Tube amps
  • pentium
    • Mar 2006
    • 2778
    Tube amps
    Some of you may remember these things (and some might still own one) but is it just me or are these modern tube amps a little harshly priced?
    This is a nice one but look at the price. $600!
    That's a bit high is it not? I would expect say $150-$250 but $600 is rather extreme for what it has to offer. Are the tubes in it even standard or are they proprietary (as in older tubes won't work)?
    Find Nedry!
    Check the Vending machines!!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Tube amps
    They are generally rather pisstakingly priced even the kits also. Personally i am into a bit more power than they generally offer. Bet you can find some nice solid state on the second hand market.
    • hardwareguy
      • Jun 2006
      • 405
      Re: Tube amps
      Welcome to the goofy land of the Audiophile. These nincompoops will pay well over $1000/meter of cable in some cases.
      The tube amps have somewhat of an excuse: they DO cost more to make, the tubes cost more than good bipolars or FETs, the output transformers aren't cheap and neither are the high voltage caps they need.
      The high priced tubes and tube amps aren't even the tip of the iceberg. You've got magical amps (sometimes with buttloads of "warmth", eh I mean distortion!), magical sources, magical speakers that actually sound BAD, magical power cords, magical speaker wire, magical interconnect, magical outlets, magical bases to put other magical equipment on, magical knobs, magical markers, magical rocks that supposedly do stuff to the sound and even magical caps, resistors, inductors and other stuff that doesn't audibly do jack shit but makes the nincompoop feel good and THINK that it has in some way enhanced his listening experience.
      Oh and here's my definition of the word magic: Pseudoscience with a sprinkling or marketing and a dump truck load of bullshit!
      • hardwareguy
        • Jun 2006
        • 405
        Re: Tube amps
        I have THREE.....
        Lafayette receiver, EL84 output stage, class A single ended, 4W/ch....LOL
        HH Scott 299 C, Push/Pull 7591 outpus, 30W/ch
        Heathkit something or other, push/pull 6BM8 I think, 8W/ch
        • hardwareguy
          • Jun 2006
          • 405
          Re: Tube amps
          I now remember what I had.... Heathkit AA32! Tube was an ECL86/6GW8
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Re: Tube amps
            hardwareguy- Caps, resistors, and inductors all will change how a speaker sounds when you upgrade them in a crossover. Be it better or worse, that depends on your ears.
            I'm currently running a pair of Polk audio SDA2's, with upgraded crossovers. Great sound, and my whole system cost less than that one tube amp above.
            Ludicrous gibs!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Tube amps
              They cost much because they don't make just one and then there is no (or very slow) market for most of what they make.
              I special ordered one once and all the order/routing paperwork came to me for some reason.
              Went like this:
              I ordered.
              Went to the dealers warehouse. No stock, they ordered from the manufacturer.
              Went to their warehouse. No stock, they ordered from the factory.
              Factory didn't have any.
              Made 1000 units and sent to their warehouse.
              10 units got sent to the dealer's warehouse.
              Dealer gave me one. (With all the paperwork ???)
              That tube was only ever used in radios in 1960 Ford cars and trucks.
              This all happened in the early 80's.
              Mann-Made Global Warming.
              - Dr Seuss
              • shadow99
                • May 2007
                • 24
                Re: Tube amps
                That's alot over the edge hardwareguy. Just because your ears cant tell the difference between high quality audio and the basic stuff doesnt mean an "audiophile" cant. I'll agree with you on some of that but take speakers as an example. A set of Energy 22 reference models sound alot better than a pair of Cerwin Vega party blasters. BUT that depends what you value most. If it's sheer volume then the CW's win but for clarity, pureness, and accuracy of sound the 22's win hands down. It's why you see 22's and similar reference speakers in tv and recording studios. Is eating a 16 oz. crap steak better than a fantastic tasting 4 oz. filet? Is more better? If you have no tastebuds, why spend money on good taste?
                As for tubes, I dont own a tube amp but I do know they are smoother. Tubes react different than a transistor so when a tube amp clips, it is much softer than a transistor amp thus it sounds better. There's alot more to it than that. But again, for sheer power and price, tubes arent a good choice for you if your ears cant hear the difference.
                A true audiophile is not a nincompoop at all, they just are aware enough to tell the difference between the everyday stuff and something special. That can be quite subtle and not detectable to someone who isnt tuned that way.
                A true nincompoop is a person who call's another person's knowledge, experience and taste bullshit without knowing much about what he is talking about
                • Stephen
                  A2991 Logic Board issue, 20volts 0 amps help!
                  by Stephen
                  Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                  09-10-2025, 03:16 PM
                • Stephen
                  A2991 logic board issue, 20volts 0 amps help!
                  by Stephen
                  09-10-2025, 03:15 PM
                • Fisher8865
                  MacBook Pro A1990 stuck at 5v .592 amps
                  by Fisher8865
                  Hi guys
                  I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                  05-30-2024, 07:36 PM
                • DCJack
                  B&K 707 tube tester. I need help.
                  by DCJack
                  Hi everyone!
                  I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                  Initially I noticed that I was not getting the red on-light to turn on, but it...
                  03-05-2024, 05:05 PM
                • Stephen
                  MacBook Air 13" A2179 2020. 5Volts .250 amps issue
                  by Stephen
                  Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
                  PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
                  ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
                  02-18-2025, 05:54 PM
