Pioneer VSX-920K Hum
  • UND312DOG
    • May 2014
    • 63
    All,
    I've recently been getting a hum/buzz through my home theatre system. When I installed it early last year everything was fine, no noise. Recently I have noticed a hum. Originally I thought it was a ground loop. So I did an isolation test. No change. I also tried a new PowerPoint via a extension cord with everything connected from my home theatre to it. Noise still there.
    The loudness of the hum is becoming unbearable to a point where I have to turn the volume up to drown out the hum. Which is no good at night with the bub asleep.
    I have also noticed sometimes when I turn my receiver off and leave it off for a minute or so. When I switch it back on the hum is very slight and barely noticeable, unless I put my ear to the speaker.
    With all this in mind I believe there is a fault somewhere in the VSX-920k, something inside is causing this hum through the speakers.
    Thoughts?
    Re: Pioneer VSX-920K Hum
    Do you still get hum if you remove all the input signal cables, just have the amp and the speakers only?
    • tibimakai
      • Jan 2012
      • 3680
      I remember a Youtube video with a similar issue(different receiver though) and it was a bad capacitor.
      Here it is:
      http://www.youtube.com/watch?v=-4b1PSy2TSQ
      • UND312DOG
        • May 2014
        • 63
        Yep. I have isolated individual inputs. Changed inputs via the amp. Still a hum. Sometimes it's there. Then sometimes not. I'm assuming its a problem with one of the components inside. Looking at that YouTube video it's sounds exactly like that. So probably a capacacitor. I will have to open it up and take a look at the board.
        • UND312DOG
          • May 2014
          • 63
          Ok. Opened up the receiver. What a pain in the arse. Anyways, found 0 bad capacitors. I noticed that some of the ground screws seemed a little loose. So I put it all back together, connected it back up. Hum gone. Not sure why though. Maybe a loose cable, bad ground. Any ideas?
            If you at the bottom side of the boards, they use the board mounting screws and the ground pads around the board mounting holes for grounding, I usually solder piece or wires from those ground pads to the chassis so I do not have to tighten the screws in the future.
            Glad you found the problem.
            • UND312DOG
              • May 2014
              • 63
              Ok. So everything's been fine since my last post. Until two days ago when the hum returned. It driving me nuts. It's weird that it's been fine since May 2014 then suddenly returning again. I'm going to have to pull it apart and have another look. Ive being doing a bit of research and it seems most of time, the problem is a bad capacitor.
              Any other ideas?
              • UND312DOG
                • May 2014
                • 63
                To add. It's been humming all day. And has now stopped. Very weird indeed.
                • R_J
                  • 9549
                  Maybe it does'nt know all the words so it hums I would take the cover off when it's humming and using a plastic or wooden stick, probe around looking for a poor connection somewhere on a board or a cable. It could be a poor solder connection somewhere on one of the boards.
                  • Longbow
                    • Jun 2011
                    • 623
                    If you made no changes to the system wiring, then why would a ground loop suddenly appear?
                    You didn't describe what your isolation test was, and what it attempted to show. In other words, what did you isolate from what? The usual test is to remove all connectors and wires, leaving only the AC power cord, while listening with headphones. Also, it is good to specify whether you hear nice smooth 50/60 Hz hum, or rather an annoying buzz sound, which actually is not hum at all.
                    All channels have hum? All inputs have hum? Does the hum get louder when you turn up the volume control? If not, you don't have an amplifier problem.
                    I have also noticed sometimes when I turn my receiver off and leave it off for a minute or so. When I switch it back on the hum is very slight and barely noticeable.
                    ...finally we're getting somewhere. That would mean the hum is actually coming from the unit itself and not being picked up from outside sources.
                    The next step is to check the individual inputs one by one using your switch-off method (above). If you get the same slow increase in noise or hum as the unit warms up, I recommend investing in a can of freeze spray. Carefully cooling different sections of the unit one at a time could isolate your trouble. At the moment, I'm betting on the DSP.
                    Is it plugged in?
                    • UND312DOG
                      • May 2014
                      • 63
                      Ok. Bringing up my old topic. The problem returned. Today I pulled the whole receiver apart. Took out all the cards. Tested the filter capacitors, all good. Powered it back up. Still humming. Even via the headphone. So I assumed it was a ground problem.
                      So I went through all the grounds and made sure whilst assembling it I checked every ground pad and ground. Plus anything that had a screw attached to the chassis. It's all back together and zero humming. So I'm guessing it was a ground on one of the cards to the chassis.
                      Kinda weird that this appeared out of the blue but I guess due to heat and expansion/contraction the contacts on one of the ground circuits wasn't 100%.
                      • Bushcat
                        Pioneer PL-X9 motor speed control wobble
                        by Bushcat
                        I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                        Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                        BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                        05-24-2023, 03:36 AM
                      • Biruslapio
                        LG 50PB690 power supply terrible noise
                        by Biruslapio
                        I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                        As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                        I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                        07-13-2022, 12:46 PM
                      • tracid1987
                        Samsung LE40F86BDX (model 2007) noise in picture
                        by tracid1987
                        Hi
                        I have this TV bought back in 2007 and used it for playing on PS3 for 4-5 years actively. After then it was barely used. It was mostly in stand-by mode or plugged out of mains completely for years. Today when i turned it on i have noticed noise in picture on two different locations of the screen. As you can see on the photos (see attachments) the noise is only in a small rectangle area, and if you look at it closely you see that one noise rectangle area is at the upper left corner of first half of screen, the other noise rectangle area is at the upper left corner of the second...
                        08-21-2021, 01:48 PM
                      • RatherLoopy
                        Pioneer VSX-44 receiver HDMI dropouts
                        by RatherLoopy
                        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                        05-26-2023, 03:54 PM
                      • eccerr0r
                        DSI 5600A frequency counter noise ...
                        by eccerr0r
                        Anyone have a old ancient DSI 5600A frequency counter (late 1970s)?
                        Just wondering if you see significant noise on the readout now in 2023, and if you replaced the caps in it.
                        I had huge amount of noise in the readout but after replacing the caps it went down a lot - but not zero... Still trying to figure out how t get the noise down when right now it looks to me to be a design flaw...
                        04-22-2023, 12:50 AM
