Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off and on rapidly. Sometimes it would stayed off a few 5-10 seconds, then powered on, then repeating the clicking off and on cycles. I powered it down, wait for a minute or so, then powered it up again - this cycles went on for the 20-30 seconds, then a quick flashlight on the fuse, and everything stopped. Checked the fuse and it is opened. When I power down, then on again with the blown fuse, it clicked but nothing else happened.
    Quick visual check find nothing obviously burnt, nor any burning smell. But noticed the the big capacitors are slightly bulging.
    Any clue on what was happening? Could it be the CD input or these capacitors be the cause of the power clicking off and on?
    And what would be the next steps with the diagnostics?
    Thank you very much.​
    • 31066
    looking at the rust and oxidising on the power section,
    the first thing i would do is put contact cleaner in the voltage selection switches and work it in!
    then consider doing it with every other switch and pot - maybe even the relay if it's not sealed
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      OK, will start doing them ongoing basis.
      While waiting for replacement fuse and capacitors, I wanted to put in a 5A (original is 4A) fuse along with a dim bulb tester to power up and see if the power relay still clicking off and on without the CD player connected.
      Is it safe to do?
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        I have recently gotten some new parts to replace the 2x biggest capacitors on the mainboard and the 3 small ones on the power-board, and added the 4A fuse. I have also sprayed contact cleaner onto the 2 voltage switches, and worked them a bit by sliding the switches left and right. The relay is seal so nothing done there.
        I added a series bulb on the live-cable into the power supply in.
        On switching on the power supply, I measure some voltages on the "control board" and seems the have the voltages there. When I press the power button on the front panel - the relay started clicking on of off continuously, and so did the series bulk flickering on and off correspondingly.
        Presumably a short-circuit somewhere. I've taken a quick continuity check on most of the diodes, resistors, transistors and capacitors, but nothing obviously shorted.
        What/where would be the most likely components to further more thorough check?
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          http://www.hifiengine.com/manual_lib.../cm-1090.shtml
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            try a higher wattage bulb in your dbt limiter
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              Will do - is 100W bulb sufficient? If not, how high must it be?
              Meanwhile - I done 1 more round of checking and noticed the power regulator, C78M10, has really loose joint, all 3 pins. So I reflowed them, and all the other 3 ICs in the same row. Now, the power relay (and bulb) just clicked once then off, instead of continuously.
              Does it mean anything??
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                Wow - knowledge and/or experience is truly power - after changed to a 100w bulb, it powers right up!!
                I presumed the bulb lighted up at around 10-20% wattage level at unloaded condition is normal, and safe to remove the DBT?
                I did some googling and reckon that some amplifier has protection circuitry to shutdown in under/over current/voltage conditions - presumably this is the case?
                And to petehall347 THANK YOU VERY MUCH!!
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  i might use an ammeter and plug it into the mains do a search for plug in power monitor
                  • beetle1303
                    • Jul 2019
                    • 279
                    • Singapore
                    You meant something like this - it draws 0.2A, so quite safe to plug directly to the wall without the DBT?
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      give it a go with clamp meter and into full power
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        Sound and Safe into full power - 0.71A.
                        Just curious how the math works - 100w / 240v = 0.417A, but it shown 0.2A with 100w bulb, and 0.71A without it?
                        • corrize
                          A funny fuse story – Lumix LX100 II
                          by corrize
                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                          10-19-2023, 09:58 AM
                        • DodgyTech
                          60" LG 60PB690V relay clicking issue
                          by DodgyTech
                          I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                          I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                          I would like to try and identify...
                          07-07-2023, 10:30 AM
                        • GraphicMan
                          Pioneer amplifier A-205 Relay not clicking after a mistake i made
                          by GraphicMan
                          Hello guys
                          Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
                          sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
                          i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
                          on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
                          05-05-2024, 06:20 AM
                        • valvashon
                          Repair Success! Middle Atlantic UPS2200R-IP
                          by valvashon
                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                          02-06-2024, 12:54 PM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
