KAM KXR1000 amp - one channel in protect mode
  • oddbodd
    • Mar 2013
    • 121
    I've volunteered to have a look at this amp, which belongs to my local club.
    I've brought it home and opened it up. After blowing out loads of dust, there doesn't seem to be anything obviously wrong. No bloated caps etc.
    Channel A is in protect mode. Channel B worked fine at the club. No change, with no speakers or anything plugged in.
    Any pointers?
    Re: KAM KXR1000 amp - one channel in protect mode
    Any good clear pictures so we know what we are dealing with?
    • oddbodd
      • Mar 2013
      • 121
      Here's some I took yesterday. Not brilliant pics, I'm afraid.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Since channel B is working. Compare voltages at the similar points of each channel. Connect a load (speaker) on each channel before turning on the power. I suggest on transistor Collectors and Vcc IC pins. More than likely the problem may be in the Output Stage (ICs or Transistors Shorting)
        • oddbodd
          • Mar 2013
          • 121
          OK, thanks.
          I've now tested the transistors, and found one at T323, which is suspect.
          The readings are:
          - to base and + to emitter = 1732
          - to base and + to collector = 1
          + to base and - to emitter = 704
          + to base and - to collector = 558
          Going by the readings on the other transistors, the - to base and + to emitter reading should be 1, not 1732.
          Does that sound right?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Personally, I prefer to use an analog VOM to test transistors. I would set the VOM on the Rx1K or Rx1000 scale and do my testing.
            First I would remove the transistor out of the cicuit board. If I am to do a quick check I would set my VOM on the Rx1 scale and do an in-circuit check.
            However, removing the transistor under test completely out of the circuit board is best.
              It is 2SD2083 NPN transistor. Checking part when still on the board is not reliable, since it has two channel, you can do comparison readings of the same transistor to see what you get. Each channel has that speaker protection relay (blue rectangular box), listen to see if the dead channel click on or not.
              Did you try contacting them to see if they are willing to send you the diagram/service manual?
              http://www.kam.co.uk/index.php?actio...product_id=103
              • oddbodd
                • Mar 2013
                • 121
                Thanks guys.
                I did compare the readings with the others, and this is the only one that's suspect.
                I'll check that relay, to see if it's switching. I'm also inclined to remove that transistor and test it off board anyway.
                Edit: I've also requested a schematic/service manual.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Originally posted by oddbodd
                  Thanks guys.
                  With amplifiers, if one transistor is bad, usually more are bad. You should test all the others on that same channel, even the ones not on the heatsink.
                  Otherwise, looks like a decent amp!
                  Muh-soggy-knee
                  • oddbodd
                    • Mar 2013
                    • 121
                    The speaker protection relay that budm mentioned, is not switching.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      OK. So the 2SD NPN output transistor is suspect.
                      Then the complemetary 2SA or 2SB PNP output transistor may also have failed.
                      This pair of output transistors would be configured in PUSH-PULL.
                      They are actually Darlington transistors and would test slightly different from a 'normal' transistor.
                      Test the big white resistors also, they may have increased in value or burnt out too. They might be 0.22 Ohms 3 Watt resistors.
                      Yes remove the suspect components from the circuit to test them accurately.
                      Also, test the smaller Driver transistors in the circuit as advised, as they too might have suffered some stress.
                      Remove them from the circuit board for testing and observe their pin positions for re-installing. See if there are any EBC markings on the board's underside and a position drawing on the upperside, to guide you.
                      Test the power Fuses as they should have burnt open to protect the system.
                      Always replace fuses with the same rating.
                        It probably sensing high DC offset voltage at the output so it stays in protection mode. The circuit is direct couple so testing component in the board will not be reliable, they need to be remove. Darlington has such high current gain, it will not take much leakage current in the bad transistor to cause problem.
                        • oddbodd
                          • Mar 2013
                          • 121
                          Thanks for that. Lots to check, now.
                          Fuses appear to be OK.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            or in any stage from the input forward.
                            i would fire it up and measure from ground to the base of each output transistor.the bad one or the one driven by a bad stage will stand out.
                            • oddbodd
                              • Mar 2013
                              • 121
                              Schematic for info.
                              • oddbodd
                                • Mar 2013
                                • 121
                                Has anyone got a service manual for this amp, please?
                                • Poloperson
                                  • Mar 2023
                                  • United Kingdom
                                  Hi, Did you get anywhere looking for a service manual for the amp? I have the same one and I too have some problems I need to look at, so a manual would be really useful.
                                  • oddbodd
                                    • Mar 2013
                                    • 121
                                    Unfortunately not.
                                    • dj8452000
                                      How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                      by dj8452000
                                      I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                      02-18-2025, 08:28 AM
                                    • eccerr0r
                                      old X58 triple channel board... memtest86 memory speed?
                                      by eccerr0r
                                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                      06-28-2025, 09:06 AM
                                    • DynaxSC
                                      Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                                      by DynaxSC
                                      I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                                      I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                                      Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                                      Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                                      05-04-2025, 12:08 PM
                                    • x16
                                      Lenovo Thinkpad T14 gen 1: Unlock MEC: in protect mode
                                      by x16
                                      i have Lenovo Thinkpad T14 gen 1 20S1 / SN: PF2M0XAG.
                                      I moved resistor like every time and read MEC chip with SVOD4. I unlocked 3 other mainboards successfully but this one could not read. SVOD 4 Software says: "MECxxxx series in protect mode, work mass erase only". Like in screenshot.
                                      What can i do?...
                                      11-14-2024, 01:31 PM
                                    • spleenharvester
                                      Reverse engineering of 18650 4-channel tester
                                      by spleenharvester
                                      Hi friends
                                      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                      05-04-2025, 02:43 AM
