Yamaha RX-V359 troubleshooting, turns on and off
  • Jooo
    • Oct 2011
    • 222
    • Finland
    I got this amplifier, it turns on, lcd displays for a second or two and then relay clicks and it turns off. Clearly goes to protection mode.
    I got to diagnostics mode and it says "DC PRT 100% E" which means "DC output of the power amplifier is abnormal." aka overvoltage.
    "Turning on the power without correcting the abnormality
    will cause the protection function to work 3 seconds later
    and the power supply will be shut off."
    Can anyone help me with troubleshooting this? Any common faults in these models? Thanks in advance.
    I have ESR meter, soon two oscilloscopes (just waiting for probes to come in mail) and multimeter ofcourse. Just not too much hands-on experience.
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: Yamaha RX-V359 troubleshooting, turns on and off
    Some pictures.
    And here's link to the service manual:
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      That doesn't mean overvoltage of the power supply, it means DC on speaker output which is likely caused by one or more shorted output transistors. Check those first.
      A working TV? How boring!
        Looks like it uses hybrid modules, but the idea is the same.
        • Jooo
          • Oct 2011
          • 222
          • Finland
          Thank you. There indeed was an short: a tiny piece of wire in the legs of IC101 (STK404-130Y).
          Removing that sadly didn't fix the problem, but the percentage on the error dropped to around 35% (from previous 100%), which means that it says now DC PRT 35% E.
          IC102 and IC103 are Sanyo STK433-130-E.
          I'm not quite sure how to measure those hybrid modules... Haven't played with them before.
          I wonder if the IC101 STK404-130Y is now damaged from having a short in the legs?
            You can measure each of its OUT pins to GND. They should all measure 0V, within 0.5V.
            • Jooo
              • Oct 2011
              • 222
              • Finland
              This is what I measured. The current DC protection value is 40%, which equals 2V according to the service manual. (100% = 5V). And 2V is exactly what I get after STK404-130Y.
              The service manual also says that normal range is 17% to 29% which translates to a voltage of 0.85 to 1.45.
              Did I get it right? If I'm correct, IC101 = STK404-130Y is bad.
              Then another question, are STK404-130 or STK404-130S the same parts, can I use them as replacement? I assume that Y could just mean that it is for Yamaha, but then again I'm not 100% sure.
                Obviously, this Yamaha is a lot more tolerant than I would expect, normally 1V on speaker outputs would be considered a failure.
                It does look like that IC could be bad but first check for any bias adjustment pots (potentiometers) which may allow adjustment of the zero point.
                • Jooo
                  • Oct 2011
                  • 222
                  • Finland
                  I couldn't find any potentiometers. Is there any other way to adjust it? DC protection value was last time I checked 34%, which means it is only 0.25V over the maximum limit.
                  Any clue if I can use STK404-130 or STK404-130S for replacement of the STK404-130Y?
                    I looked at the schematic, and I don't see a way. I'd guess the only thing you can do is replace it.
                    As long as you replace it with a part which has identical pin out and identical or closely matched parameters, it should be fine.
                    • Jooo
                      • Oct 2011
                      • 222
                      • Finland
                      Thank you. Ordered one of those STK404-130S. They seem to be the same to me. I found this which finally convinced me: "Drop in compatible with the entire series of STK404 IC's from Sanyo." I hope it is true. I will let you know how it goes.
                        -130 suffix indicates maximum output power of 130W. You could use a -150, for example, which has a maximum 150W output. It won't make the amp louder on that channel, because it's not designed to use the additional power capability.
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          I don't know about your particular unit but there are a lot of counterfeit STK modules out there. If it burns out quickly again, keep that in mind.
                          sigpicThe Sky Is Falling
                          • Jooo
                            • Oct 2011
                            • 222
                            • Finland
                            I received the new IC today and soldered it in, unfortunately that did not fix the problem
                            It does exactly the same and there is still 2 volts after the IC... Any suggestions?
                              Do the input pins read 2V too?
                              • Jooo
                                • Oct 2011
                                • 222
                                • Finland
                                So this is what I measured:
                                Pin 1: 0,4V
                                Pin 2: 0V
                                Pin 3: 1V
                                Pin 4: 2V
                                Pin 5: 0V
                                Pin 6: 0,6V
                                Pin 7: 12V
                                Pin 8: 3,1V
                                Pin 9: 0,9V
                                Pin 10: -52,3V
                                Pin 11: 52,3V
                                Pin 12: 2V
                                Pin 13: 2V
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  Pin 1: 0,4V
                                  Pin 2: 0V
                                  Pin 3: 1V
                                  Pin 4: 2V
                                  Pin 5: 0V
                                  Pin 6: 0,6V
                                  Pin 7: 12V
                                  Pin 8: 3,1V
                                  Pin 9: 0,9V
                                  Pin 10: -52,3V
                                  Pin 11: 52,3V
                                  Pin 12: 2V
                                  Pin 13: 2V
                                  I would expect pin 6 to have a much higher voltage. Check for a resistor applying rail voltage to it.
                                  • Longbow
                                    • Jun 2011
                                    • 623
                                    Input pins 3 and 4 should not have any d.c. voltage on them. Pin 6 is missing the -49 volts (check Q109 and R144. Pin 8 is high. Check Q106 and R119. Is it possible that traces cracked during IC replacement? Assume that the stray piece of wire took out a number of other parts, which are directly connected to the output IC.
                                    Is it plugged in?
                                    • Jooo
                                      • Oct 2011
                                      • 222
                                      • Finland
                                      Thank you for your message.
                                      - Q109 seems bad, ordered a replacement for that
                                      - R144 is open, ordered a replacement
                                      - Q106 is ok
                                      - R119 is ok
                                      Replacing the IC went smoothly. The traces are still good.
                                      I will let you know how it goes when the new parts arrive.
                                      • Longbow
                                        • Jun 2011
                                        • 623
                                        A faulty Q109 accounts for the missing -49 volts. A missing 1.2 volts on pin 8 might be caused by missing +48 from Q108/R133. Q106 serves as the 1.2 volt regulator.
                                        Is it plugged in?
                                        • Sinnyone
                                          Yamaha RX-V3900 dim display and turns off
                                          by Sinnyone
                                          This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
                                          I have searched through the forums and have not found anything about my problem. So,...
                                          08-30-2023, 08:35 AM
                                        • jason123
                                          Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                          by jason123
                                          Hi there,
                                          I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                          So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                          I see 2 posts that are relevant:
                                          https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                          https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                          10-29-2025, 02:01 PM
                                        • roadrash
                                          Yamaha HTA-5630RDS Amplifier dead
                                          by roadrash
                                          Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
                                          12-12-2024, 10:19 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
