MacBook Air 13" A2179 2020. 5Volts .250 amps issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
    PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
    ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully replaced from a working donor board so now those turn on. The customer stated she was using some weird data cable and her computer died from using it. I cannot for certain say this is dead but I had confidence this was going to turn on from those shorts, now I believe its another issue. Any thoughts?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • ugamazing
    • Jun 2013
    • 171
    • usa
    T2 rails stable and not cycling? Make sure you check for a solid 30 seconds. Same with PMU. Is the .25a stable and consistent as well? 12.3v screams T2 or PMU, so you're on the right track. Check diode of the T2 rails closely, one might be slightly higher or lower. Also of course confirm CPU isn't shorted to ground--common on the 01958.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Yup,failed T2 chip :/
      sigpic
      • Darren Hibbert
        MacBook A2179 Audio board+Power button boardview & schematic needed
        by Darren Hibbert
        Hi.
        Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
        There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
        Many thanks. ...
        08-21-2025, 02:38 PM
      • thuygsm
        Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
        by thuygsm
        I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
        I noticed there is liquid at U3200 and U3100 and have replaced them.
        PP1V5_UPC_X_LDO_CORE : 1.575V
        PP3V3_UPC_X_LDO : 3.280V
        PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
        I have isolated R6979,
        Pin 1: 3.280V stable
        Pin 2: 0.447 (diode)
        PPBUS_G3H: 12.28V (with R6979 isolated)
        PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
        What should I do next?
        10-29-2025, 06:02 AM
      • Fisher8865
        MacBook Pro A1990 stuck at 5v .592 amps
        by Fisher8865
        Hi guys
        I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
        05-30-2024, 07:36 PM
      • conghuyms
        MacBook Air A2179 stuck logo , pls help me !
        by conghuyms
        Hey everyone,
        I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
        When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
        I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
        11-05-2025, 08:30 AM
      • cheebster
        Macbook Air 2020 A2179 Internet Recovery and Battery Issues
        by cheebster
        Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
        The 10 of them show the exact same behavior;
        They auto power on, to internet recovery spinning globe, fans to 100%.
        Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
        Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
        All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
        10-09-2024, 06:23 AM
