Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
ARCAM AVR500--SAMWHA caps--Unbelieveable!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    This £2,500 retail specialist 7.1 AV amplifier uses Cruddy SAMWHA capacitors in the PSU and the Power-Amp Stages.
    There are a couple of 6800uF 35V in PSU that are already bulging, its only 4 years old.....
    Next time Ive the lid off--To fix the faults it has, when I get some replacement caps and Transistors I'll take pics of the PSU, the O/P boards etc....
    (O/P stages blown apart, due to equally crappy Bias-Setting pots!)
    To say that I was amazed/dismayed is an Understatement! So much for Great British Engineering!
    Perhaps that's why this particular model is known to have issues!
    TELEFIX
  • retiredcaps
    • Apr 2010
    • 9271
    Re: ARCAM AVR500--SAMWHA caps--Unbelieveable!
    I remember lusting over Arcam amplifiers, but they were out of my price range back then.
    Yes, pictures please.
    I don't follow the audio world anymore, but for people who know how to fix them, it presents an opportunity to get a non working for cheap.
    --- begin sig file ---
    --- end sig file ---
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Out of interest, I contacted Arcam with my problems and although this amplifier is well out of any warranty or any obligation for them to do anything, they have offered to renovate, repair and update it and completely free of charge.
      They acknowledge that there have been issues with this model, and have developed remedies for the problems....
      I am very impressed by this offer, and will let you know how it goes....
      TELEFIX
        master hoarder
        • May 2008
        • 12182
        Thanks nice of them. Keeps us posted.
        I recently repaired a Behringer EPQ1200 rack amplifier. Although the problem wasn't due to the caps at all, I should still note that it used CapXon caps on the primary side and Decon caps elsewhere - including the PSU, which is of the switchmode type.
        • quattro alex
          • Mar 2012
          • 92
          Lets hope their customer service is better than their choice of caps ( I really hope they don't use those Samwha's in the AVR600)
          Here's an interesting repair following a previous repair at the Arcam factory.
          When you get it back can you do a followup report so we can see how good they are?
          Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
          • retiredcaps
            • Apr 2010
            • 9271
            Hmm, I don't see in the Rubycon YK datasheet where ESR is listed. There is a line about impedance ratio (MAX), but no individual parameters/values for each cap.
            I wonder how the person in the above pdf file determined that 15 out of 19 YK capacitors exceeded the ESR limits?
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Well, the YK is an 85C general purpose series, so "of course" they won't have any impedance / ESR specs. Best case scenario, those particular ones were above some arbitrary "rule of thumb"-value?
              On the other hand, even small-can caps from low-ESR series can have their nominal ESR in the low ohms range
              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              • bcstedt
                • Jun 2011
                • 59
                Any updates?
                • bcstedt
                  • Jun 2011
                  • 59
                  Any updates? I've got an AVR600 that needs some looking after.
                  • nodols
                    • Jan 2023
                    • 24
                    Kind of an old thread, but got a non working Arcam AVR400 for cheap. Layout is nice, but components used. I don't know what happened, might be cheapening out them?
                    • spiros.p
                      • Dec 2020
                      • 89
                      • Greece
                      not surprised by one 2000euros measuring instrument or lab psu and you see inside crap capxon or chang capacitors.take a look inside at motu expensive interfaces or 1000 + crown amp.or dell psus everyone cut the parts cost and the end user pay the bill.plus the destraction of the environment.they care only if you drink your coffee with recycled straw.only money matters nothing else.
                      • birchy7
                        Arcam FMJ A29 Stero Amp - schematic diagram of power supply
                        by birchy7
                        Hi, I'm hoping someone on here can supply or point me in the right direction for a service sheet for the above amp.
                        Its on the bench, no power, all 3 fuses on main board are intact. no voltages are coming out of the mains tranformer, but it is recieving its input voltages ok, theres a relay in circuit with the transformer that might be my problem, either that or the transformer itself, would love to have the circuit diagram just to see how exactly this operates, many thanks in advance...cheers
                        EDIT, sorry made a typo, its the ARCAM FMJ-A29 i need, not A32, sorry all
                        09-25-2024, 10:59 AM
                      • dobrykamil
                        Arcam AVR 850 question
                        by dobrykamil
                        Hi all
                        Does anyone know, what voltage should be present at a Collector pin of output transistors (NJL3281DG and NJL1302DG)? Arcam calls those two rails +VLIFT and -VLIFT. Sadly, I'm getting from a separate power supply board (large caps and bunch of mosfets) +60V and -35V. Pretty sure, these should have the same value.
                        Thanks in advance.
                        08-12-2024, 03:45 PM
                      • nodols
                        Arcam AVR400 No sound
                        by nodols
                        Bought an Arcam AVR400 FMJ with no sound and no VFD display. I've plugged in to TV and it has display.
                        I've checked the VFD and it's toast, I don't know where to source it so if anybody has suggestions please let me know.
                        However, the main issue really is the No Sound to speakers.
                        I have connected a signal generator to the RCA CD input, and signal stops at the IC101 Renesas R2A15218FP IC. -7V and +7V power supply is there. On this IC101, mute is on pin 51, Clock on pin 50, and Data on pin 49.
                        Pin 51 - mute is logic low (no voltage) so I'm...
                        01-11-2023, 09:50 AM
                      • cbx99
                        EHC Comet Combi 14.4kW – no heat, triac outputs never energise (diagnosed)
                        by cbx99
                        Boiler: EHC Comet Combi 14.4 kW (single phase)
                        Symptom: Display shows heating demand (icons on), pump runs, valves move, flow reading present, but no temperature rise on CH or DHW. Both remain ~ambient even after 30–40 minutes.
                        Electrical measurements (with multimeter)
                        • Incoming to element control board:
                          • Terminal 1 → N(7) = ~240 V
                          • Terminal 3 → N(7) = ~240 V
                          • Terminal 5 → N(7) = ~240 V
                            → Live feed to element power board is present.
                        • Element outputs under demand (heating icon ON):
                          • Terminal 2 → N(7) = 0 V
                          • Terminal 4 → N(7) = 0 V
                          • Terminal 6 → N(7) = 0 V
                        01-29-2026, 10:30 AM
                      • TyMercer
                        Can I flash a working BIOS from one computer to another of the same make, model, etc?
                        by TyMercer
                        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                        11-13-2025, 09:39 PM
