Focusrite Saffire Pro 40 re-cap
  • canonball
    replied
    Hello, Like many of you, I now have a dead Saffire Pro 40 power supply. I am hoping someone may be able to provide a little information for me. On the back of the board, R17, R18, R19 and R20 are 100% bad. I think U1 (LD7537), R9, R11 and Q1 (cs8n60f) are also bad. I am planning to replace all of these items along with all of the capacitors. Are there any other items that should be replaced? I don't have the tools or know how to test components at this level.
    Thanks for any advice you may have.
  • SolderFumes
    replied
    I just recapped the power supply for one of my Pro40's.
    I thought it would be a good idea to test the power supply before connecting it to the mainboard. I have read that these switch mode power supplies need to have a proper load on each of the rails for them to work correctly and/or to prevent damage. The problem I am having is determining the correct load resistors to use. There are 4 rails: 5V, 15V, -15V and 51V. I know that the whole Pro40 draws 12.3 Watts or .17 Amps.
    If I understand correctly (there's a good chance I don't!) Ohm's law would say the load of the whole interface is (R=V/I) 119.9V/.17A = 705Ω, but that doesn't really help me figure out the load for the 4 power supply rails.
    The 51V rail is likely for the phantom power. Assuming a max current draw of 14mA, could I use Ohm's law to here? If so, it seems a 3.5KΩ/.5W resistor should work. But what about the 5V and +/-15V rails? Does anyone know how I could figure this out?
    Thanks​
  • b0bster
    replied
    Another board, my second one with the exact same issue as a few of the posts above. Can't seem to get a replacement this time. :/
  • saffire
    replied
    Re: Focusrite Saffire Pro 40 re-cap
    Originally posted by panthera86
    Hi newbie here! First time poster:
    Can this PSU board of my beloved Liquid 56 be resurrected
    It's toast, unfortunately, or do I have to order a new PSU?
    Did you managed to get a replacement psu and if so did that work?
    I have exactly the same problem with my saffire pro 40, exectly the same pattern of frying ;D
  • JoaoSalles
    replied
    Originally posted by Shteff
    U1 is a LeadTrend part on the one i have here for repair, markings are JP 35 but i can't find it exactly.... LD7535 is the exact part.
    LD7535ABL is P1 35,
    LD7535BL is YP 35,
    and more QP 35, WP 35, S1 35, XP 35A, G1 35, and so on.
    but i can't find JP 35 anywhere, it is for sure LeadTrend LD7535 part. i might change it for a P1 35 and see what happens.
    I'm also looking for this U1, could I find a component that can replace it? I can't find this JP35
  • JoaoSalles
    replied
    Hi, did you manage to solve it? I have the same problem!
    Originally posted by Khron
    Finally got around to taking the top off one of my Saffire 40's, so here's a hopefully-clear-enough photo of the bottom.
    Since all those resistors are toasted on yours, there's a pretty good chance the MOSFET is also gone, as is the PWM controller.
    No idea what the stock PWM controller was, but as i mentioned, i managed to find a nearly-pin-compatible one, in the Diodes Incorporated AP3105NAKTR-G1.
    The photo seems to be from the other Saffire 40's power supply which was ok. If memory serves, in the first one, with the new PWM controller, i removed the 100K R12.
    I can't find another one to replace this U1, I searched on google and there is no datasheet talking about this U1 (VP35)
    Originally posted by bfpgio
    Here it is cleaned
    what is written on that U1? Mine was damaged and I can't read what it says
    Last edited by SMDFlea; 05-15-2023, 02:39 PM. Reason: Merged three seperate posts into one
  • panthera86
    replied
  • прямо
    replied
    I got this lovely and versatile audio interface a couple years back, for some multitrack recording with my (former) band, and as a "foundation" for my (future?) home-studio.
    A while back, i decided to "pop the hood" and check out the insides. The PSU made me cringe - C(r)apXon It puts out 5v for the digital/logic stuff, +/-15v for the analog stages, and 51v for the phantom-power. I haven't yet replaced the mains filter cap (since i figured it's not under THAT much strain, plus i don't have a suitably-sized one in stock... for now ).
    Well, you can't blame Focusrite. Everything that is made in China these days has to use parts that are also made in China, unless requested specifically by who ordered the production. It's one of them govt's rules.
    With that being said, I wasn't surprised at all when I peeked inside Liquid Saffire 56 to find ChangXin caps in the audio path and in the PSU section.
    What surprised me is when I had to service a $4000 SSL channel strip rack unit 5 years ago. For power, they use a cheap low quality switching PSU that cost $1 a piece if you buy in bulk (which they did of course), and they put a price tag of 150 pounds before tax and shipping for it on their online store. What a rip off!
    I revived the mic pre by replacing the blown out fuse and PWM IC (it's a TOP PWM IC, I forgot the series but it has a TO-2XX transistor package if I'm not mistaken), also recapped it with Chemicon KY. Took 3 days to disassemble and assemble including a 24 hour test period in which I abused the thing just to see if the PSU would hold up in performance and stability. I charged $75 for service labor and parts, which the client happily paid me. The preamp is still running to this day.
  • redwire
    replied
    The small cap C5? is most important. It's 10-22uF 50V I am guessing.
    Be careful to discharge ALL the capacitors before plugging in the connector.
    Focusrite PSUI001007 Power Supply PCB for Scarlett 18i20, Saffire, OctoPre MkII, RedNet 1. Gee it's got cheap electrolytic capacitors used in it.
  • pcperez72
    replied
    Hi.
    I decided to post here because it's about Focusrite PSU.
    I own 4 octopres MKII. They remained unused for a year. This week I had a recording gig and took them to do it. Out of 4, two units presented the same problem when turned on. The clock front panel remained dead with all LEDs unlit. No word clock out or in.
    What I found is that the PSU might be the origin of the problem. I disconected the 5v supply cable from the main board and checked with a multimeter. I found that the 51v pin measured around 58v steady, but the other voltages were varying all over the place. The 15v and -15v went from 12.1 to 13.4, back to 12 and started all over again. The 5v pin went from 0 to 2.5 to 3.2 to 4v back to 0 and so on.
    I think this is not normal and should get all the voltages steady as the 51v pin, tough it's a little higher, 58.2v.
    I thought some capacitor was the cause and changed all the electrolytics after the transformer secondary. I replaced the caps with the same value but not with the same voltages for all of them. Regarding the 470uf caps, 3 are 63v, one is 50v and the other is 16v. The 2200uf is 16v and the other 100uf are 100v as the originals.
    All replaced, nothing changed.
    So I checked all resistors in the back and all are ok.
    Regarding the ICs and transistor, I have only checked the Mosfet which seems to be ok.
    So my question is... what might be the origin of the problem? I believe this varying voltages are not normal and this is the reason why the clock panel does not light.
    Thanks in advance.
  • Khron
    replied
    The part i used isn't "the only hope", it just happened to be the cheapest pin-compatible device that one of my preferred suppliers had in stock at the time. And since i couldn't know what the stock part was, it was a bit of a crapshoot, but it worked.
  • Shteff
    replied
    yea, main issue now is the part is only available in china so maybe the AP3105NAKTR-G1 is our only hope, or the new PSU fullcompas sells. idk
    if i find a decent supplier and i don't forget, i'll post it here
  • Khron
    replied
    Markings are on page 2 of the datasheet. First letter is the week code, while the "P 35" indicates the part number, looks like.
    The -A version seems to be spec'd for only 21V for the overvoltage protection trip point, while the non-A is rated for up to 28V. Installing an -A could be pushing your luck for no good reason.
  • Khron
    replied
    Thanks for the update. Assuming one can find a datasheet for that chip, i would expect the differences (if any) to be somewhat visible.
  • Shteff
    replied
    LD7535ABL is P1 35,
    LD7535BL is YP 35,
  • bfpgio
    replied
    Thank you
  • Khron
    replied
  • bfpgio
    replied
    allright let me know the list of component, I could also simply change a maximum number of them all arround
  • Khron
    replied
    Well, you're somewhat in luck. I do actually have two Saffire Pro 40's that i need to put up for sale, so i suppose i could take a look under one of the power supplies in the mean time.
    But until then, determining what was the root-cause of the damage would be very useful, and so would figuring out which components are blown. You can bet your life those resistors are NOT the only things that let the smoke out.
    One of these two Saffires i have, turned out to have a faulty PWM controller in the power supply - the feedback side of it was wonky, so the output voltages were about twice what they should have been. I have no idea what the stock chip was, but replacing it with a pin-compatible one (and removing a now-unused resistor) cured that.
    Considering that group of four parallel current-sense resistors is that well toasted, is a safe bet that the MOSFET is now just a wire, ie. shorted drain-to-source, at the very least. Probably blew the gate as well, going by the seemingly cooked 10 ohm resistor (marking "100" in the last photo), which likely killed the PWM controller as well.
    There's gonna be quite a bit of measuring to do, before drawing up a list of parts that need replacing...
  • bfpgio
    replied
    Originally posted by khron
    first of all, clean off the soot (black stuff) from the bottom of the board.
    Here it is cleaned
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
    no-name Radeon 9600 XT recap and cooler
    by momaka
    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
    This one was actually suggested to me by ChaosLegionnaire....
    11-06-2020, 07:54 PM
  • varunviolin007
    Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
    by varunviolin007
    Hi guys,
    I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
    I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
    Looking for someone experienced with older PC boards who uses...
    07-29-2025, 11:53 PM
  • Foetuss
    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
    by Foetuss
    Hi all
    Hope this is in the correct place.
    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
    Could use some double checking to see if I'm not doing something stupid .
    Pictures of the boards are attached.
    What I will be replacing with what : (planned)
    Soltek Golden ::
    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
    01-18-2025, 11:44 AM
  • speggio91
    Focusrite Scarlett Solo 3rd Gen component identification
    by speggio91
    I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
    From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
    Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633...
    12-04-2024, 04:00 PM
