Sony CMT-M373NT (HCD-M373) repair, stuck in standby
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    No, this time there're no fireworks at the end of the post.
    I'm running out of ideas with this one. It's a compact CD, MD, Tuner and Tape. When plugged to mains, main transformer relay clicks, all voltages appear, display backlight is lit (nothing shown), and after 5-6 seconds relay clicks again as it goes into Standby, constant red led, "--:--" on display (not blinking) and then it doesn't react to anything. Owner says it happened from a day to another, no previous problems.
    All voltages at CN101 are present while the relay is active (A+10V, M+8V, M+10V, M+7V, MD+5V, D+5V). There's also ±27V for amp IC803 (STK403-030). I've tried disconnecting CD FFC (CN103) and MD FFC (CN102). Same result, just that it stays for a bit longer until it goes into standby. Tried making a bridge between Power tactswitch contacts, nothing. When pressing power button, KEY1 line goes from 3,4V to 0V, seems normal behaviour.
    Not very reasonable to me, but could be an amp protection. Tested pin 100 of system control IC101 (PROTECT_IN) and reads 3,4V all the time, normal voltage according to schematics!
    What else?
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Re: Sony CMT-M373NT (HCD-M373) repair, stuck in standby
    I tried to remove R200 in order to induce a protection, just to see if that makes a difference, but no, all the same. It’s very weird.
    I’m about to dismiss this one.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      CPU clock failing?
      Is there anything that enables/drops the clock during turn-on vs standby?
      Can you upload the schematic or service manual?
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • Chungalin
        • Jul 2014
        • 423
        • Spain
        Originally posted by kaboom
        CPU clock failing?
        I’ve checked both crystals from IC101 (System Control) and perhaps there’s something here, thanks for pointing this. While I can clearly see X100 wave (32.768kHz), I cannot see anything from X101 (16MHz), just 1.5V and 1.3V at each side. According to SM, I should see a 2.8V wide pulse train. The "problem" is that it’s not a normal crystal (like X100) but a ceramic resonator with 3 leads.
        If I remove it, the set won’t even start, so it’s doing something, although I can’t see it.
        The most similar thing I have at hand now is a 4MHz ceramic resonator from a remote control. I’ve replaced 16MHz resonator with one of these and the set starts, but it lasts more than one minute to complete the starting cycle (about 7 seconds with the original 16MHz resonator) and after that it stays in standby like before, doesn’t react to from buttons.
        Although I can’t read X101, I’m not sure now if this is the right direction. Perhaps my Hameg CRT scope is too old to show several MHz signals...
        I’ve attached SM, downloaded from ElectroTanya.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Found an error in the schematic.
          One side of the 10.8V winding from the main transformer was unconnected. I have added this line in blue. Image attached.
          Have you checked & verified all supply voltages, as indicated on the schematics? Almost sounds like a missing rail.
          Many years ago, had a VCR that did something similar. Would go into "play," fully threaded, but tape never moved, no capstan motor or servo. FF or REW would work each time you tried them, but would STOP after 15 seconds.
          An open/corroded jumper killed one of the +5V supplies.
          Check all voltages on power, regulator, amp and main boards.
          EOL it...
          • Chungalin
            • Jul 2014
            • 423
            • Spain
            I've already double checked all voltages at CN101 (10V, 8V, 10V, 7V, 5V, 5V, 7,5V unreg), CN106 (3V, -26V), CN103 (5V, 7V, 10V, 10V), CN805 (-26V, 26V, 18V). 5V for CD are switched off by Q110. Checked +4V regulators (IC355, IC356). I think there're no more.
            The set is quite well conservated, no moisture or oxidation. I've repaired other sets with problems like you say, but in this case I see everything very shiny. It's not very repair-friendly, as it has 3 boards interconnected directly without intermediate cables of FFC, leaving little room to insert probes.
            It's time to give up, I have other repairs to do. Thanks for your help.
            • brithepi2k
              Sony KD-65XE8596 no standby light
              by brithepi2k
              I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
              cheers...
              09-06-2025, 02:22 PM
            • Ukdigger
              Sony KDL-40EX403 Stuck on Standby Fixed
              by Ukdigger
              This TV was stuck on standby, all the voltages tested ok. I Googled the problem
              and found that the ambient sensor could be causing the problem. I disconnected the two leads going to the ambient sensor (on the infra red remote sensor board) and the TV worked with no problems.
              05-23-2022, 02:34 AM
            • sigmeyer
              Sony KDL40R470A Stuck on standby , red light
              by sigmeyer
              So this is the second tv this week that comes in with the same problem. The power supply looks good , There is a solid 3.3v stand by voltage. The tv doesnt react to button presses or from the remote. The Processor gets slightly warm and thats about it.
              My question to other veterans on this forum is , what is more likely to be bad , the processor , or the memory chip. in this case there is a toshiba tsop48 fk4924 , tc58dvm92astaj0 . At the moment i do not have my hands on the programer but i will be buying it in the following weeks. i Can see that on 90% of tv boards there is a jack for...
              06-13-2023, 07:21 AM
            • lepak06
              TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
              by lepak06
              Hello
              I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
              The TV is faulty with stuck in Standby RED LED. Can't power the TV.
              Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
              All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
              But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
              01-12-2023, 01:43 AM
            • toty79
              Hisense LTDN50K220WSEU stuck in standby
              by toty79
              Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
              As per Hisense tv title LTDN50K220WSEU stuck in standby
              PSU rsag.820.5687 HLL 4855WF
              Main rsag 7.820.5842
              I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
              05-01-2022, 04:39 PM
