Onkyo tx-sr606 fluorescent display not working
  • Jblues
    Bing0
    • Nov 2014
    • 5
    Hi I've had this on my receiver and fixed by replacing a bad cap on the video board a 470uf 63v cap end bulged out surprising as it was a nichicon but only rated for 85 degrees Celsius this was in addition to replacing the caps twice on the HDMI board. its a good receiver just needs fans to cool it surprising some models had them going by the service manual just not all. going to look into adding them from the schematic for now I have a fan on top sucking the heat out I suggest anyone else do the same.
    • 31015
    Re: Onkyo tx-sr606 fluorescent display not working
    that's a terrible design putting caps near heatsinks!
    • Jblues
      Bing0
      • Nov 2014
      • 5
      I agree on that but there must be tons of these out there with bad caps and filling land fills as any one else would just junk it and buy new but its not a bad Receiver when it works still has Audessy new ones don't. Heat is the big killer in this one so I just put a Quiet 120 v fan on top to vent the heat so far so good! Why only some got the fans is probably Onkyo's cost cutting ?
      • drobson2
        • Feb 2018
        I found my cap to be bulged out identically to your picture.
        Is there any trick to changing that cap out? I've got it apart enough to have access to the bottom of the board. I though I read somewhere that I can just start pulling/twisting on the cap and it will come apart. I can then use the left-behind leads to solder the new cap to. Is that correct or do I need to completely de-solder the old one and and then solder in the new one?
        Thanks a bunch,
        Dave
        • madan1
          • Nov 2016
          • 682
          • Bulgaria
          No, do not pull/twist that sort of caps. You can do that with SMD caps ( the small metal ones ), but doing it to thru-hole components, you might damage the board.
          Just get the board out and desolder the bad cap(s)... it is not that hard, just take photos on every step you make and you will be good.
          Also pay attention to the cable connectors.. if I remember right, those onkyos have the "push" type cable connectors ( push the connector and then pull the cable ). When connecting back the cables, be careful to put each wire in its hole.
          • drobson2
            • Feb 2018
            Thanks much!
            • tmho
              • Jun 2016
              • 39
              Hi, I got the same receiver and the same capacitor with problem. But I do not know how to remove the ribbon cable from the connector so as to take out the PCB. That connector does not look like the press and pull type. Could jblues and madan1 please help?
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Is this a post-1990s receiver? Definitely looks like it is! That kind of bullshit is typical of certain kinds of post-1990s stuff, which the frequenter folks of the badcaps.net message board, know too well!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • re-atari
                  • Oct 2010
                  • 136
                  Depressing the top part of this connector unlocks the wires inside the connector, so you can pull the flatcable out. This type of connector fooled me as well when I had to fix my TX-SR803 a few years back. I think the SM describes how to disconnect the flatcable.
                  To prevent damage to the flatcable I used a flat screwdriver to depress the top of the connector.
                  Do support the PCB's bottom when putting force on the connector to prevent the PCB from flexing. It's made of a material (phenol) that tears/breaks quite easily. Pertinax PCB material has already been around for ages, and yet manufacturers continue to make use of lower quality phenol PCB's, like Onkyo did here. Onkyo certainly isn't not the only one, though.
                  re-atari
                  • tmho
                    • Jun 2016
                    • 39
                    re-atari
                    I followed your method and successfully removed the cable. Thank you.
                    • tmho
                      • Jun 2016
                      • 39
                      I have one more question. There is a bigger cap (16V 10000uF) beside the defective 63V 470uF cap as per Jblues photo above. At the bottom of the bigger cap, there is some white stuff. In my case, there is also white stuff at the bottom of both caps. The white stuff seems came out from the caps. Does that mean the bigger cap is defective and should be replaced although the top of it does bulge out?
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        i would change them all whilst in there.
                        • R_J
                          • 9535
                          The white stuff is glue used to secure the larger cap to the board, It does'nt come from the caps.
                          • tmho
                            • Jun 2016
                            • 39
                            Thank you. You save me the money on buying that cap.
                            • Secured
                              • Feb 2021
                              • Usa
                              2021, and your post helped me. Thanks
                              • Geraps
                                • Jan 2023
                                • Spain
                                thanks for the solution !!!
                                • assenheimer
                                  • Aug 2023
                                  • 4
                                  • Brazil
                                  In my case the display is very weak. I can barely see the display.
                                  Any suggestions?
                                  Thanks!
                                  • debruina
                                    • May 2020
                                    • 29
                                    • Nederland
                                    Any suggestions?
                                    Thanks!
                                    Maybe its just dimmed? press dimmer button, otherwise check ac line to display
                                    • assenheimer
                                      • Aug 2023
                                      • 4
                                      • Brazil
                                      The dimmer button goes even darker. When I press the dimmer button the display appears bright for a second and then goes very dark again.
                                      • lotas
                                        • Jan 2016
                                        • 4590
                                        • Russia
                                        Any suggestions?
                                        Thanks!
                                        Replace the display power capacitors (anode voltage and filament voltage).
                                        • ai.need.help
                                          Onkyo TX-8050 AV-Receiver no sound
                                          by ai.need.help
                                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                          It doesn't play music. There is no real output from:
                                          pre-out
                                          amp-out A and B
                                          phones out
                                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                          I tested with analog-input, usb and radio.
                                          I know that there is a common problem with...
                                          12-20-2022, 05:54 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
                                        • budwich
                                          onkyo 919 Receiver... hum problem but...
                                          by budwich
                                          I have an onyko 919. It has a hum problem at cold start which eventually dies / goes quiet. I have been "chasing" it for a while. Tightening ground screws and checking a few places. Basically, the problem is in the "back half" of the unit.... that is, if I take the sound out of the "pre-out" and feed it to a stand alone amp, it is good. If I feed in a signal at the external decoder input and play thru the back end of the onkyo, it has the hum.
                                          Anyway, along the way (the chase), a number of components (resistors, capacitors, etc) on the main board...
                                          01-13-2021, 03:31 PM
                                        • CdDvdFlash
                                          DSE GE6878 possible TV receiver dying remote not working well
                                          by CdDvdFlash
                                          For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                          07-03-2024, 03:55 AM
                                        • JordanW
                                          Diagnosing NAD receiver -- unexplained shut-downs
                                          by JordanW
                                          Everyone -- I am trying to troubleshoot my NAD C740 stereo receiver, which either won't power on or won't consistently stay powered on.
                                          I will start by saying that I am a hobbyist, and while I am decently handy with basic DC stuff, I am more hesitant when it comes to mains-powered equipment (that is, reluctant to poke around with a multimeter when it is powered on)
                                          The central issue is that after a long period of non-use, the receiver powers on and all functions seem to behave normally, but after a couple of minutes, it powers itself off.
                                          If I attempt...
                                          01-02-2023, 11:43 AM
