PARASOUND P3 Pre-amp reapair
    Notes: typo on the 'reapair' sorry.
    Got this one in for repair, the owner said it makes spatter distorted sound when the audio is applied to the any inputs and does not matter if the volume is up or down.
    I found that the +/- 30V power supply are not balanced, the +VCC is about 5V lower than -VCC, these are supplies for OPAMPs.
    Inspect the board and found that the center tap pin of the dual supplies was never soldered to the board, there was no solder applied.
    Soldered it and the voltages are reading fine now but the distorted sound is still present, I did more research on the non-opamp IC (there are two 16-pin ICs, one is for Volume control, and another one is for Tone control) so I can get the pin out for the voltages feeding the ICs, I was suspecting the Volume control IC since turning the Volume control knobs has no effect on the level of the distorted sound. The -VCC is showing -12V, but the +VCC is showing <1V, check the resistance reading on the +VCC and it shows < 5 Ohms. The +/-VCC pins are fed through 100 Ohms resistors and small lytics cap for filtering. Removed the filter caps and it still shows <5 Ohms, so I cut the +VCC pin then the 5 Ohms reading went away. check the +VCC pin and GND pin of the IC off the board and it shows <5 Ohms. Luckily I still some of these Toshiba ICs in stock, now it is running, it sounds pretty good.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: PARASOUND P3 Pre-amp reapair
    Thanks for the pics and documenting the repair.
    The only thing I remember about this brand when I was "into" audio was it was spelled Para$ound.
    --- begin sig file ---
    --- end sig file ---
    • Khron
      • Sep 2006
      • 1350
      • Finland
      While the repair is indeed commendable, i can't help but facepalm at the Black Gates and the Gold Tunes...
      No wonder it was spelled Para$$$ound
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • narf
        Epson EB-U42 projector / Caps with 0.7 ohms ?!
        by narf
        hi all,
        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
        what i've found so far:
        - the PSU does its job and supplies 12V to the mainboard via the connector.
        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
        - not far away, there's the first cap with a resistance of 0.7 ohms....
        07-02-2024, 03:53 PM
      • maleksa
        Yamaha MOX8 boot freeze and distorted sound
        by maleksa
        My Yamaha MOX8 synthesizer recently developed two issues.
        Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
        Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
        11-07-2024, 03:28 AM
      • Baste
        What are the pro's and cons of replacing a 1/4 with a 1/2 resistor same ohms?
        by Baste
        As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
        Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a...
        10-30-2025, 11:51 PM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • gica69
        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
        by gica69
        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
        Resistor shows orange range silver gold and green lines.
        Thanks in adv...
        07-21-2025, 09:49 PM
