Yamaha RX-V450 -- Dead
    £20 on eBay for this nice 6.1 channel Yamaha amplifier. Rated at 0.02% THD+N at 100W output; 350W maximum output power across all channels. Despite the ".1", it doesn't actually have a built in subwoofer amplifier. It does have a line-level sub output. It also uses one less far-rear speaker, so it's only got 6 surround channels.
    After I saw Dave Jones' (EEVblog) video on this amp, I had a look around eBay and saw there was a plentiful supply of this amplifier or its cousins going faulty on eBay. Picked one up for £20, plus another £10 got three half-decent speakers plus a subwoofer+amp (Combined unit; I'll post pictures of it in another thread.)
    The fault is that the amplifier is completely dead or will only power up intermittently. And the cause? A single poly capacitor worth about £0.50. I just blasted this cap with a little freeze spray and it fired right up complete with functioning sound on the FM tuner.
    This amplifier uses a rather novel, but somewhat complex energy saving standby circuit. It uses a real mains transformer, but switches it on and off a few times a second depending on load -- a sort of proto-switching power supply. It manages 0.2W standby power by doing that, whilst satisfying audiophiles (because it doesn't use a real switching power supply.)
    The poly capacitor supplies the power to a D-type flip flop which latches the transformer on for a few cycles about three times a second using a FET and bridge rectifier. It also powers an optocoupler which tells the CPU if the AC line is present. When the poly cap falls in capacitance (typical failure mode due to self-healing from mains spikes), the voltage across the optocoupler drops, the signal goes away, and the CPU switches off the amp completely (no sign of life at all -- no standby light, no clicks from the relay...)
    Now, this amplifier basically only fails in 230V markets. It's perfectly reliable when used on 115V (if it is rated for 115V of course.) Try and think why it might matter...
    It's a Christmas present for my dad to accompany the 50" plasma (also one I repaired.)
    Re: Yamaha RX-V450 -- Dead
    My error. It's C405; the red cap near the top of the PSU, not that large green one.
      It's fixed now. I bodged a much larger WIMA capacitor in...
      The original, failed cap read 6.5nF instead of 22nF.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Very weird standby supply circuit.
        If this was just a plain old transformer, then hundreds of these units would still be in operation...
        Muh-soggy-knee
          Yeah, but simple transformers have been banned by the EU, because they use too much in standby. Silly law, probably causes more waste than it stopped... but it looks good from a political standpoint.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            I sure didn't know about that!!!
            //begin rant
            What a lame law... iron core transformers are usually capable of >95% efficiency!
            Instead, they should ban CFL's and their spike making, energy-meter fooling madness!!!
            //end rant
            Muh-soggy-knee
              Transformers are really efficient -- but only when loaded significantly. When unloaded, they are essentially drawing a couple of watts continously. Look up magnetising current. Iron-core transformers are banned except for AC-AC supplies (which are in continuous use) i.e. wall warts. Due to the ban on AC-DC supplies, the price of AC-AC supplies has increased significantly making them less cost effective. You are still allowed to use a transformer in your audio amplifier, but the standby power must be less than 1W unless it offers some kind of timer or recording feature, in which case the limit is a generous 2W.
              CFLs are fine, but the current cost cutting annoys me, because they sure don't last 15,000 hours like they claim. Usually the main primary electrolytic cap fails. It should be possible to design a lamp which doesn't use one of those. I designed a self-oscillating current-controlled LED power supply which uses NO electrolytic caps; the output flickers at 100Hz, but so do filament bulbs, so no-one notices. It's also got 0.9 PF and short circuit/open circuit protection.
                Forgot to include the diagnosis video and to say it's fixed now.
                https://www.youtube.com/watch?v=efRnYAcT7us
                • turbozutek
                  • Jan 2009
                  • 71
                  Great work and a good price for such a meaty looking amp!!
                  /Not sure about the Jamcon 1uf start cap though
                  Chris...
                    Everything else is good caps. Jamicon seem to be fine for general purpose, though I admit it's probably saving less than a cent and the rest are quality caps, it seems strange.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      A local repair guy told me that even mains rated capacitors used to replace the 22nf eventually fail also. I dont know the brand of capacitor, only that it is 275VAC.
                        I used a 1250V rated cap, I think it will be OK.
                        • Daf66
                          • Dec 2013
                          • Belgium
                          Yeah, I was really happy with the amplifier, but i fear its a dead cap in mine too. I know my way around soldering, but how to see if it really is this capacitor? Freeze spray is unknown to me.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            have you got any air duster the type used to clean pcs etc if so you can turn the can upside down and use that as freeze spray it does work and is a lot cheaper to buy imo.
                            • Xenon-Codex
                              • 186
                              • Finland
                              Thanks for this info, my brother came with this amp, totally dead. Just replace the cap and it works again.
                              • roadrash
                                Yamaha HTA-5630RDS Amplifier dead
                                by roadrash
                                Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
                                12-12-2024, 10:19 AM
                              • double_DD
                                How can I be sure that my EC chip is dead?
                                by double_DD
                                As the title suggests, how can I be sure that my EC chip is really dead?
                                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                03-12-2025, 07:47 AM
                              • hemant_2222
                                Yamaha RX-A1020 full dead
                                by hemant_2222
                                Hello Everyone,
                                Greetings!
                                It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
                                09-14-2024, 11:25 AM
                              • Nevillet
                                Yamaha A-520 HiFi amplifier
                                by Nevillet
                                Hi All,
                                I have a Yamaha A-520 that has no sound output.
                                I notice after power up the protection protection relay does not click in.
                                I'd appreciate any pointers on where to start.
                                Many thanks.
                                Service Manual below:
                                https://www.badcaps.net/forum/attach...1&d=1641841819...
                                01-10-2022, 01:11 PM
                              • disorder
                                ps5 edm-033 dead after hdmi/usb ports destroyed
                                by disorder
                                hello guys,
                                i need help to repair a edm-033 ps2
                                history : as always hdmi port and usb ports destroyed after unplugged
                                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                so i changed it
                                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                i don't see any projection of liquid metal on pcb.
                                01-14-2025, 12:48 PM
