Yamaha HTA-5630RDS Amplifier dead
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    The first picture wasnt very good so here is another. I cant seem to meaeasure any voltage anywhere other than the 240v mains input on the small pcb top left. I checked the 470uf cap on there and it is ok. There is no voltage going to the transformer below it on the blue and grey wires.
    a bit of a mystery.
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      1st image has got rotated 90 degrees to the right so my reference to top left is now top right.
      • R_J
        • 9549
        How about checking some voltages... do you have standby voltage? I will give you a hint, it should be across C681, that 470µf capacitor.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          Thanks very much . Getting 50v across C681. I did check this cap and its within tolerance. I popped the cover off the relay and there is voltage there and manually moving the points gets a tiny spark.
          • R_J
            • 9549
            If you are getting 50V across C681 either there is something seriously wrong with that standby circuit or your meter is bad. You should have around 14 vdc across C681
            Are you sure about that model number? Could it be HTR-5630RDS
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              Yes your right its a typo sorry its HTR-630RDS.
              i was meassuring the voltage across the cap with the 3 pin ribbon cable disconnected because its so short i couldn't find a safe way to turn the board upside down when it was live to measure the voltage. I just got the Mrs to hold it for me and with the 3 pin ribbon cable connected there is no voltage showing across that cap.
              • R_J
                • 9549
                That is the standby power supply, on your model the standby consists of T681 transformer, bridge diodes (D6683,684,686,687) I would check the resistance of the transformer, I suspect the primary is open.
                Components in yellow are not in your model.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  Think your right about the little transformer as can only get a reading on 2 contacts on one side of the transformer and nothing on any other pair of contacts. Could you possibly point to a suitable replacement on ebay or rs etc.
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    Typed these numbers into google and nothing found.
                    • R_J
                      • 9549
                      This is the part number from the manual for T681 XW608A00 TRANS.PWR TKABGL (British model) A search on the internet found a few listings
                      If you can find a small (non pc mount) transformer with your country primary voltage and a secondary voltage of around 12~13VAC you could likely wire it in and mount it inside somewhere.
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        would this one do?
                        https://fixpart.co.uk/product/yamaha...A0NjQ.#reviews
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          Well i found a new transformer and fitted it but sadly it still doesn't turn on any more things to check?
                          • roadrash
                            • Oct 2015
                            • 490
                            • U.K.
                            I cant figure this one out at all. Its beyond my abilities to diagnose and work out where the fault lies. Ive checked most everything on the standby power supply board including the transistor, and all diodes plus I replaced the elecro cap and the transformer which I had to get from Germany and cost me £20. The fault must be elsewhere.
                            • R_J
                              • 9549
                              It is a simple transformer; do you have line voltage on the primary? do you have 14vAC on the secondary? What is the resistance of the primary winding and the (center tapped) secondary ?
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                It is a simple transformer; do you have line voltage on the primary? do you have 14vAC on the secondary? What is the resistance of the primary winding and the (centre tapped) secondary ?
                                Thanks for the reply RJ. Dont know if I am taking measurements from the wrong place. On the transformer there are 2 contacts on one side and 4 on the other. I am not getting any voltage reading on the single pair of contacts which I thought were the primary ones. I hooked the transformer up to my component tester and look at the photos to see the results I got. These were the only pairs of contacts that gave a resistance reading.
                                • double_DD
                                  How can I be sure that my EC chip is dead?
                                  by double_DD
                                  As the title suggests, how can I be sure that my EC chip is really dead?
                                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                  03-12-2025, 07:47 AM
                                • hemant_2222
                                  Yamaha RX-A1020 full dead
                                  by hemant_2222
                                  Hello Everyone,
                                  Greetings!
                                  It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
                                  09-14-2024, 11:25 AM
                                • Nevillet
                                  Yamaha A-520 HiFi amplifier
                                  by Nevillet
                                  Hi All,
                                  I have a Yamaha A-520 that has no sound output.
                                  I notice after power up the protection protection relay does not click in.
                                  I'd appreciate any pointers on where to start.
                                  Many thanks.
                                  Service Manual below:
                                  https://www.badcaps.net/forum/attach...1&d=1641841819...
                                  01-10-2022, 01:11 PM
                                • flibidy
                                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                  by flibidy
                                  I have here a Magnum IA.100 which belongs to my parents.
                                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                  What Ive done........
                                  01-01-2025, 01:26 PM
                                • disorder
                                  ps5 edm-033 dead after hdmi/usb ports destroyed
                                  by disorder
                                  hello guys,
                                  i need help to repair a edm-033 ps2
                                  history : as always hdmi port and usb ports destroyed after unplugged
                                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                  so i changed it
                                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                  i don't see any projection of liquid metal on pcb.
                                  01-14-2025, 12:48 PM
