I have a DJ mixer main who's main psu died. I order a new one but its not the exact same. The old power supply has 2 leads going to the power plug which is mounted to the chassis and a connection for the on/off switch. The new power supply had the actual 3 prong socket for the the plug and doesn't have the connection for the on/off switch. I desoldered the 2 leads from the old psu and soldered it to the new psu. The mixer now powers up but has no on/off switch connection. My question is can I just attach the 2 lead on/off switch to the live lead on the psu? If so, will there be any noise introduced?
Power Supply Replacement Issue
Tags: None
Re: Power Supply Replacement Issue
Can we see the pictures? You just feed one terminal of the power switch with the wire for the LINE (HOT), the other terminal of the power switch will be connected to the LINE (HOT) in of the power supply. It will not cause any noise problem if the switch's contacts are good and not arcing.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I have the power supply in the garage I'll post pictures tomorrow. I will disconnect the hot lead from the 3 prong plug and cut it in half and connect one end of switch to psu and the other end to 3 prong plug?Comment
Assuming...7 Photos -
by grimacelordHello,
I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need.... -
by r2digitalI have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...2 Photos
by KYBOSHI have a floodlight-security camera that recently died on me.
its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the... -
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... - Loading...
