ONkyo TX-NR626 Check SP Wire
  • artois7
    • Mar 2011
    • 159
    #41
    Re: ONkyo TX-NR626 Check SP Wire
    From memory, I think if you hold down display and the power button, release display and press the tone button, you should get an internal temperature reading. My 609 reads around 23 degrees on first power on and will idle somewhere mid 30s-40s ish (and it's got no ventilation around it..!)
      "Quiescent current = the 6mV reading you took from the test points..! (before anyone jumps in and says the current can't be taken in mV and that it doesn't make sense; this is word for word from the service manual!)" Divide the voltage reading by the resistance will give you the Idling current, they are just taking the reading of the Voltage drop across the Emitter resistor of the output transistor, this way you do not have to open the current path to put the DC Amp meter in series with the current path, that is how it been done with many solid state amplifiers and that how I did it it since the 70's when I was working for warranty station for SANSUI, PIONEER, PHILIPS, FISHER, ZENITH, RCA, MAGNAVOX, etc. we had lots of service manuals at that time.
      • artois7
        • Mar 2011
        • 159
        #43
        Always wondered that. Thank you!
        • tibimakai
          • Jan 2012
          • 3680
          Thanks for clarifying.
          I remember about that button combination on the 609. That was my first receiver.
          I will try it out on these also(I have a 515, 616 and 626). Most likely the 515 will have to go.
          I'm thinking about replacing the factory fan, with a much bigger size fan, to cover bigger area and maybe I find one, that the RPM can be adjusted. This way, I could run it at lower RPMs(quiter) and cool everything much better.
            BTW, I check the other Onkyo service manual for the TX-NR series, it shows the set point of 6mV on 0.22 Ohm which represents 27mA of current on the output transistor.
              Oh BTW, you do not adjust for minimum current, the Transistor has to be bias on to reduce crossover distortion, in this case it is Class A-B amplifiers. You can do class A but you will need lots of heat sink and good power supply, Class A amplifiers make good room heater.
              http://www.aikenamps.com/index.php/w...ver-distortion
              http://www.electronics-tutorials.ws/...ier/amp_7.html
              • commpradeep
                • Aug 2015
                This could be something very old to you but very new for me like beginner,
                Can you please share the NT626 service manual if you have ... Please
                • tibimakai
                  • Jan 2012
                  • 3680
                  http://elektrotanya.com/?q=showresult
                  You have to wait like half a minute, to show up below the picture, Get manual.
                  • grunca
                    • Sep 2015
                    • 5
                    Did you end up fixing it ? can you share what you learned ?
                    thanks.:compy
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Who you are asking?
                      • grunca
                        • Sep 2015
                        • 5
                        asking anybody that can answer.
                        • grunca
                          • Sep 2015
                          • 5
                          I downloaded all manuals linked here and ready to open the receiver for repairs, any advice ? thanks.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Measure all final transistors for short, mounted on the heatsink. Cut the shorted legs and the receiver should turn on. After that, you have to measure all the components on the base board, around the shorted transistors. Most likely, the Emitter ceramic resistor is open as well.
                            Than remove the pre-amp board and check all the components that belong to the bad channel. Replace what is bad.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              After all is done, you will have to check and adjust as necessary the idle current.
                              • grunca
                                • Sep 2015
                                • 5
                                thank you !
                                my front right front stage power PNP and NPN pair are shorted and the collector resistors are open.
                                can you save me some time and let me know which preamp parts you found to be bad ? Of course I can check further than that, but it would be a good start.
                                thanks !
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  You will have to check everything on the vertical board, course only the bad channel one.
                                  • grunca
                                    • Sep 2015
                                    • 5
                                    Would greatly appreciate sharing your experience, what parts did you replace ?
                                    I found the final power transistors bad and, on the vertical board I had two medium power transistors that were bad and one low power (2sa1037), also a 82ohm resistor on the vertical board and the 2x .22 ohm on the high power finals.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      It's been a while since I have repaired a 626 and I don't remember. Lately I have repaired a bunch of 636s, 545.
                                      Usually I have found bad SMD transistor at the bottom as well. Sometimes a capacitor was blown near the medium power tranzistors.
                                      If you don't want to blow it again, you will have to check all the components.
                                      It will take like 15 minutes, it's not that hard.
                                      • jworthin
                                        • Feb 2017
                                        • 33
                                        I received a 626 that was in VPROT. The R channel was blown. I noticed that channel had been serviced before. I replaced the bad channel power transistors and some small parts in it's driver. I set the idle current and it seemed to work fine for about 4 hours when it blew the same channel again. (VPROT) It is ‘repaired' now again but I am reluctant to run it for very long. The idle currents on all channels are normal and stay within service manual limits. But here's the odd part, when it is turned on it starts getting hot with no input, no volume, and no speaker load. It gets up to about 135F in 20 minutes and then the unit switches the +/-B from 60V down to 29V which cools the unit off.
                                        1) Why did it blow the the same channel again?
                                        2) Why is the unit getting so hot with normal idling currents?
                                        Any help would be greatly appreciated.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          It could be, that you have missed a component.
                                          Check every(!) component, at channel R on the vertical board, and base board.
                                          Compare measurements, with another adjacent channel.
                                          Idle current is stable, after reaching the amount off time, specified in the service manual?
                                          I don't know how hot is yours, but these receivers run quite hot.
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • rddube
                                            Help with blowing transistor NAD T752 receiver
                                            by rddube
                                            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                            09-01-2022, 05:19 AM
                                          • ai.need.help
                                            Onkyo TX-8050 AV-Receiver no sound
                                            by ai.need.help
                                            I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                            It doesn't play music. There is no real output from:
                                            pre-out
                                            amp-out A and B
                                            phones out
                                            The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                            I tested with analog-input, usb and radio.
                                            I know that there is a common problem with...
                                            12-20-2022, 05:54 PM
                                          • ShotwellCoho
                                            Onkyo TX-NR363 Check SP Wire
                                            by ShotwellCoho
                                            Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
                                            I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
                                            However I have so far been unsuccessful - here is what i have done
                                            Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
                                            Put everything...
                                            08-27-2021, 07:39 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
