Pioneer VSX-1016 Noise During Test Tones
  • mmartell
    • Oct 2013
    • 3189
    Sound seems clean during normal playback but when I run the test tones there is a noise in all channels that aren't being tested. The noise can be increased with the volume control and goes away when I exit the test tone.
    Any ideas ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Pioneer VSX-1016 Noise During Test Tones
    Is there a way to isolate this ? I can't be sure whether the noise is actually there during radio playback because the signal is shitty to start with but with any other input I hear nothing - but maybe the signal is internally muted with no input..
    Need some help with this.
    • Longbow
      • Jun 2011
      • 623
      This has the earmarks of a DSP failure. It might be possible to isolate the problem further with block diagrams and schematics (are those available?). But, why would all channels get noisy at the same time? Your test proves that the amps are not at fault. A check at the D/A converter should show the noise. These are generally tough problems to pin down. Run any software updates first, however.
      Is it plugged in?
      • mmartell
        • Oct 2013
        • 3189
        Yes I have the SM for this though it's a bit above my head on how to interpret it. I have a dmm and a scope if you can suggest how/where to take some measurements.
        I will heat the dsp ic to see if the symptoms change.
        I tried attatching the service manual but it failed. It's available at ElektroTanya.
        • Longbow
          • Jun 2011
          • 623
          Sorry, I don't have access to Elecro-T. If possible, posting just the block diagram would be a good start. Heating and cooling the DSP might give you a clue if the noise changes in some way (use headphones at a low volume levels). Describe the noise - constant, white noise, similar to radio static, etc. Operation normal with various inputs? Be sure to check the various modes (theater, room, etc.) and note any problems. Also many of these units offer a test mode with random noise for setting up room acoustics. Time for the owner's manual!
          Is it plugged in?
          • mmartell
            • Oct 2013
            • 3189
            Will post block diagram shortly...
            • mmartell
              • Oct 2013
              • 3189
              Block diagram
              • tibimakai
                • Jan 2012
                • 3680
                You can download two SMs per day, without logging in.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5097
                  • New Zealand
                  I agree with Longbow - are you certain it's not supposed to do that?
                  It wouldn't be the first time a 'feature' looked like fault.
                  -David VanHorn
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Check/clean/tighten/resolder grounds for DSP.
                    Use external signal source, either sig gen or CD with test tones.
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                    • mmartell
                      • Oct 2013
                      • 3189
                      No. Right now I only have two speakers hooked up to it and no subwoofer. If I run the test tones for three channels (couldn't see where to tell it there is no sub) then when the test tone is in the right channel I can hear noise in the left and vice versa. When the sub test tone is played I can CLEARLY hear this noise through the left and right speakers.
                      The noise sounds like part noise, part interference.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Though this is sound advice if this was the nature of the problem would it not be evident on other signals using the DSP ?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5097
                          • New Zealand
                          What kind of signal is the test tone? I wonder if there is some marginal fault which means it can handle normal music etc but not the test tone.
                          What if you generate a copy of the test tone with your PC in software or signal generator and feed that into the inputs, see if you get the same problem?
                          Probably not too relevant, but all I can think of - I recently fixed a Roland KR3500 Digital Piano that had a digital noise problem in the left channel. Turned out the DAC for that channel had an open circuit resistor in the voltage divider which adjusted a voltage to change the DAC's MSB offset.
                          (And yes, it had the known leaking SMD electrolytics problem as well!)
                          *Maybe* you have a similar problem with a voltage reference being off somewhere?
                          Note that in the case of my KR3500, it only took a tiny 13mV drop in that voltage to confuse the DAC!
                          -David VanHorn
                          • Longbow
                            • Jun 2011
                            • 623
                            Thanks for the block diagram. I think the DSP section of the receiver is missing - that's what you want to focus on - section G. The problem you describe seems abnormal, since a noise test mode would surely be noted, but we do need to check the O.M. first. Also, perform the f.w. update. You DO need the remote on these things to get anywhere.
                            Is it plugged in?
                            • mmartell
                              • Oct 2013
                              • 3189
                              I had a few minutes and so endeavoured to remove the dsp board for close inspection but after removing a few screws and ribbons could not readily see how to extract it. After reassembly the noise is gone, or at least greatly reduced.
                              Will put the lid back on and see how it holds up under operational stress.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5097
                                • New Zealand
                                Bad solder joints?
                                -David VanHorn
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Could still be that though I couldn't make the noise go away using the butt end of a screwdriver on and around that board. I know, hardly scientific lol. Ran it several hours yesterday and still holding up.
                                  • GraphicMan
                                    Pioneer A-205 faint noise/hiss issue
                                    by GraphicMan
                                    as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
                                    what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
                                    out of curiosity what does that mean?
                                    thanks
                                    05-19-2024, 11:45 AM
                                  • tony359
                                    by tony359
                                    11-28-2023, 05:18 AM
                                  • chth96
                                    How Can I test PWM DM0365R?
                                    by chth96
                                    Hello
                                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                    06-18-2025, 04:14 PM
                                  • MegaZAC
                                    Onkyo TX-SR805 noise in one channel
                                    by MegaZAC
                                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                    There's some logic behind it. As soon as I select an input I get only left...
                                    04-23-2025, 10:09 PM
                                  • khelane
                                    test active pfc power with lamp test
                                    by khelane
                                    Hello
                                    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                    Is there a way...
                                    06-03-2025, 01:00 AM
