Pioneer amplifier A-205 Relay not clicking after a mistake i made
This topic has been answered.
  • CapLeaker
    Leaking Member
    • 8286
    Originally posted by GraphicMan
    shorting the leads gave me 0.4 ~ 0.5 ohms, so it looks like the resistor is off, the unit is about 24 years old but rarely used
    i have already tested q321 outside the pcb and it is good (is not that the regulator u mean?)
    if the the regulator is gone then the resistors cant be a fusible i think, however the resistors really look like normal ones, they dont have the extra while band, what kind of amps should it blow at, i can make a test on the semi good one and see when it will fail with my volt station? i also need to know how to determine them fusible or not when i buy them to make sure, i looked that up and could not find an answer, plz let me know
    attached page 19 from the service manual i have, it is terrible pdf, can u share the one you are looking at? i could not find any other better version, it is the only available one
    thanks guys so much
    Just look at the schematic and trace it. The +15V regulator isn't on this board PA board. Just test the two voltages at the connector...
    You looking at the wrong page 19 again. On the schematic the two resistors are We got the info from looking at it like this:
    • GraphicMan
      • Aug 2018
      • 124
      • Egypt
      thanks a lot , i found the page, is that the part number for the resistor f4r7j ?
      i just got back from the market , the best i could find is 1/8watt 5.6 ohms, i barely found any 1/8 watt version, people also dont know much about fusible resistors, plz confirm the part number and if i can use the 5.6 ohms ones i got or not, ppl here say they use they tiny resistors at that low ohms as fuse anyways but i dont trust their knowledge
      is it possible to make a test on one of them and see if they will burn or not at a specific mA ?
      i already tested at the connector as u know, and there is only -15v, or did u mean to test after replacing the resistors?
      can u plz point out to me where i can find the regulators u mentioned before?
      thanks
      • GraphicMan
        • Aug 2018
        • 124
        • Egypt
        update:
        i just made a test on the original good resistor , i tried to blow it and it did not blow even at past 0.5A (about 2.5v or so) so over 1 watt
        i did the same with the new ones, same performance, nothing happened (they both get hot to the touch at these ratings)
        so i just replaced the 2 resistors, the relay kicked in, the amp worked and produced normal sound, the loundness also worked with its led, i can feel its normal slight effect on sound, so far so good,
        does that mean that the 15v regulator is good? i think it is the one with a small heatsink very close to the mains, plz confirm
        thanks a lot for your help, u guys are brilliant and so good
        • GraphicMan
          • Aug 2018
          • 124
          • Egypt
          btw i did actually test the +15 on the connector and it is still zero with and without connect it to the button panel, always zero, is there any explanation for this?!
          • redwire
            • 3912
            MEASURE the +/-15V rails and see if they are close, to tell if the regulator is still working. I think it's Q321/Q322 etc.
            There is another +15V reg for the LEDs but you said they are working. If you keep getting zero then your multimeter ground might be wrong place?
            • R_J
              • 9579
              If the amp is working the voltage is likely ok, which is "the" connector, or you are checking the wrong pin on "the" connector
              Check connector AKM1037 on Power amp board or (AKP1044 on control ass'y) pin 7 =+15 pin 5 = -15
              The service manual from the Pioneer A-103 is very similar and a bit better quality and easier to follow (but too large to upload here)
              https://elektrotanya.com/pioneer_a-1.../download.html
              • GraphicMan
                • Aug 2018
                • 124
                • Egypt
                #27
                again my bad, i was not connecting the prob properly, too afraid to short next to the gnd pin
                the +15 is there very exact
                thank you again for the much better pdf, that helps a lot (assuming it is the same schematics)
                i really did notice way deeper BASS! after that repair, coz i also did disassemble the pot , it was so scratchy , i even needed to mill a small copper ring with a stick (0.1mm thick) and placed it on the inner carbon resistant ring, the outer was not worn out, so the inner of the left channel was causing the issues, no the loudness switch is much better, the direct which is so big switch is very scratchy , i need to disassemble and clean it, but these switches are really hard to assemble , it is very very complex and delicate, if it gone perhaps the whole amp wont work again, and wont even know what it does to try to replace it
                you guys are really good at what u do, thank you very much for your patience and help, u r a life saver
                • GraphicMan
                  • Aug 2018
                  • 124
                  • Egypt
                  #28
                  btw i am curious to know what class is that model? A or AB or something else?
                  • CapLeaker
                    Leaking Member
                    • 8286
                    It’s a Class AB. No way that thing is Class A.
                    • GraphicMan
                      • Aug 2018
                      • 124
                      • Egypt
                      #30
                      i think u r right, but how did u know?
                      however i did notice that its wattage is not really affected by the signal nor the volume control, it is connected to a power meter, so i can see precisly how much it is drawing
                      i heard the class A is the best in quality but least in energy efficiency, are class A more expensive also?
                      • GraphicMan
                        • Aug 2018
                        • 124
                        • Egypt
                        #31
                        I have a little another issue now
                        for some unknown reason after the assembly i cant get any sound from the left output, i tried everything, swapped the input jacks, swapped the output speakers, but nothing comes from the left side
                        where can i start diagnoses for this? i just want to make sure it is not a serious problem, it also does not seem to be a scratchy knob or a bad switch because nothing at all comes from the left output
                        thanks
                        • GraphicMan
                          • Aug 2018
                          • 124
                          • Egypt
                          #32
                          i found very good continuity from these points to its related speaker out screw sockets from the back
                          hope this narrow things a bit
                          • GraphicMan
                            • Aug 2018
                            • 124
                            • Egypt
                            #33
                            I also tried to use other inputs, CD instead of line in, same issue
                            • GraphicMan
                              • Aug 2018
                              • 124
                              • Egypt
                              #34
                              guys i am stuck
                              is there anyway to narrow where is the issue?
                              can somebody give me some steps to start with? at least to make sure that no rare/expensive parts are the issue
                              waiting
                              • R_J
                                • 9579
                                Start by checking everything you took apart, maybe you damaged a plug or cable during re-assembly
                                • petehall347
                                  • Jan 2015
                                  • 4429
                                  • United Kingdom
                                  #36
                                  right down dirty testing . lick your finger tip and touch where the arrow is pointing . expect a loud hum from test speaker . Click image for larger version
Name:	Screenshot from 2024-05-11 01-58-04.png
                                  • GraphicMan
                                    • Aug 2018
                                    • 124
                                    • Egypt
                                    #37
                                    i have also done that, there was indeed a cable with a single pin not very tight, but it turned out it is not the issue
                                    i am sure the unit was great right before the assembly and i am usually very careful during it, really strange
                                    how about you guide me with tracing to narrow it a little?
                                    thanks
                                    • GraphicMan
                                      • Aug 2018
                                      • 124
                                      • Egypt
                                      #38
                                      i would like to do so but can u plz tell me where is that capture, perhaps the page number or a wider capture, i cant figure out where is that section
                                      thanks
                                      • petehall347
                                        • Jan 2015
                                        • 4429
                                        • United Kingdom
                                        #39
                                        thanks
                                        hope this helps
Name:	Screenshot from 2024-05-11 11-23-00.png
                                        • GraphicMan
                                          • Aug 2018
                                          • 124
                                          • Egypt
                                          #40
                                          hope this helps
                                          yup i actually found it before i read ur post, however i wanted to make sure where it is on the board
                                          attached a screen from the board, where should i short with my wet finger tip?
                                          thanks a lot
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • jason123
                                            Pioneer VSX-523-K Amplifier - Identify resistors
                                            by jason123
                                            Hi folks,
                                            New audio equipment repair and I could use some help.
                                            Picked up VSX-523-K Surround sound amplifer.
                                            Upon power up for the first time (been sitting for a while) loud popping noise and smoke..
                                            Disconnected, opened up and found many popped caps on the amplifier board.
                                            Replaced all, replaced A992 BJT, and pre-amp transistor and power transistor. I found 0.47 Ohm resistors that are blown or have gone High impedance and I'd like to replace.
                                            On the service manual, it shows these as 0R47(2) (assuming this is a 0.47 Ohm, 2W?)...
                                            09-14-2021, 10:16 AM
