Uni-Sync Model 50
  • Logistics
    • Apr 2007
    • 721
    Uni-Sync Model 50
    Good morning, friends! I saw an old, heat-sink-heavy unit on craigslist yesterday, so I decided to snag it as the owner only wanted $25. He says that one side powers up normally (lights up green), but the other side stays in clipping mode (lights up red). I haven't opened it up, yet. However, I'll post a picture of the guts from another owners unit so you can see what they look like inside. Looks pretty simplistic as it's all single-sided boards and through-hole components. What I am gleaning from my research is the first thing that should be done is the replacement of the large stiffening caps. Could a failure of the stiffening caps on one channel cause that channel to enter clipping mode?
    Anyway, look forward to hearing from you all.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8372
    Before you change things around. Look if all your voltages are there. You can compare the working side with the broken one. Could be anything from a broken solder joint, to a corroded connector, missing voltage, etc.
    • Logistics
      • Apr 2007
      • 721
      Ah! Good point. I don't know why this didn't cross my mind.
      Thanks!
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8372
        Thanks!
        I just looked at some pictures, this isn’t only the clip LED, also the protection one. So you probably could have DC on the output on that side and the protection is on. The nice thing here is you can easily swap one thing from one side to the other side.
        • Logistics
          • Apr 2007
          • 721
          I didn't get to play for more than about 10 minutes today, but when I power the unit on both channels are red, in protection mode, and I hear the relays CLICK. After several minutes I noticed the left channel would erratically cycle back and forth between Green and Red, until it seemed to finally settle a solid Green. The right channel stays in protection mode. I'll dive into it more next week. Sounds like it would be a good idea to re-wet all solder joints.
          • Logistics
            • Apr 2007
            • 721
            Wait a second, which things are you suggesting swapping? This is the behavior of the amp with nothing hooked up to the outputs so.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8372
              First I would go after the interconnects on the boards. Then test if heat or freezing (can of air upside down) does anything. Take the transistors out and check them. I suppose it also could be a bad TO-3 holder. Put a little pressure on the board trying to flex it a little, or a little pressure on components. I suppose you could try to defeat the protect mode… there a various ways to go about it, but I would wanna check why this is in protect mode and if there is dc on the output while it is in protect. The problem is somewhere in the output section of the amp anywhere from the pre drivers to the final drivers. A bad input section does not make the amp go in protection mode. Once you identified suspected components, you can test them from swapping the same part from left to right channel.
              • Logistics
                • Apr 2007
                • 721
                Just out of curiosity, could this behavior also be caused by aging relays?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8372
                  As for the protection relay, NO. The protection relay is normally open. It only closes if all is o.k.
                  Your symptoms would be different. The amp would appear working normal, but yet nothing on the speaker. The problem lies with that channel clip. You got to figure out why that’s coming on.
                  • eccerr0r
                    old X58 triple channel board... memtest86 memory speed?
                    by eccerr0r
                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                    06-28-2025, 09:06 AM
                  • spleenharvester
                    Reverse engineering of 18650 4-channel tester
                    by spleenharvester
                    Hi friends
                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                    05-04-2025, 02:43 AM
                  • mikey5791
                    Help on car amplifier only one channel works
                    by mikey5791
                    Hi all forum members,
                    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                    08-06-2025, 10:36 PM
                  • dicky96
                    Hitachi V19B01922 Channel Tune problem
                    by dicky96
                    Hi Guys
                    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                    He also has an LG TV, so three screens in the bar
                    I installed three Satlink ST-6503 DVB-T Modulators
                    This model https://www.aliexpress.com/item/32916553905.html
                    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                    02-09-2023, 09:20 AM
                  • dicky96
                    American Audio VLP1500 Distorting on one channel
                    by dicky96
                    Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                    Protection and Clip LED are off
                    There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                    I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                    The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                    07-13-2022, 05:25 AM
