Need schematic example how ISL95855C VRM is wired to SiC631
  • G33RT
    • Oct 2016
    • 69
    • Belgium
    I need a schematic example on how the ISL95855C VRM controller is wired to SiC631 power stages.
    Does someone has a schematic of any kind of laptop that use a ISL95855C and SiC631 Power Stages ?
    Regards, Geert
  • G33RT
    • Oct 2016
    • 69
    • Belgium
    Re: Need schematic example how ISL95855C VRM is wired to SiC631
    I already found one: MSI GF63 9RCX (MS-16R31)
    Regards, Geert
    • Sierr47
      • Jun 2021
      • zapopan
      thanks man, i needed
      • KYBOSH
        Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
        by KYBOSH
        This found its way to my workbench this week.
        The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
        Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
        The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
        This reminded me of the eufy floodlight...
        09-06-2024, 09:09 PM
        RCA WHP141 wireless headphones wired up
        by momaka
        OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
        Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
        As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
        02-22-2023, 06:28 PM
      • jetuaime81
        nacon ps4 wired controller faulty LED and trigger pot
        by jetuaime81
        I have a nacon controller which has some fancy RGB ring (4 RGB LEDs). 3 of 4 leds are not good and I am looking for a replacement. The size I measured is 3mm x 2.5mm and it seems a 3528 led would fit fine, and it's in common anode. But I am not sure what wattage it is. I have attached photos of led and driver ic (ak63rq1 I think).
        Also one of the triggers is malfunctioning sometimes, I don't know what these pots are called. I measured across the 1st and last legs (in circuit) seems to be 1.1kohm pot. I found some xbox controllers have this but they are 10k. Any info?...
        06-05-2024, 08:28 PM
      • Uranium-235
        Think I would need to recap this Sunfire bi-wired amp ?
        by Uranium-235
        Sunfire bi-wired amp. Not sure if it's the 300w version or 600w version
        stored in a cool place. Not turned on for like, 30 years
        I'm worried about the big two after the rectifier. But if anything else catches your eye please speak up
        dried out, obviously not bloated...
        10-13-2021, 06:53 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
