check for cracked solders (long term thermal stress). I find some suspicious ones, but believe me that I know when a solder is really broken, and in this case none seemed completely broken. Also, no changes when knocking the board.
    Then I start to measure things randomly at L channel, diode test mode, specially diodes and low value resistors. I reach R247 (100Ω 1/4W) that reads higher. I double check and it's about 650Ω, but it's not burnt or bad looking at all. Same for surrounding components. I replace it without great expectations but surprisingly it's fixed!
    Very, very random failure.
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Pioneer A-449 amplifier repair, no sound (fixed)
    Late '70 Sansui had that problem with fusistors. I bought an amp off ebay said to have both channels out. It has a fusister in each channel of the pre-amp and both read infinity. The others on the power boards read about 600 to 1000 ohms instead of the 81 they were supposed to be.
    sigpicThe Sky Is Falling
      Good fix.
      Service manual:
        master hoarder
        • May 2008
        • 12175
        Originally posted by Chungalin
        I reach R247 (100Ω 1/4W) that reads higher. I double check and it’s about 650Ω, but it’s not burnt or bad looking at all. Same for surrounding components. I replace it without great expectations but surprisingly it’s fixed!
        I've had that happen on an 17" CRT monitor. In that case, the resistor was a 560 KOhm 1/4 or 1/2 Watt. Wasn't overloaded or burned out. Just went open-circuit all by itself. I didn't have that specific value, but I did have 2x 300 KOhm resistors. The 560 KOhm resistor was part of a circuit that seemed to be flexible with values, so I soldered those 300 KOhm ones in series for total of 600 KOhms. Pressed the power button and hey, it works!
        So yeah, good save! Old, simple, stereo amps are always worthwhile fixing.
        • UserXP
          Mackie CR4 amplifier no sound
          by UserXP
          Hi, people.
          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
          10-17-2020, 05:06 PM
        • acedogblast
          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
          by acedogblast
          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
          03-01-2023, 08:24 PM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
