Denon avr 2802 with no sound on speaker
  • tufi979
    • Mar 2012
    • 27
    • Serbia
    Hello to you all. I have been browsing for a couple of days now about my problem but i was unable to find solution so i will try here
    I bought used Denon avr 2802 faulty. Receiver turns on like it should relay cliks it responds on all commands ( volume change on lcd, switching between sources , mode selector... ) but there is no sound , i downloaded service manual , i checked all voltages on supply rails and everything looks normal and as it should. I traced input signal from dvd input and signal is lost on TC9459N , there is input signal present on pin 5 and 24 , but no signal is getting out from it od pin 3 and 26. so i assume that this chip is faulty??? But this is present only on DIRECT and STEREO mode on every other mode there is no signal present on input pin of TC9459N. Yesterday when i powered it up i have noticed that there is slight sound on speaker but very very faint and this only happens when you powered it up as soon as you change input source and return it to DVD again there is no signal. I have checked all big amp chips, there is no short on any of them . I ran out of ideas where to check so any help will be appreciated.
    Thanks in advance.
  • paulstef
    • Dec 2013
    • 724
    Re: Denon avr 2802 with no sound on speaker
    Please post the service manual here or a link to it.
    I have a very similar one and I hate it, they are way to complex. Sometimes my daughter would press some buttons and it would take me an hour to find the problem.
    Maybe yours isn't even broken.
    • paulstef
      • Dec 2013
      • 724
      I had a customer recently with the same problem, no sound. His daughter had played around with it too.
      Did you check the buttons "ANALOG" "EXT IN" and "INPUT MODE" ? The problem was with one of these.
      Owners manual page 36:http://a248.e.akamai.net/pix.crutchf...033avr2802.pdf
      • tufi979
        • Mar 2012
        • 27
        • Serbia
        Well im sure it is broken it cant be that simple not with me well i tried every button every mode etc. i reset it couple of times but no luck.
        i checked pin 14 on IC 108 and on IC 805 there is same buzz or hum i guess the clock that drives this is ok . BUT when i bypass signal from input pin 24 to output pin 26 ( same as from pin 5 to pin 3 ) on IC805 i get input sound on speakers but without volume control ( i cant turn it up or down ) just constant tone as i can guess same level as input sound on pin 24. So do you have suggestion what to check ? This bypass confuses me , as far as i can see there is nothing that can amplify signal . so problem is somewhere in this section right ? Or i can't figure out how volume control fits here ) i guess that clock which comes on pin 14 IC805 i trace it to pin 37 of IC303 Master ucom. Is it posible that this is faulty ?
        here is link for service manual i cant upload it for some reason
        you have to wait for couple of minutes and on the bottom will appear link GET MANUAL
        • paulstef
          • Dec 2013
          • 724
          This link says: "Error! This file not found! It may deleted or renamed"
          We need to work with the same schematic you have.
          • tufi979
            • Mar 2012
            • 27
            • Serbia
            can you send me your email here or private message to send you via drop send , service manual iz 38 Mb that is why i cant upload it
            • tufi979
              • Mar 2012
              • 27
              • Serbia
              try google search denon avr 2802 service manual and scroll down to find this electrotanya site
              • paulstef
                • Dec 2013
                • 724
                Weird, the last two links also give errors. Don't know if it's just me. I'll try to find it somewhere else. You could also print the pages that contain the schematic as a new pdf file and post that here. It will certainly be smaller than 38Mb
                • tufi979
                  • Mar 2012
                  • 27
                  • Serbia
                  ok one sec
                  • paulstef
                    • Dec 2013
                    • 724
                    I only find it on eservice and it's chopped into 3Mb files...
                    • tufi979
                      • Mar 2012
                      • 27
                      • Serbia
                      here is short version of service manual.
                      • paulstef
                        • Dec 2013
                        • 724
                        Do you have an oscilloscope?
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          Ahhh Denon, Run away!! sorry, had to.
                          Follow the white rabbit.
                          • tufi979
                            • Mar 2012
                            • 27
                            • Serbia
                            No
                            • tufi979
                              • Mar 2012
                              • 27
                              • Serbia
                              Ha ha , did you had some "good " experience too
                              • tufi979
                                • Mar 2012
                                • 27
                                • Serbia
                                i dont have osciloscope
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  many...
                                  • tufi979
                                    • Mar 2012
                                    • 27
                                    • Serbia
                                    Did you manage to download service manual that i uploaded ? is it ok ?
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      Yes , I downloaded it.
                                      I would test it like this:
                                      1. Check the voltages and ripple of the voltages that supply all the chips the signal goes through
                                      2. Apply a sine wave signal from a function generator (could be from a PC or cellphone) on any of the inputs and then follow the signal through the circuit and see where it gets lost.
                                      I'm afraid without a scope that will be next to impossible.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Usually, no sound is a badly soldered DTS chip, at least at other brands. Oven trick, may work for a while.
                                        • FuzzyOwl
                                          Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
                                          by FuzzyOwl
                                          Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
                                          Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
                                          Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
                                          I've followed the trouble shooting guide, audio check...
                                          12-05-2024, 11:54 AM
                                        • benspawn02
                                          Anthem MRX500 - no sound. R2A15218FP issue??
                                          by benspawn02
                                          Dear Electronics Experts:
                                          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                                          08-12-2023, 04:46 AM
                                        • cazi1001
                                          Samsung Galaxy A22 - strange problem with sound / speaker
                                          by cazi1001
                                          I have a Samsung Galaxy A22 5G with a strange error image.
                                          If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
                                          If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
                                          If I listen music via Youtube, even the upper or lower speaker don't work.
                                          If I switch louder or quieter, the sign on the screen show me a headphone.
                                          If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
                                          Does anyone have any ideas, what the problem could be?​
                                          02-10-2024, 09:16 AM
                                        • Gumboil
                                          Denon AVR-X2000 no sound
                                          by Gumboil
                                          Good day all
                                          My first post on the forum, tried to find a introduction page, but couldnt. So thank you for having me here.
                                          After spending most of the past 2 days Googling and watching Youtube videos, I came across the forum, in the hopes that I could get some assistance with the above mentioned amplifier. As I do most days, I switched the unit on yesterday morning, got the relay clicks as per normal, but no sound from any of the speakers. Tried "Audio Direct' and the same issues there. In a panic state, I did a factory reset, without any luck. Then disconnected all...
                                          06-08-2025, 02:43 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
