Is This a Battery ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Is This a Battery ?
    I did not write it down but I did google it and could not find a pdf for it.
    From memory... 2109-430-390
      • 30983
      that's not a part number of a chip, that's somebody's order-code for spares.
      • mmartell
        • Oct 2013
        • 3189
        Except it's right on the chip.
        But the number is wrong as at home I was getting hits to purchase it from China but no datasheet to be found and I'm not at home atm...
        I should have taken a pic because there was another number underneath which may be more pertinent. Will check it out in the morning.
        • mmartell
          • Oct 2013
          • 3189
          Ok I can close this one out. I had the battery backup working with a used up 9v (about 7.6v) but realized this solution seemed messy and inelegant against simply replacing the part.
          Thanks for identifying the part and the help with the circuit.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
