Denon avr 2802 with no sound on speaker
Re: Denon avr 2802 with no sound on speaker
Man you are a life saver. rock on dude
I really really need to send you some voice note. Can you PM me your whatsapp number? I will alway be grateful and help anyway i can when needed.
I returned the AVC-3800 today and against that I bought the JAMO Center Speaker. Now all I need is the DENON AVR-2802 to work. Because its the only AMP that matches with my speakers aswell as the required Output wattage.
Its a must to have both the IC's because if if if if..... DSP IC is working and the Programming IC is failed then we'll be back where we started. even if its in working order after the DSP change, I'll atleast have a backup of Programing IC when needed.
I do have some cousin living in US. I'll transfer the amount to you and you can program the IC and send it to them, they'll bring it over here.
Cause I want this thing to work I loved at and we all did, my father is a audiophile listener and he loved the sound that denon AVR-2802 produced.
Appreciate all that you did till now
Thanks in advance.
I looked at the DSP datasheet and the -CLZ version simply means it's a lead-free package.
So it should work just fine. (See attached screen grab).
You can download the datasheet anywhere off the web but I've also attached it.
I didn't think paypal would be a problem but hey, order from whereever you want.Comment
My denon is workingthe Denon AVR-2802 is 100% fully working condition and special thank to AZChris who actually is responsible for the flash IC. i replaced both IC the DSP IC is easily accessible in the market but for ATMEL ic you need programmed IC. Or like AZCHRIS did. Just follow his procedure.
Thank you again azChrisLast edited by addahasan; 08-18-2018, 05:32 PM.Comment
Hi azchris i have the same broblem with my denon avr 2802 (no sound) can you sent me
an already programmed ic chip (ATMEL AT49LV00270TC)?Comment
I am a small French hacker, sorry for the translation ...
The idea for me was to repair my DENON AVR-2802 without buying a memory or programmer : maladroit:
In addition, orders in China impossible with Coronavirus.
Thanks to azchris for all the valuable information :clin d'œil:
I used an ARDUINO MEGA 2560 to program a W29C020 memory that I had in stock of the same size 256k x 8
A SPI mode SD card reader
I used the 256Kb azchris flash file, renamed to "HEX.bin" copied to an old 128MB SD card formatted in FAT32 or FAT16.
Thank you, thank you to azchris
For information, I tried with a 2GB SD card but does not work ...
I made sure to read the SD card by block of 0x80 Octect because the Arduno does not manage the 256K Octect at once.
The wiring details in the file "FLASH_DENON.ino"
For W29C020, a PDF file for erasing and programming procedures.
The procedures can be different on other Flash memory.
The W29C020 memory is in 5 volts but works very well in 3.3 volts on the amplifier.
It is not super clean with the wires but it does not bother me as long as it works well.
I'm happy, my Denon amplifier is coming back to life
I kept the old memory just in case.
Hope this can help someone.Attached FilesComment
Here you have the firmware..
https://www.dropbox.com/sh/ckne01lp9...H5ctIhaSa?dl=0
Flash H27U....
https://www.dropbox.com/sh/1sx6i6ohc...L4ibFqiAa?dl=0
Flash EN29LV160
https://www.dropbox.com/s/op2qqctkgi...LV160.bin?dl=0
File not presentComment
I'm not sure what you are looking for, but in post #99 I have included a zip file with the binary for the DSP FLASH IC.
https://www.badcaps.net/forum/showpo...0&postcount=99Comment
Folks,
I also have one of these intermittent 2802s I would like to fix. Here are the symptoms:
I can get the receiver to work by presetting it to the settings I need then power cycling the receiver by turning off/on the power strip the plug is in. It will come up working in the mode I set it before power cycle. Volume control works and I get good power to the speakers. I can play with the tuner settings and it work fine. If I initially mains power it on set for VCR1 or DVD, for example, it will take inputs from these.
Once powered up, if I change source I lose audio. If I try to set the source back to the one that was just working, the audio will not come back. I have two choices to get audio back. First if I power cycle the receiver it will come back with audio and the volume control works. Second, if I turn the receiver off/on from the receiver power switch, it will come back with audio but usually the volume control will change the indication but the actual audio will not change level. In this second case I can then power cycle the receiver and it will come back with audio and the volume control works.
It appears the receiver, on mains plug power up, will return to the last settings before power off but many functions do not work if changed after power on.
I would also like to add that all my experimenting works with Stereo mode. If I pick a surround mode (dolby or other) I get no audio no matter what.
What I have done so far:
I resoldered the flash pins, the analog switch ICs and connector pins while the DSP board was out. No change.
I replaced the DSP and no change, then I replaced the flash with the duplicate hex code loaded (checksum correct for the 4M part) and no change either. Exactly the same symptoms.
Unless someone has a good idea what these symptoms point to, I will need to start tracing the signals again and maybe checking pins on the DSP.
ThanksComment
Here you go
https://www.dropbox.com/s/fcembdd9eq...02%20dump?dl=0
Flash it on a new chip, solder it on the board, and ready!Comment
Here you go
Can anybody share the flash file for IC817 (AT49LV002-70TC)?
Best regardsComment
Hello sparx 59,
Please can you help?(sorry to disturb)
Have you any opportunity to send me one chip (AT49LV00270TC)
for AVR-2802 .
I have exactly the same faulty on my Denon that you mention on https://www.badcaps.net/forum/showth...t=45694&page=3
if possible, Im from Portugal and is easy to send to you the paiment for it.
Thanks for your support
SPLComment
To be complete: The problem is the IC817. This is a flash chip wich holds the data for the DSP uprocessor. This chip will sometimes fail. The data is still in it, but the processor has problems reading it due to wear. In other words: the chip is getting old. I was lucky enough to be able to read the data from a faulty chip with a programmer. Flashing this data in a freash chip resulted in a fully working rom. I had replaced two boards with these chips, and this fixed the problem. I know Denon does not support the avr 2802 anymore, so I want to share the fix to help ppl with this problem. Please feel free to ask any question! I am happy to answer them.Comment
by FuzzyOwlHi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
I've followed the trouble shooting guide, audio check...1 Photo-
by benspawn02Anthem MRX500 - no sound
Dear Electronics Experts:
I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...-
by cazi1001Hello,
I have a Samsung Galaxy A22 5G with a strange error image.
If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
If I listen music via Youtube, even the upper or lower speaker don't work.
If I switch louder or quieter, the sign on the screen show me a headphone.
If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
Does anyone have any ideas, what the problem could be?02-10-2024, 09:16 AM -
by GumboilGood day all
My first post on the forum, tried to find a introduction page, but couldnt. So thank you for having me here.
After spending most of the past 2 days Googling and watching Youtube videos, I came across the forum, in the hopes that I could get some assistance with the above mentioned amplifier. As I do most days, I switched the unit on yesterday morning, got the relay clicks as per normal, but no sound from any of the speakers. Tried "Audio Direct' and the same issues there. In a panic state, I did a factory reset, without any luck. Then disconnected all...-
06-08-2025, 02:43 PM -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
