Sony Diode St02d-140
  • tech2014
    • Aug 2014
    • 807
    It has the marking T2D98. It is open circuit. Does anyone know where I can find this part or is there a replacement I can use.
    thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sony Diode St02d-140
    Ebay, or search google. You sure its O/C normally these when they fail will go S/C but it can happen ?
    • tech2014
      • Aug 2014
      • 807
      I found the data sheet for it. I don't think its open circuit going by the symbol/pinout from the data sheet. Measuring across it measures from anode to anode.
      • Electronic Handyman
        • Apr 2016
        • 58
        Best way to check that part is de-solder one end from the board or totally remove it.Mouser.com probably has it cheaper then what i found on ebay.
        • R_J
          • 9548
          It's a clamping diode, it's going to check open, it conducts when the voltage accross it exceeds the breakdown voltage of:
          Min. 130
          typ. 145
          Max. 160
          when its in circuit working it probably has around 130 -145 volts accros it.
          Clamping at a maximum of 200 volts . at that point it probably fully conducts acting like a short
          https://cdn.badcaps-static.com/pdfs/...cf2b63802a.pdf
          • redwire
            • 3910
            Shindengen ST02D-140 pdf
            It looks like a 145V 200W unidirectional TVS with a 600V series reverse diode. I haven't seen that combination offered by other companies. Used for snubber clamps.
            I would put a P4KE150A or 1.5KE150A and a UF4005 in series to make it out of two parts.
            It should check out, start conducting at 145V but no 0.7V (open) in the reverse direction. These probably fail short.
              Can you tell us what kind of unit you are working on and the location where this Snubber/Clamping diode being used?
              • tech2014
                • Aug 2014
                • 807
                It for a Sony STR-KS360 a/v receiver. The fault is when you try and power it on, the unit shuts down. I get all my voltages for a few seconds then they drop back. Checked all voltage regulators and all are good. I get no voltage coming out of IC921(see screenshot). I decided to remove the diodes to test and D921 looked open, but now I know its fine.
                  So what DCV do you on all of the pins of that SMPS IC921? All 0 Volt?
                  What GND are you using when test the Voltage on that IC?
                  • tech2014
                    • Aug 2014
                    • 807
                    Chassis ground
                      Originally posted by tech2014
                      Chassis ground
                      You are working in the primary side so you cannot use chassis GND as the GND ref. for your meter, you can use chassis GND as the GND ref for cold side of the circuit.
                      Look at the circuit and see how the GND point of that circuit is connected to, does the GND point of that circuit show 0 Ohm to the chassis?
                      You should know that by now since you have been fixing many TVs.
                      • tech2014
                        • Aug 2014
                        • 807
                        You are right. Not used to working on audio equipment with SMPS, usually they have a linear power supply. I will take a look at the schematic.
                        I really appreciate the help budm.
                        • Longbow
                          • Jun 2011
                          • 623
                          No, this is a temperature stabilized voltage reference. Obviously it won't test like a regular diode and the only real way to test it is to add a resistor in series with it and put it on a d.c power supply. I'll bet the voltage will come out to be around 5.6 volts, which is the zener voltage with the best dynamic resistance figure. The schematic should show you what the actual voltage would be - and, you can reproduce the exact thing with a zener of correct value and a 1n4148 tied together thermally. My guess is that the part is not faulty anyway.
                          Is it plugged in?
                            It is snubber/clamping diode. 1N4148 and 5.6V Zener is not going to handle high Voltage spike and current from the primary winding fed by 300V power source.
                            • R_J
                              • 9548
                              The voltage for ic921 is supplied from the main bridge through jumper wires jw981/982 through r929 2.2 ohm, if its open I suspect the ic921 is bad, also check R927 .82 ohmif its ok The first voltage I would check is the +31 on CN904, that feeds the output ic's if its not there, disconect the plug and see if it comes up. I can't say for sure but my moneys on one of those output ic's being shorted, I did see that problemon earlier models
                              • Chungalin
                                • Jul 2014
                                • 422
                                • Spain
                                Shindengen ST02D and ST03D family of Power Clampers cause a lot of confusion because they're sometimes drawn as normal diodes on schematics and they can't be tested with DMM under diode mode. They exhibit open in both ways.
                                On the other hand, to date I've been unable to externally differentiate its voltage rating. ST02D and ST03D can be 82, 140, 170 or 200V, but all are marked as T2D and T3D, respectively. Datasheet doesn't help. Some people say that the other two smaller digits following the main marking have something to do, but I don't agree.
                                My theory is that they can be distinguished by marking color. I have some of them that marking lettering is dark red, and others is yellow. This has to mean something. Or maybe not. I tried to contact Shindengen with this question but I obtained no response.
                                ST02D and ST03D can be found in Sony DVD power supplies, usually as a companion of Panasonic MIP2E3DMY, MIP3E3SMY, MIP3E4MY switching regulators. I've seen them too in Vorwerk Thermomix TM31.
                                • Chungalin
                                  • Jul 2014
                                  • 422
                                  • Spain
                                  Another Shindengen trouble: how to distinguish between D3S4M and D3S6M Schottky diodes? Both have marking D3S. The other two digits are datecode, nothing to do with max voltage. I have two marked in blue ink, and another two in white ink. I think that’s the key, but still I’m unable to find any official doc that confirms this color coding.
                                  More: I have a rectifier diode marked as 3LU in violet ink. This can be a S3L20U or a S3L40U.
                                  I can understand this kind of ambiguity in SMD components, but not in larger components where there’s enough surface to write full component name.
                                  • Chungalin
                                    • Jul 2014
                                    • 422
                                    • Spain
                                    I attach datasheet for Shindengen S3V60. This is the first clear reference to marking color that I’ve found. Blue: S3V (S3V60), red: S3V (S3V20).
                                    Others have to follow similar convention, but I’m just unable to find where it’s documented.
                                    • Wisdom
                                      • Jul 2016
                                      • 12
                                      • Brazil
                                      Guys, I know my question should be an off-toppic, but, since I can not post an new thread, I will ask here about the diode T2D98.
                                      (Google bring me here after search for this diode)
                                      I have an dead powersupply from an HP 8000 Elite SFF with this diode dead, reading this thread if I get right the idea, I should replace it with St02d-140 is it?
                                      Note: I am willing order on mouser.
                                      • Chungalin
                                        • Jul 2014
                                        • 422
                                        • Spain
                                        What means that "this diode is dead"? If it’s not shorted, it’s probably not dead. Forget about the ending "98" (in smaller lettering), it’s a date code, not anything related to part number. Which color is the marking? You should replace it with another ST02D of the same color, because I still don’t have any info on how to identify voltage rating by marking color.
                                        • Tnmg
                                          Sony XBR-65X850E power supply board diode replacement
                                          by Tnmg
                                          I have a Sony XBR-65X850E that when plugged in buzzes for a few seconds about 5-7 times but the screen never comes on. It looks like one of the four diodes on the main power supply board are bad. I'd like to replace all four at the same time. The diodes that are bad are the D750, D751, D752 and D753. The S750 looks discolored and fails the diode test on the board. It hasn't been removed from the board yet for testing.
                                          Are all four of these the same diode? I saw a video that called the discolored one a Schottky 5150 diode. How can I make sure to get the right diodes for these?...
                                          07-01-2022, 04:54 PM
                                        • pcardoso73
                                          iMac power supply short-circuit diode to ground
                                          by pcardoso73
                                          I have an iMac with the power supply reference: ADP-200DFB.
                                          This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
                                          With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
                                          As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
                                          06-09-2020, 08:47 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
