Car Audio Alpine MSP M1000 Amp
  • Deazy
    • Jun 2015
    • 5
    I have been running an Alpine Msp M1000 amp in my car for some time now. Just recently it gave up on me, It was turning on and receiving power but would not output power. I opened it up and found a broken transistor, the only problem is in removing it i broke the plastic and now have no idea of the rating of it. If someone with the same amp could help me out and let me know what the rating is i would greatly appreciate it. I also already called Alpine and they basically told me they had no idea of the internals and would have to pay 100+ to have it fixed.
    • 31305
    Re: Car Audio Alpine MSP M1000 Amp
    so how about a hint, got a foto or any markings on the board near it?
    • Deazy
      • Jun 2015
      • 5
      Sorry I was in the process of uploading it, the transistor in question is exactly the same kind but had a different rating.
      • Deazy
        • Jun 2015
        • 5
        bump
          How about the pictures of the whole board? There should be another set of transistors with the same set up, but cannot tell until we can see the pictures to see what the function of that circuit is for.
            • 31305
            i cant see any pictures.
            • Deazy
              • Jun 2015
              • 5
              here are pictures of the full board and a repost of the transistor location
                OK , those three Transistors seem to be setup for linear Voltage regulator circuits, exact regulated Voltage are, I do not know.
                But since they are for regulator circuit, then we just need to find out if it is NPN or PNP transistor, that will require some circuit board tracing.
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • kotel studios
                  Lantec PULSE 386 subwoofer - no audio output
                  by kotel studios
                  Hi
                  I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
                  After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
                  The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
                  11-29-2025, 04:15 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • i_am_patch
                  Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                  by i_am_patch
                  Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                  04-30-2024, 08:20 PM
                • silver60618
                  Macbook M3 A2991 Speaker Audio Amplifier IC
                  by silver60618
                  Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                  I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                  09-26-2025, 12:25 PM
