ONkyo TX-NR626 Check SP Wire
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: ONkyo TX-NR626 Check SP Wire
    Originally posted by jworthin
    The heat sink gets so hot (135F) you cannot leave your finger on it.
    More like 160F! If you can't leave a finger on it.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • rddube
      Help with blowing transistor NAD T752 receiver
      by rddube
      I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
      Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
      I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
      09-01-2022, 05:19 AM
    • ai.need.help
      Onkyo TX-8050 AV-Receiver no sound
      by ai.need.help
      I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
      It doesn't play music. There is no real output from:
      pre-out
      amp-out A and B
      phones out
      The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
      I tested with analog-input, usb and radio.
      I know that there is a common problem with...
      12-20-2022, 05:54 PM
    • ShotwellCoho
      Onkyo TX-NR363 Check SP Wire
      by ShotwellCoho
      Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
      I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
      However I have so far been unsuccessful - here is what i have done
      Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
      Put everything...
      08-27-2021, 07:39 PM
    • wnlewis
      New wire for my RDE3340 Whirlpool electric range
      by wnlewis
      OK. I got the rocker switch figured out thanks to the good advice on this forum.
      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
      This is a Whirlpool RDE3340 electric range.
      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
      Where may I find parts...
      01-08-2025, 11:21 PM
