60" LG 60PB690V relay clicking issue
  • DodgyTech
    • Jul 2023
    • 3
    • United Kingdom
    I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
    I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
    I would like to try and identify the faulty component if it's in one of the boards that are at the back rather than purchase a new board (if we can work out what it is).
    I have a multimeter and have a soldering station so I can have a go at testing/replacing components as required.
    Video link (3min 41sec): https://youtu.be/8IULh7uoGXs
    Thank you all in advance
    EDIT:
    Power board part number: EAY63168603 (PCB: EAX65359531, Rev: 1.0)
    YSUS board part number: EAX65331001 (2.0)
    ZSUS board part number: EAX65331101 (2.2)
    Logic board part number: EAX65399305 (1.0)
    List of the sites/pages I visit in my research:
    https://www.badcaps.net/forum/showthread.php?t=72699
    https://www.badcaps.net/forum/showthread.php?t=66297
    https://www.youtube.com/watch?v=egNSzoH4tRc
    https://www.youtube.com/watch?v=SfXf58shH-o
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: 60" LG 60PB690V relay clicking issue
    This board is not always easy to repair, but first you need to find where the fault lies, if there's any shorted component on Y-SUS, Z-SUS, you know it.
    Test if the buffers are ok, example video:
    https://www.youtube.com/watch?v=3Oq2MsU0XOQ
    • DodgyTech
      • Jul 2023
      • 3
      • United Kingdom
      Thanks for the video, I tested one of the two buffer boards and didn't find any continuity.
      In the middle of doing this, I connected the YSUS board without the buffer boards attached and found the clicking still persisted. That leads me to think it's not the buffer boards but the YSUS board itself.
      Any tips on how to find the fault if it's within the YSUS board?
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Take the Z and Y boards and measure all the transistors, most important are the bigger SMD ones on the back, and the ones mounted to the heatsinks, any short = bad.
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • Stephen
          A2991 Logic Board issue, 20volts 0 amps help!
          by Stephen
          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
          09-10-2025, 03:16 PM
        • Stephen
          A2991 logic board issue, 20volts 0 amps help!
          by Stephen
          09-10-2025, 03:15 PM
        • notallbad
          TCL 55RP620K power board issue
          by notallbad
          Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
          0% p_dim at 1.65v and a_dim at 1v
          50% p_dim at 3.3v and a_dim at 1.65v
          100% p_dim at 3.3v and a_dim at 2.88v
          Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
          Leds are 2 rows of 15 6v leds.
          On inspection of the power board found diode MBR3200 shorted so replaced with...
          07-12-2025, 05:45 AM
        • TrisHCl
          LED TV Boot loop - UE40F6500SB
          by TrisHCl
          First post...
          I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
          Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
          I disconnected the main board from the power...
          02-06-2025, 08:42 AM
