Yamaha RX-V3900 dim display and turns off
  • Sinnyone
    • Feb 2022
    • 12
    This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
    I have searched through the forums and have not found anything about my problem. So, without further ado, my problem is a dim display on the receiver. I have tried adjusting the display brightness in the GUI menu, but it stays at, i would guess, 50%. I have read online that Yamaha is famous for placing caps too near a heat source and the caps prematurely go bad, or just bad caps. I have worked on pcbs quite a lot and have confidence that I can change any caps that might be bad, however, I have no idea where to find the caps to replace. I do have the service manual for that receiver, but i said I like to tinker, not learn another language. LOL. If someone could point me in the right direction, I can order like replacement caps and remove the old ones and install the news ones. Any help would be greatly appreciated. Thank you
    I have a Yamaha RX-V3900 that has been working fine, except with dim display, for a few years now. a few days ago, it powered down for no reason. I turned it off, unplugged, restarted it and it worked fine for about a week. Yesterday, it did it again, but would not stay on. It would power up, then turn off. After a couple of tries it would do nothing until i unplugged it and tried it again. Again, power on then off. I found a service manual and tried the self diagnostic function. using the buttons, i can get it to turn on, stay on and go into self-diagnostic mode, but it wouldnt show any codes. According to the manual, it should show "Diagnostic No Protect". It seems stuck at the main "Diagnostic RX-V3900". It will not show any codes or history. Also, now, it wont even stay on in Diagnostic mode. It shows power on then turns off. Wont stay on in protected mode. Does that sound like an issue with the power supply? Its a really nice receiver, plenty of power for my vegas, so Id like to keep it and fix it if I can. Im pretty handy with electronics and soldering so Im not afraid to play with it.
    So I was searching around and found out a bit of info. I guess a common problems with this era of receiver is a faulty or failing cap on the power board coming in from the power cord. I took the board out but dont see any leakage, but these arent electrolytic ones, they are the polyester ones. Those dont leak do they? I think it is supposed to be the one circled in the picture. Anyone have any input? Also, i do have a meter with microfarad. Can I check with that? or are these in a lower capacitance? thanks
    Jim
  • sanalelevenstar
    Yamaha RX-V485 receiver. After encountering a "version error"
    by sanalelevenstar
    I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
    After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
    I managed to find the service...
    09-10-2025, 01:54 AM
    Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
    Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
    various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
    Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
    trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
    what is wrong with your PC in just seconds. It saves you time and money.
    Our new and improved design...
    11-01-2024, 06:29 AM
  • Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
    by Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
    03-15-2024, 09:37 AM
  • alfredomfr1
    YAMAHA AV Receiver RX-V585 No Power
    by alfredomfr1
    120v ok, No voltage on the connectors, Fuses OK, 165v DC on the main capacitor...
    09-12-2023, 09:47 AM
  • www
    LG L192WS-BN backlight turns off after 1 second
    by www
    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
    03-24-2024, 05:26 PM
