Re: SVI3206D Hybrid IC ( BC POWER MODULE BY SANYO)
sorry i learn in same time on that , im not sure to know what you mean by Getting the Base drive signal ( if you mean Check for Pin who have Power Supply and pin that receive Audio signal i will be ok for check it out . for the darlington , ive just read about ''Darlington Configuration'' ( fet 1 out thru fet2 in then fet 2 out is cumulative of both ) it look pretty like this configuration but again , Sa m'embete un peu pour l'instant , ''le temps de me démêler avec tout sa ''
btw, put one under a good magnifier to make sure there is only one transistor and not a darlington.Leave a comment:
maybe you can work out the NPN from the PNP by the polarity of the power rail.Leave a comment:
if you mean geting the base-drive signals, you could use spring-loaded pins on a bit of stripboard over the module.
you can solder though, you just need a good iron - it's metalised-ceramic substrate.
it acts like a heatsink.Leave a comment:
i have a made a noob moove ive unsoldered all 4 before identify it . but if im right , i only need to identify one of these to know the rest i love this project is like reverse engeenering
is the worst Case scenario
i think the big deal with theses IC's is to solder a wire on it because its not copper based but alloy pcb . i will check if it is possible to solder a wire directly on a SMD resistor or simply The AMP PCB without toutching at the SVI directly , probably i will only need to Tap the 4 Collectors connections that is not identified on my picture im happy if at this point the idea of concept is possibleLeave a comment:
sounds good, i would try it too with the cost of those hybrids.
dont forget to meter he base-drive transistors incase they are aso damaged.Leave a comment:
hi members !
today i work on an old technics amplifier with blowed SVI3206 IC ,, everyo0ne know theses IC become pretty rare , here this amp is sold for about 75$ the price of the SVI IC ,, here is the standard trouble of thechnics engineering , ( failed cooling , PNP power transistor unsoldered themselves and shorted out ,
so my plan is not to replace this HYbrid board , BUt REPLACING ONLY POWER FETS ON IT by subtilise it with standard PNP/NPN power transistor mounted directly on heatsink ,, a lot of time to lost here but if all this become to work , it will be an usefull way to recover Blowed SVI/STK Powers modules .. i will post somes pictures of my devlopment soon , if anywone hane any info to point me in a good direction it will be really appreciated , KEEP In mind i do dat in priority for RESEARCH AND DEVLOPPEMENT , no need to say y will lost some time on that ! but its my plan !
thanksTags: None
Assuming...7 Photos -
This specification for the HP EliteBook x360 1030 G2 + USB-C Notebook Power Bank Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + USB-C Notebook Power Bank boardview and 1030 G2 + USB-C Notebook Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 06:21 AM
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
by sam_sam_samI have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
Dose anymore known if there is such a module and where would I find some
While searching this topic on google I found this
https://www.badcaps.net/forum/troubl...anything/page3
I have read through this I have some switching... - Loading...
