Focusrite Saffire Pro 40 re-cap
  • Khron
    • Sep 2006
    • 1350
    • Finland
    #61
    Re: Focusrite Saffire Pro 40 re-cap
    What exact chip might that be? I can make out the [BB] Burr-Brown logo, and "PCM", but no numbers.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Khron
      • Sep 2006
      • 1350
      • Finland
      #62
      Nevermind, a bit of squinting, and the flexible search engine from alldatasheet.com revealed that it's a PCM3168A.
      https://cdn.badcaps-static.com/pdfs/...787658228e.pdf
      Page 8 shows the pinout - those caps that are close to the chip itself seem to be only filtering the power supply rails and the various reference voltages that the chip generates / needs.
      To get to the signal coupling caps, you'd have to trace the signal lines. The outputs seem to be quite clear (the pairs of traces leaving the chip, on the left side); the inputs might be a bit trickeir, they're on the opposite (right) edge. C20-23 (ceramics) seem to be, most likely, anti-RFI (ie. between the input lines and ground, or between the (balanced) input lines themselves).
      • aaronrash
        • Feb 2014
        • 6
        Awesome, so what would you replace those 10uF/16V caps with? I am guessing they are decoupling caps for the AD/DA chip?
        I was thinking of changing to maybe 47uF/16V
        • Khron
          • Sep 2006
          • 1350
          • Finland
          #64
          That should be fine, extra filtering on those power rails definitely can't hurt. I'm just not sure if/how audible that might be
          • aaronrash
            • Feb 2014
            • 6
            Ok so my first attempt at replacing my op amps went horrid. The SMD station got the Op Amps out with no problem but the tip on my solder iron was way to big for the job and ruined all the pads on the first and second channel. The only way to recover at this point would be to trace where the damaged pads go and run wires to the op amps.
            The elctrolytic recap process has gone fine so far with no problems but those op amps are so tough to replace!
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #66
              Did you (even) try cleaning the old solder off the pads before installing (or attempting to install) the new opamps?
              With the help of a bit of (good quality) flux, even a huge(-ish) tip shoulnd't be an issue.
              Got any pics of the present state of affairs? And is your soldering iron temperature-controlled? Or is it just one of those mains-powered unregulated "firesticks"?
              • surrealisticdukes
                • Mar 2014
                • 6
                • Austria
                #67
                Hey there!
                I also decided to recap parts of my Pro 40, especially the psu and some caps around the mainboard regulators. I noticed that it took more and more time after startup for the locked led to come up (always acompanied by the audible click of some relay). Also for quite some time i have occational problems with some kind of digital distortions where the drivers seems to get a hick-up, which i normaly solve by muting and changing the audio buffer to a different setting. Many different driver version updates and reinstalls didn't fix the problem, i could find the motivation to reinstall the operating system to see if it was the cause.
                I thought maybe the startup-delay and occational gliches could have the same root in some power stability problem. Also the +48v test point only measured 43V and the 51V from the power supply took some time to come up and this seems to correlate to to the start-up delay, as you can hear it switch when a specific voltage is reached. When you switch it off and on again it will be faster in reaching this voltage and switching the relay.
                The recap didn't bring any improvment in startup-time and unfortunally i can't look for the failure anymore. During some power up to test the voltages a dangling earth wire from the chassis managed to slide past the shield and supposedly touched the heatsink of regulator Q1.
                So far it only seems to have blown out R37 which lies between the bridge rectifer and the heatsink. It was badly chared and clearly released the black magic smoke. I hope nothing else got fried and the resistor took all the damage. I tried to switch it on again before i knew i had lost a resistor and it took out the primary fuse. I didn't take any pictures of the underside of the psu, so now i have no idea about the value of the burnt transistor.
                Would be very nice if somebody could look at their pcb for me and tell me the value? There is only marketing wank all over google and here seems to be the only place where people work on the pcb of the saffire range.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #68
                  Sorry to hear about your loss
                  The heatsinked Q1 is in the power supply, i reckon, right?
                  Can you check the traces on the underside of the pcb, to see where the now-blown resistor is connected?
                  • surrealisticdukes
                    • Mar 2014
                    • 6
                    • Austria
                    #69
                    Hey, thanx for the quick reply!
                    Yeah, its on the psu. Actually Q1 is the switching Mos-FET, i mistook it for a regulator and R37 is on the underside of the PCB next to a big solder-blop which holds the heatsink. There should be a Silkscreen Label next to it. The blown Resistor is connected to the Output of the Diode-Bridge-Rectifier and via another Resistor (if i remember correctly 10K) to the Gate of the FET.
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #70
                      is it connected also to the source pi of the FET? The source pin is the first from the right, when you look at the FET from the front ( standard pinout is gate-drain-source, as viewed from the front, starting from the left).
                      if that's it, that's the current sense resistor (under 1 ohm in value), and if that's blown, there's a good chance the FET itself is blown as well...
                      • kod2nd
                        • Mar 2014
                        • Singapore
                        #71
                        This thread is awesome, im gonna take a shot at modding the pro40s caps.
                        • surrealisticdukes
                          • Mar 2014
                          • 6
                          • Austria
                          #72
                          No, the blown one is not the sense resistor. In this power supply it consists of 4 Resistors in parallel (2x 1R0 2x 3R3).
                          I think R37 is part of 2 pull-down resistor in series on the Gate of the FET. R11 is 10k and connects the heatsink to the gate of the FET, R37 connects the heatsink to ground of the Diode-Bridge Rectifier.
                          No idea why the heat sink is connected in circuit like this anyway?
                          • surrealisticdukes
                            • Mar 2014
                            • 6
                            • Austria
                            #73
                            I unsoldered the FET and checked it using my multimeter. It should be OK.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #74
                              Any chance you could post a (half-decent) photo of the power supply, top and bottom? Maybe with indications with which component is which...
                              • danmol14
                                • Mar 2014
                                • spain
                                #75
                                Hello Khron666.
                                I decided to recap my Pro 40, and follow your steps. I`m trying to buy the caps, but I don`t find an online store to buy them all together. I live in spain. Do you recommend any store?
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  #76
                                  I can't say / guarantee it's the cheapest choice, but there's a guy on ebay selling a wide array of japanese caps (among others). You can search for his id, egekecu, or "PC Motherboard Capacitors Store".
                                  I've seen him recommended by a few guys around here, and i myself bought some Sanyo lowESR caps a while ago, for some ATX PSU recaps, and all went fine.
                                  • surrealisticdukes
                                    • Mar 2014
                                    • 6
                                    • Austria
                                    #77
                                    So.. here are the pictures of the failed Saffire Pro 40 SMPS PCB.
                                    The heatshink for Q1 is where the mains earth wire touched and on the underside you can see the missing R37.
                                    I already cleaned up all the mess, there has been quite some soot after R37 burned out.
                                    If somebody could tell me the value of R37 it would help quite a lot to repair the bugger.
                                    Note that the input protection devices (NTC Thermistor & Varistor) are missing because i unsoldered them for testing.
                                    I found the Thermistor shorted out (maybe during the failure, or even before?). Another thing i have to fix.
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      #78
                                      Hmmm... From what i can tell, there's a reasonable chance that R37 was just a "0" jumper.
                                      The FET is in an isolated TO220 package, and that solder-tickened trace is going to the negative leg of the bulk filter cap, right? The trace going to the FET gate goes under R37, and those 3R3 and 1R0 form the current-sense resistor (from the FET source to the negative leg of the bulk filter cap). So it wouldn't make much sense if R37 had some (greater) value. Most likely it's just employing the heatsink as a small EMI-shield of some sort, i'd reckon.
                                      Although i AM open to corrections from more knowledgeable types
                                      • surrealisticdukes
                                        • Mar 2014
                                        • 6
                                        • Austria
                                        #79
                                        Yeah the solder tickenend trace goes to the filter cap. If it was just a "0" jumper for layout reasons, it would actually connect the heatsink to ground, which makes sense. I also was thinking it might have been some sort of fusible smd.
                                        But i'm anxious to solder some jumper wire instead, maybe it still was some Resistor, probably fine tuned to prevent some stability problems or something.
                                        I hope somebody can check the value for me when they recap their SMPS. Would be very much appreciated.
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #80
                                          The heatsink's not connected to anything (else), so there's not much to tune with it. If anything needed adjustment, that would be done in the passive components surrounding the PWM controller chip
                                          Actually, i'm reasonably sure the power supply works fine even as it is, with the heatsink "in the air". But, as before, i stand to be corrected
                                          • Momo_the_duck
                                            Schematic for Focusrite Scarlett 2i2 3rd Gen
                                            by Momo_the_duck
                                            Hello!
                                            New here. I just bought a broken Focusrite to begin my journey in repairing stuff.
                                            I would like the schematic for the Focusrite Scarlett 2i2 3rd Gen audio interface.
                                            Thanks in advance if anyone answers!
                                            09-01-2025, 10:03 AM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                            no-name Radeon 9600 XT recap and cooler
                                            by momaka
                                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                            This one was actually suggested to me by ChaosLegionnaire....
                                            11-06-2020, 07:54 PM
                                          • laskr1999
                                            DFI Lanparty NF3 250GB complete recap help
                                            by laskr1999
                                            Hello!
                                            I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
                                            I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
                                            I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
                                            - 20 x Nichicon 1000uF 6.3v HM 105C
                                            - 5 x Chemi-con KZG 1000uF 10V
                                            - 1 x Chemi-con KZG...
                                            11-25-2025, 03:27 PM
                                          • varunviolin007
                                            Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                            by varunviolin007
                                            Hi guys,
                                            I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                            I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                            Looking for someone experienced with older PC boards who uses...
                                            07-29-2025, 11:53 PM
