Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
  • TinkerTron
    • Mar 2025
    • 8
    • Switzerland
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic for the radio board shows about 40 resistors, all labeled with their values. That's fine. But when I look at the actual radio board, I can only find about 5 resistors. And when I look at the wiring diagram in the service manual (the one that shows the actual board layout, rails, and component placement) I also only see those same few resistors . The parts list at the end of the manual also only includes those resistors (plus of course the ones on the clock board, which I'm not referring to).
    However, the wiring diagram (radio board layout) has a blue/cyan overlay that seems to represent all the "missing/ghost" resistors — 30ish of them — the same ones that appear in the schematic.
    I'm not sure what to make of this. Are these resistors hidden somewhere? Integrated into something else? Or is there some convention I'm missing?
    Apologies if my terminology isn't perfect — I'm still learning. My intro post should give some background on where I'm at.
    Attached are some pictures of the aforementioned schematic, diagram and parts list.
    I've made the full service manual available here: https://drive.proton.me/urls/TZN4HG59QC#YxX7A8fRFliS
    Thanks!
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    its capacitor coupled output so you will see dc at the speaker connections without a speaker connected
    • petehall347
      • Jan 2015
      • 4448
      • United Kingdom
      i cant see the actual boards
      • TinkerTron
        • Mar 2025
        • 8
        • Switzerland
        Oh, that's excellent info. Thank you very much! I'll test it with a dummy load.
        What about my "ghost" resistors? Would you happen to know something about that?
        • TinkerTron
          • Mar 2025
          • 8
          • Switzerland
          here's a picture I took of the actual board. It looks kind of "unpopulated" to me...
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            its just a variation like that board can be used for other models .
            • TinkerTron
              • Mar 2025
              • 8
              • Switzerland
              As for the capacitor coupled output, I got it, thanks! So if I connect a speaker, should I expect that DC voltage to disappear? And would measuring across the speaker terminals with the speaker connected give me a better idea of whether there's an actual DC issue?
              But also, am I correct in assuming that the only resistors actually needed for this circuit to work are the ones physically present on my board? Even though the schematic shows around 30 more resistors? I may be a newbie, but this seems like a big discrepancy to me (?).
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                there will be other things not there ..
                • lti
                  • May 2011
                  • 2557
                  I don't know why I didn't see this earlier, but those are printed thick film resistors. The resistor is the black rectangle in between the pads. I wouldn't have expected them to have good enough tolerance back then, but they were used a lot for non-critical stuff.
                  That's also a 2-layer PCB with plated through-holes, which I didn't think existed in the 1970s.
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • Ritchie_Uk
                    Sharp 32BC2K0 Service Manual of Fix Please?
                    by Ritchie_Uk
                    Hi Folks
                    I am searching for a Sharp 32BC2K0 Service Manual
                    Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
                    Fault - Coloured "Bars" very thin all across the screen.
                    I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
                    I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
                    Is there such thing as a Boardview for this TV?
                    I will Post the Photos in a second
                    Stay Safe !...
                    09-05-2024, 06:35 AM
                  • praveenramavath
                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                    by praveenramavath
                    Hello All,
                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                    https://www.hifivision.com/threads/m...-screen.98243/
                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                    04-26-2025, 09:08 AM
                    HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                    This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                    09-12-2024, 02:00 PM
                  • Omron
                    Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                    by Omron
                    Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                    My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                    - Tried to unplug radio and plug it back in into power,
                    - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                    - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                    05-23-2024, 01:27 PM
