Car Headunit (Chinese?) No Sound / Audio
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Just bought a car that has a stereo in, thats bluetooth etc, and powers on fine and all functions seem to work, BUT there is no audio/sound.
    I have tried another unit in the car that works fine, so know it definitely a problem with this unit.
    I know it just cheap rubbish, probably of chinese origin, but its really bugging me just throwing it away and replacing it 🙈🤣
    I know zero about things like this, ans its probably unfixable, or more trouble than its worth, but just wondered if there was anything to check, as what could lead to an easy-ish fix? Havnt opened it up as yet.
    Any help or advice greatly appreciated.
    Pics of the unit attached, although isnt alot to go on unfortunately.
  • petehall347
    • Jan 2015
    • 4431
    • United Kingdom
    push a pin into the reset hole
    • redwire
      • 3912
      not to be confused with the mic hole lol
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Just tried that, did it for 1 second, 30 seconds, 60 seconds.... still no sound
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          I found the right hole 🙈 had rst written near it
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Have you tried doing a basic test of the unit outside the car?
            Connect ground and 12v then some speakers and see how it behaves?
            Oh yea, and tried pressing the mute button and playing with the volume?
            From the manual: each cable can not be grounded, can not be shared, can not touch the line, otherwise there will be no sound output, output sound distortion, machine fever and so on
            Especially important that the machine can have a fever after a long flight: When you receive the product, please do not take it directly to the car for installation. Because the product is in the after a long journey, it may affect the product.
            So if it doesn't work make it a nice cup of hot tea and give it a hot blanket and some bisquits
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              It doesn't need to be a Chinese model or anything else . According to my long experience , it's usually a case of blown speakers , cut and bent speakers wires and even wrong wiring sometimes . Next to those frequent cases , comes primarily the Amplifier sound main chipset , easily blown in many systems due to speakers wiring shortage . Unfortunately , there are no fuses for that . The main amplifying chipset could be one (most of the times) or two , and it's always screwed to the large Alu. sink you see on the device's rear . If you don't have a source of 12 v 10 A. at least , you can always use any computer power supply .. just don't raise the volume too high .
              • Bloopeta
                • Jun 2018
                • 526
                • United Kingdom
                Yeah I have tried it in a different car to eliminate it being the vehicle and speakers etc .
                have also tried a different head unit in the vehicle it came from, and that plays fine.
                • petehall347
                  • Jan 2015
                  • 4431
                  • United Kingdom
                  https://www.youtube.com/watch?v=1JbdWu4g4yo
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    I thought it may be the case of something blown, oh well was worth a try
                    • Bloopeta
                      • Jun 2018
                      • 526
                      • United Kingdom
                      Thats the one, unfortunately Id already been through all the settings etc.
                      Given that video is 5 years old, Id guess that the unit is around that if not older.
                      Was worth a try, to try and get it going since everything else worked, but alas I am beaten lol
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Unfortunately its time for the scrap heap lol, thanks everyone who commented
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          In this place behind the radiator there is an audio frequency power amplifier chip, if it does not heat up (cold) when the device is operating, then just change it, it usually costs TDA7388..
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Not at all, this is the stage where the fun begins.
                            Or put more succinctly by a member of this bard: a working TV? How boring!
                            • redwire
                              • 3912
                              [...] From the manual: each cable can not be grounded, can not be shared, can not touch the line, otherwise there will be no sound output, output sound distortion, machine fever and so on [...]
                              This is referring to the loudspeaker outputs, it uses a bridged amplifier configuration. Grounding any loudspeaker lead will blow the IC. Back in the day some speakers were grounded to the car chassis/door.
                              I'd keep going, take it part look inside. Bad soldering is also a common problem.
                              • Bloopeta
                                • Jun 2018
                                • 526
                                • United Kingdom
                                This is what it looks like from the inside
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  • United Kingdom
                                  I have added a picture of the inside,
                                  • lotas
                                    • Jan 2016
                                    • 4708
                                    • Russia
                                    Unscrew the two bolts, remove the clamping bar and look at its body, it looks like burning underneath, the body may have exploded.
                                    • Bloopeta
                                      • Jun 2018
                                      • 526
                                      • United Kingdom
                                      I have done what you said, and yes it was black underneth.
                                      I had a spare basic Citroen CD player, so I desoldered the part out of that, and soldered it into this unit.
                                      It now has sound
                                      Thankyou very much
                                        • 31154
                                        that chinese unit looks a lot better inside than the italien crap the car makers like to fit!
                                        • Piaskos
                                          Dell Vostro 5490 - no sound, no audio device
                                          by Piaskos
                                          Hi, i've got problem with Dell Vostro 5490.
                                          Board - Mantis CML 18788-1
                                          Windows says "no audio device detected". The other functions work properly.
                                          What i've done:
                                          1. I checked motherboard
                                          2. I changed audio codec (ALC3204)
                                          3. I reflashed bios with clear ME
                                          4. Audio is enable in bios
                                          5. Both speakers are good
                                          6. After installing the drivers from the Dell website, the devices visible in the manager:
                                          - Audio for intel displays
                                          - Intel Smart Sound Technology...
                                          01-30-2023, 02:58 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • JRade
                                          Audio video receiver KENWood KR-V990D,no sound
                                          by JRade
                                          When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                          The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                          I replaced the capacitor C303/0.047F, nothing changes.
                                          I'm asking for help, what should I do next?
                                          Thanks in advance!...
                                          08-05-2025, 10:23 PM
                                        • televizora
                                          HP 8470p - distorted sound and noise when playing audio
                                          by televizora
                                          Hello.
                                          I have an issue with HP 8470p - rather strange one.
                                          I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                                          Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                                          Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                                          12-31-2021, 10:25 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
