Recapping Your Soundcard!
  • Logistics
    • Apr 2007
    • 721
    Okay, quick'n'dirty thread!
    IIRC, I posted elsewhere on the board explaining what I did to my SBLive!, but in case you missed it, here is what I did:
    First of all, I switched from the Creative drivers to the kX Project drivers. You should do this before anything else. It is always said that the DAC for the rear channel on the SBLive! is superior in sound quality to that of the front channel. The kX software allows you to swap the front and rear output channels so that the rear output acts as the front, allowing you to use the superior DAC for listening enjoyment.
    After examing the board, it appears that this is because rather than sound running out of the EMU10K DSP to the AC'97 Codec DAC, it runs from the EMU10K DSP to a seperate Phillips DAC. Both of these DAC's are followed by an unidentifiable operational amplifier which boosts the analog output power.
    The traces between either of these DAC's and the output OpAmps contain signal decoupling caps, the likes of 10uF 16V electrolytics. I don't use surround so I am simply using the rear output. In my case, I changed the electrolytics to .1uF film capacitors.
    The difference is not something you have to try to hear, it's obvious. You will hear all sorts of things you did not hear in the recording previously. There is amazing seperation between sounds/instruments/voices. It is crisp and clear. The electrolytics add this horrible hash where everything is sort of blended together and it sounds quite garbagey in comparison, causing listening fatigue, very quickly. I kept the volume at exactly the same level during all modifications, which was about as loud as I could comfortably listen, but this caused listening fatigue with the electrolytics. Removing the electrolytics and installing the films removes this listening fatigue.
    There are four electrolytics on the bottom of the SBLive! which bypass the power traces coming from the PCI bus. IIRC, they are originally 100uF 16V. Adding .01uF and .001uF films in addition to the electrolytic causes the sound to be blacker, in that silence is more silent.
    The only con to putting the small .1uF films in the signal path and removing the large 10uF is that the low frequency cut-off is reduced, meaning you lose bass. This was obvious on my bass CD's, but for almost everything else, I never notice it because most things don't hit that low. Happily, though everything else seems to have improved bass response. Cleaner, tighter, just better.
    What I plan on doing next, and what is actually ideal, is to order actual crossover caps. These are large and will have to be fastened to perhaps the backside of the board with hot-glue or something, but it should return the originally intended bass response and actually be much better in every way because the films I used are just some old miscellaneous films out of a dead monitor, whereas ideally, at least a metallized polypropylene film should be used if not a polypropylene film & foil cap. You can find this sort of cap at Parts Express. I'm going to use the Dayton metallized polypropylenes. The 10uF's are only about $4 IIRC.
    You could actually use the 100uF versions to replace those four bypass electrolytics mentioned earlier, but space becomes a huge issue then. I think any other changes here should simply be quality, low esr electrolytics to replace the originals.
    If you do nothing else, switch to the kX drivers, use the rear output jack and replace the signal decoupling caps on this channel. I can't stress enough how much better this sounds. Just do it, now, GO GO GO!!!11ONE XD Maybe later we can do a sticky thread with pics. Oh and if you want to try something on a different soundcard, just try to follow the traces back from the output jack you are using and find the electrolytics which are being used as signal decoupling caps. The giveaway on my card is that on the backside of the board these caps are not bypassing to the ground plane and don't go anywhere on the back, they are a continuation of the signal path on the top side.
  • ferynov
    • Dec 2006
    • 18
    Re: Recapping Your Soundcard!
    can u show the pics?
    • Logistics
      • Apr 2007
      • 721
      Gah, I replaced the bypass caps that run on the power traces from the PCI bus again, but now the card has problems and won't work. This was probably the second or third time and I think the VIAs finally decided that was enough. hehe! Sorry! ;p I have another thread on a SB16, though.
      • Fizzycapola
        • Oct 2006
        • 423
        Any chance of some pictures?
        Rubycon Rubycon Rubycon
        • El-kamote
          • Jul 2006
          • 12
          I got an old SB Live! Value (CT4670) for peanuts, and decided to mod this one just for kicks. The EMU10K is still a great chip, and I do play games once in a while. I'm thinking of replacing the lone headphone driver, a Philips TDA1308 (used as an opamp, I guess? ), with a better one, and replace all those ugly & misshapen Wincaps around the AC97 chip. Better yet, replace all those . Any suggestions? I'm thinking of upping the output caps a bit, from 100u to 220u
          • Logistics
            • Apr 2007
            • 721
            Ahh, my Live! did not have that IC; it had a philips 1300a, which is just a codec ic. I wish it would have had the same IC as yours. I would not change the value of the capacitors, but I would change to better caps, such as Panasonic FM's from Digi-Key. Also, if you can find the decoupling caps in the signal path, change them to either Panasonic SU's (bipolar, leaded, radial electrolytics) from Digi-Key or rig up some films on there.
            If you're just doing headphone listening I would get rid of the Creative drivers and switch to the kX Project drivers so you can use the rear output, which I'm guessing has the superior codec on the rear output like my Live!. Then you can use the ASIO plugin for Winamp or Foobar.
            • El-kamote
              • Jul 2006
              • 12
              I recently finished recapping 2 cards, my Live! and an SB AudioPCI in my parts bin, and it was a total recap. Live! cards aren't really mod friendly, got problems removing the solder in holes and the PCB can be easily scratched. Took me more than 2 hours to recap . In contrast, the AudioPCI took me a little over 30 minutes to remove & recap.
              Initially I used stock values but the sound was a bit muted. I used 100uf GP (general purpose) Elnas on the output, same value before the recap. Eventually I replaced those with 470uf 6.3v Panny HFQs, the same ones I used on the AudioPCI. The sound became clearer and more vibrant, and the bass became more of a "thud" than a "thump." It seems that the card has a provision for larger caps.
              The large caps on output are Panny HFQs, yellow caps on the rear output are 33uf 16V Elna and the green ones near the VRM are 220uf 16V low-ESR Sanyo minis. I eventually replaced the PCI filters with Sanyos, up from 47uf. The rest of the caps are just GP Chemicon KMEs. The chip near the output caps is the TDA headphone driver.
              I'm pretty much happy with the card right now. I have to turn down the volume of my desk speakers a bit since after the recap, just love the quality of the sound. If I can grab an LM4562 as opamp replacement, I'll stick with this card until I can afford an Auzentech .
              • Delicieuxz
                I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                by Delicieuxz
                I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                Here's an audio clip of the sound coming from my speakers:
                https://vocaroo.com/16HaryHwTx78
                I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                11-15-2023, 09:50 PM
              • Physios
                Large vs small electrolytics reliability
                by Physios
                Goodmorning.
                I have a curiosity: can low voltage/capacity electrolytic capacitors (e.g. 16V/47uf) last longer than high voltage / capacity ones (e.g. 63V/2200uf)?
                I ask because many threads indicate a life of electrolytics that does not go beyond 15 years (it seems to me that Panasonic has written something in its documents), but I have several musical instruments bought in 1980 that work perfectly: they have inside them many small electrolytics. I tried asking an electrical engineering friend to unsolder some and measure them, and these were incredibly within spec....
                03-08-2021, 01:28 AM
              • Crystaleyes
                What are the 'actual' effects of old electrolytics in a vintage radio?
                by Crystaleyes
                Hi all.
                Just trying to get a better understanding of electronics in general, and although I know that it can be general practice to replace any electrolytics in vintage gear, I was wondering 'what' are the effects from these failed components?
                I can see that a shorted cap acts as a short circuit and therefore a power drain, but what else might it cause?
                Similarly, an open cap won't be smoothing any signals but is there anything else?
                I'm sure this is basic 101 but I'm not at school, so just learning as I blow things up...
                07-05-2022, 06:41 PM
              • Exim
                Yamaha YST-MS25 amp board recap: replace small electrolytics with different type?
                by Exim
                Hi there, I'm working on the 25W amp board of a Yamaha YST-MS25. It's 20yrs old.
                Since a few months the volume on the left channel is way too low. It turned out that - compared to the intended use and the former price tag of this thing - they put solid stuff into it. So I decided it's worth a recap.
                The board uses two amp ICs on opposite sites of the board. Both ICs are connected to the same heatsink. The heatsink unfortunately is a bridge-like construction that covers almost all other components, including the majority of the caps (pictures and schematics below).
                10-31-2018, 04:11 PM
              • Pentium4
                Replacing low value electrolytics with ceramic?
                by Pentium4
                So I disappeared from working on electronics for quite some time. I'm unboxing my ancient projects and want to resume some of them. Unfortunately, my knowledge is a little rusty.
                I've always liked to do full recaps on power supplies. My cap supply isn't perfect and I do not have any more 0.47uF 50V caps. I do have some ceramic caps with that value. Can they replace the lytic without issues? If I remember correctly, their max voltage drops rapidly after getting hot. Is that correct? If this isn't a good idea, I doubt the cap will cause any problems. It's by the main controller/exhaust...
                12-13-2021, 02:23 AM
