Sharp 32BC2K0 Service Manual of Fix Please?
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    • I.T
    Hi Folks
    I am searching for a Sharp 32BC2K0 Service Manual
    Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
    Fault - Coloured "Bars" very thin all across the screen.
    I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
    I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
    Is there such thing as a Boardview for this TV?
    I will Post the Photos in a second
    Stay Safe !!
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    • I.T
    • lotas
      • Jan 2016
      • 5398
      • Russia
      R - 2x47 Ohm
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        • I.T
        Hey Iotas
        Thanks for that.
        How did you know the value?
        Did you know the Component next to it Value / Type?
        Do you have a schematic, please?
        Thanks for your help already
        • lotas
          • Jan 2016
          • 5398
          • Russia
          This photo is from the Internet, the marking 470 is visible in the photo, and this is 47 Ohm, there is a diagram, but the component values ​​​​are not indicated on it.
          • Ritchie_Uk
            Prawnography
            • Mar 2021
            • 185
            • Uk
            • I.T
            lotas Thankyou
            Its the other component value I am not sure of it looks like CB117, which implies its a Cap
            • lotas
              • Jan 2016
              • 5398
              • Russia
              Yes there should be a ceramic capacitor
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                • I.T
                Yes, I added one, not knowing what the value should be, and it burnt out the 47 Ohm resistor
                • Diah
                  • Feb 2013
                  • 6763
                  with screen resolution 1366 x 768 when displaying only color bars they changed positions regards to image source... there are cleaning wet damage on the panel buffer boards
                  • lotas
                    • Jan 2016
                    • 5398
                    • Russia
                    There the capacitor should be of small capacity, somewhere around 0.01uF
                    • Ritchie_Uk
                      Prawnography
                      • Mar 2021
                      • 185
                      • Uk
                      • I.T
                      Thankyou
                      Let me try in the morning
                      will update you
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        • I.T
                        Hi Iotas
                        I was going to order a mainboard, but would rather repair the board.
                        I havnt even looked at the front panel yet, as the burning smell came from the mainboard, which ended up being the burnt resistor, and missing component.
                        Its a nice TV
                        Thankyou
                        • Ritchie_Uk
                          Prawnography
                          • Mar 2021
                          • 185
                          • Uk
                          • I.T
                          Hey lotas
                          Thanks for your suggestions earlier
                          As Promised, sorry for the delay, the update is that those components have worked, and we have a screen that lights up now
                          I had to order some components
                          We have no audio, but it could be that it isnt tuned, so I am going to use a computer, to connect the HDMI port
                          Sadly the Flexi Cable on the T-Con board was torn off, which I didnt notice at first.
                          It wasnt much, just slightly, so when I rubbed my finger over it, the screen flickered.
                          Will try it now
                          • Ritchie_Uk
                            Prawnography
                            • Mar 2021
                            • 185
                            • Uk
                            • I.T
                            ps - Has the screen Flexi Cable ever been successfully stuck back on?
                            • lotas
                              • Jan 2016
                              • 5398
                              • Russia
                              Is it torn from the glass or from the buffer strip? Can I look at the photo?
                              • Ritchie_Uk
                                Prawnography
                                • Mar 2021
                                • 185
                                • Uk
                                • I.T
                                Hi Lotas - The FlexiCable has pulled away from the main board
                                ​Torn away from the Buffer Strip
                                Not torn or Damaged
                                When I rub my finger over the Cable, picture tries to come back
                                I have reassembled the TV as It's taking up too much space in bits
