Strange fault in Fisher FM-60 tuner
  • Jooo
    • Oct 2011
    • 222
    • Finland
    I have this Fisher FM-60 tuner that is behaving strangely.
    It won't find any radio channels, unless I spray a little bit of cold spray to the tuner area.
    After that, it immediately finds the channels and will work flawlessly for weeks.
    Last time I left it running for 48 hours continuous and no problems. I also tried to unplug it for some days and it still worked.
    I heated the tuner area with a hair dryer without any affect on the functionality.
    Then one day, about two weeks after the last cold spray I was listening to the radio, all of sudden it lost the tuning again, and won't work again without a small bit of cold spray.
    I have now cold sprayed it three times, and it will always work for couple of weeks after that. I couldn't find any cold solder joints.
  • Ed Hall
    • Sep 2014
    • 30
    Re: Strange fault in Fisher FM-60 tuner
    My first inclination was toward a cold solder joint, as well, but I see it mentioned at the end of your message.
    I have also used the following two methods in similar situations:
    1- carefully let a little of the freeze spray out easily, so you get a drop and catch it with a small tool. Then place the drop onto an active component, and then continue one component at a time.
    2- tap lightly with a small screwdriver at some of the locations where the freeze spray worked. Be careful not to short anything.
    Of course, this will all have to be done at a time when the unit is broken...
    • jake51563
      • usa
      Have a p3 halo but dont no which caps to replace. Like coupling caps in a tube pre
        Is it FM-60 or KM-60?
        BTW, for localize cooling, I use Q-TIP.
        https://www.badcaps.net/forum/showth...ht=ln32b540p8d
          Are you asking about PARASOUND P3 HALO PRE-AMP?
          If it is, please start a new thread with make. model, and problem you are having.
          • DXseekerMO
            Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
            by DXseekerMO
            I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
            As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
            09-15-2021, 05:15 PM
          • Rictech
            Panasonic SA-MAX770PU SMPSU board fault....
            by Rictech
            Hello everyone. 😀
            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
            There are no devices that have exploded or otherwise show signs...
            08-26-2024, 01:05 AM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
            ESR meter came to the rescue again today with a PLC I/O card fault
            by sam_sam_sam
            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
            12-18-2023, 08:17 PM
          • crackedprint
            Sony HCD-HX80R Amplifier Volume Control Problem
            by crackedprint
            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
            I have tried a Cold Reset as per the service manual.
            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
            I have looked all the way through the service manual and tried many online...
            01-21-2025, 12:18 PM
