Focusrite Saffire Pro 40 re-cap
  • PhilippHoeger
    • 20
    Re: Focusrite Saffire Pro 40 re-cap
    right, could be a problem. narrow to wide adaption will be a little bit annoying.
    are you sure with your original 470uF Vcom filter caps? mine has 47uF/16V in it.
    All the others caps are the same in the 56
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Yeah, i'm pretty sure about that. These would be the four 8mm diameter caps, in-between the 5 ADC/DAC chips, in the middle of my Pro 40 board (see the pic in the first post). I doubt 47u/16v would be so "fat" The 47u/16v are usually 5mm, or 6.3mm diameter, max
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • PhilippHoeger
        • 20
        interesting.
        I even thought you accidentally interchanged Filt+ and Vcom because this is what the Saffire 56 got there:
        Filt+ filter caps for the codecs : 47uF 16V
        Vcom filter caps for the codecs: tiny blue 10uF 16V
        • Khron
          • Sep 2006
          • 1350
          • Finland
          My guess is they got designed at different points in time, hence the possible different component value choices
          PS: What's the model of that square chip near the ADAT i/o? And is that black rectangular device near the S/PDIF i/o a relay, or what?
          • PhilippHoeger
            • 20
            chip is a DSPB56374AF and yes it's a relay.
            here's a picture of the preamp board. All in all, a total of 144 capacitors and 48 opamps.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #26
              Aha, that must be handling the "liquid" channels then. Thanks for the info
              I really wish the 40 had a 2nd ADAT i/o, though
              • PhilippHoeger
                • 20
                what are you using the ADAT i/o for?
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #28
                  I'm planning an "extension" with, in my case, 4 other mic preamps. It'd be nice to have two ADAT in's, for an extra 8x96k
                  • PhilippHoeger
                    • 20
                    Just finished my PSU and decoupling update and tested it a acoustically treated studio surrounding.
                    I expected to find a subtle improvement in sound, but man this is HUGE!
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #30
                      Difference in the outputs? Or have you finished re-capping the analog input board as well?
                      • PhilippHoeger
                        • 20
                        Yes. Only a few caps left to do now .. a day of work.
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          #32
                          I'd really like to get a (close) look inside an OctoPre Mk.II Dynamic, though
                          • PhilippHoeger
                            • 20
                            OctpPre is a really nice unit too! Had it but sold it because I didnt need that much inputs anylonger.
                            Here's my conclusion after changing all caps:
                            Overall it improved the saffire enormous.
                            I found changing the input cap didn't make a huge difference. To me the mids got cleaner and more defined on the inputs. But I will measure this in addition later.
                            Since I did the recap stepwise to compare it directly, I was really impressed how the sound improved after changing the power supply caps on PSU and on the mainboard inputs.
                            Strangely after this step my very normal software bug with the mixControl disappeared!
                            (I had to switch syncSource to ADAT or Word Clock and back to Internal to get an output after turning it on.)
                            Maybe there was a bigger problem with the power supply here?!
                            For now I am waiting for some LM4562 i found fairly cheap hoping they will fit the wide body pining in the saffire
                            • lti
                              • May 2011
                              • 2557
                              I think the old caps might have been bad. Replacing good caps wouldn't have caused that much of a change in sound quality.
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                #35
                                4562's are in narrow SOIC, so... Good luck
                                About the OctoPre, i was / am mostly interested in the "Dynamic" part of things, ie. the compression The plain one should be pretty straightforward, 8 pre's and some ADC's, plus an ADAT converter or two...
                                • PhilippHoeger
                                  • 20
                                  they do fit. no problem at all. seems the board was designed for both sizes cause the pins soldering surfaces are long.
                                  finished one preamp using the lm4562 compared it to the stock njm2122 preamp.
                                  difference is obvious. the 4562 really shines. slightly more output and MUCH less noise. the 2122 sounds covered and thin. hard to describe but 4562 is worth its dollar
                                  so I'm gonna get a lot of these and change them.
                                  • PhilippHoeger
                                    • 20
                                    Additionally: I hate soldering smd.
                                    how do you desolder these little chips in between all the caps?!?
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      #38
                                      Hot air station Got one from China (fleaBay) about a year and a half ago, it was ~60eu including customs and whatnot... and it already more than paid for itself
                                      Soldering's easy, especially for SOICs
                                      Before you mod all the channels, try leaving a 2122 in place, and just changing the other opamps around it (are they 4565's in the 56 as well?). I'm curious which parts have what effects
                                      • PhilippHoeger
                                        • 20
                                        yes, 2122 on each preamps. after that 3x4565 on the liquids and 2x4565 on the 6 other inputs.
                                        then there are 21 (?!dont understand why and how) 4565 for the 10 outputs.
                                        SIP NJM4556 for headphones. These sound very good to me. is there a good replacement?!
                                        first smd soldering for me. but it worked
                                        • PhilippHoeger
                                          • 20
                                          changing the 2122 made the biggest improvement. replacing the 4565 enhanced it furthermore, but wasn't a big step up as the 2122.
                                          I made some speaking samples with a mic to compare it after all.
                                          • Momo_the_duck
                                            Schematic for Focusrite Scarlett 2i2 3rd Gen
                                            by Momo_the_duck
                                            Hello!
                                            New here. I just bought a broken Focusrite to begin my journey in repairing stuff.
                                            I would like the schematic for the Focusrite Scarlett 2i2 3rd Gen audio interface.
                                            Thanks in advance if anyone answers!
                                            09-01-2025, 10:03 AM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                            no-name Radeon 9600 XT recap and cooler
                                            by momaka
                                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                            This one was actually suggested to me by ChaosLegionnaire....
                                            11-06-2020, 07:54 PM
                                          • varunviolin007
                                            Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                            by varunviolin007
                                            Hi guys,
                                            I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                            I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                            Looking for someone experienced with older PC boards who uses...
                                            07-29-2025, 11:53 PM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
