Altec Lansing iMT320, badcaps!
  • gilly1984
    • 751
    Well, when trying to switch this on it just buzzes whilst your finger is on the power button.
    I open it up and this is what i find. How on earth do they blow in such a low powered device?
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Altec Lansing iMT320, badcaps!
    1) It could be cheap 85C caps.
    2) Is this powered by an external AC adapter? If it is, that adapter could have bad caps in it.
    --- begin sig file ---
    --- end sig file ---
    • gilly1984
      • 751
      It came without an adapter, i tried it with battery's.
      Got it with a bag of docks, all faulty.
      Mostly smd components too so gonna be a struggle for me.
        Hmm, maybe the board's been crushed somehow? Doesn't look like they are just bulged - they are seriously deformed from external force.
        • gilly1984
          • 751
          I thought that too Tom. I think its a design flaw. just put it back together and looks like the battery compartment crushes them.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            There also appears to be some corrosion on the board to the left of the ferrite beads right under the bulged caps. Not sure if this could have been caused by the electrolyte from the caps or if something spilled on the board. Probably wouldn't be a bad idea to clean that off too.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              It might be because they're Lelons.
              That was common with smaller Lelon caps on slot-1 era boards, based on what I saw here.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • prfma
                • Mar 2013
                • usa
                How can I open the IMT320 to check the caps I have the same buzzing noise, I remove the 4 bolts on the bottom but it is very tight to open, don't know thre trick.
                • gilly1984
                  • 751
                  its a pain in the bum. got to remove the leather case thing. its stuck down with glue.
                  • stewart710
                    • Jun 2006
                    • 42
                    To anyone else reading this, there are also ten screw hidden under the faux-speaker-mesh on the front. You have to peel that up to get them out too. Mine is an IMT325, same layout. No bulging caps in mine, but it won't charge ipods or play through the speaker, unless its a really old ipod w/out speaker, then it plays very softly. Aux input doesnt work either. Power light comes on.
                    • stewart710
                      • Jun 2006
                      • 42
                      8 screws actually, not 10.
                      • SumyunGuy
                        • Jan 2015
                        I have 10 silver screws (6 under the speaker screen, 4 at the bottom under the pleather portion), 2 small screws by the batteries and 3 screws holding the bottom pleather to the unit.
                        I did plug in the wrong AC plug and that's when the buzzing started. Batteries do the same thing so I'm wondering if it's the two small caps/diode looking things at the bottom that is stopping power from getting to the larger caps? Ideas?
                        • yuzupatogik
                          Help with replacing Capacitors on Altec Lansing ATP 3
                          by yuzupatogik
                          I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                          I can't find datasheets for the Samxon in any of the following variants:
                          10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                          02-14-2025, 04:11 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • EvazX
                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                          by EvazX
                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                          However, after some time, the replacement motherboard...
                          Yesterday, 06:09 PM
                          ASUS VivoBook P541NA Notebook Max Specification for Upgrade or Repair
                          This specification for the ASUS VivoBook P541NA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P541NA boardview and P541NA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS VivoBook...
                          09-06-2024, 08:00 AM
                          ASUS ASUSPRO PU551LD-CN042G Notebook PU Specification for Upgrade or Repair
                          This specification for the ASUS ASUSPRO PU551LD-CN042G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PU551LD-CN042G boardview and PU551LD-CN042G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 06:20 AM
