Allen & Heath XONE92 DJ mixer PSU board - (003-233JIT)
  • mikedubz
    replied
    Re: Allen & Heath XONE92 DJ mixer PSU board - (003-233JIT)
    Hi im new to this thread and entirely new to threads all together but i was hopping on elaborate explanations to your issue hope u can shed some light cause this is what is my issue with my xone 92 as of today i noticed something weird with my mixer and i love it to death as i'm sure you do yours !
    First off the signal seems to change even when the filter is not engaged and i twist the filter knob, then even when applying wet\dry with the filter not engaged it changes the sound and last my hpf bpf and lpf are not cutting off like they used 2.
    does this sound like a cap issue ?
    PLZ some light to my deep and dark tunnel of desperation .?
  • mikedubz
    replied
    Wow thx guys for the help i hope this is the solution to my filters not working correctly .
    first off the signal seems to change even when the filter is not engaged and i twist the filter knob, then even when applying wet\dry with the filter not engeged it changes the sound and last my hpf bpf and lpf are not cutting off like they used 2.
  • djkevinz
    replied
    Hi there, I am about to undergo the same project. Glad I found this post!!! It looks like it's been a couple of years since you did this, were you able to fix your PS??
    Also in case anyone would find it helpful, I found a schematic of the PS.
    I'm ordering my caps from Mouser, hope to get this going again soon!
    Cheers
    Kevin Z
    Denver CO
  • firespace
    replied
    oops your right, no charge, my bad too many tabs open with components, *laughs* thanks, I will order your choice, good to know I hadn’t picked something unworkable though, thanks again
    FS
  • Scenic
    replied
    The one you linked to has a 115mA ripple rating. From what I was able to find out that's the same as the original. Just 85°C though.
    Shouldn't be a problem. The one I linked has higher specs, but if it's a US import (expen$ive shipping) that's not gonna help lol
    BTW where does it say that? Couldn't find anything
  • firespace
    replied
    Originally posted by Scenic
    The higher the ripple rating the better. At the very least the same ratings as the original cap. (It's an "up to" figure, like the voltage.. It'll work fine up to XYZ mA ripple current without blowing up by overheating)
    ESR on the other hand should be as close to the original as possible to prevent problems. Lower ESR generally doesn't hurt, as long as you don't go too extreme.
    Replacing a 0.048 ohm ESR cap with a 0.036 ohm ESR one shouldn't cause any serious problems.
    Going from a 0.048 ohm ESR cap to one with 0.012 ohm ESR (or even less) most likely will make something go out of whack.
    Could I use my choice without problems?
    I can’t find the ESR rating for it or the original, but the one you list is a USA import and I get charged a handling fee of £15 from Farnell.
  • firespace
    replied
    Very informative thanks so much, I hope you don’t mind but I PM’ed a little informal health info since you have been so kind sharing your knowledge, and I cure colds and coughs quite often I hope it’s of use.
  • Scenic
    replied
    Had such an "ESR problem" just a few weeks back. The caps I used in a LCD TV PSU were too good in terms of ESR, which made the whole thing whistle/whine and run much hotter than before. Replacing them again with slightly "worse" caps (higher ESR ; closer to the originals) made it work as if nothing happened.
    I'm feeling a bit better, but I'm still on my "way in" so to speak.
    My bro has been coughing his lungs out.. he just can't stop it. I fear I'm gonna end up the same in a few days or something :/
    So far it's just a runny nose + headache.. maybe I'll get lucky (famous last words.. )
  • firespace
    replied
    5. (C57 board location). Samwha SD series, Model R7A, 400V 10uF 105°C (M) - Width 10mm Hight 21mm
    https://cdn.badcaps-static.com/pdfs/...5cffd5baf9.pdf
    I have noticed the ripple rating for the original is 115 @ 120hz-
    Hence my replacement choice of-
    http://uk.farnell.com/panasonic/eca2...0uf/dp/1907181
    your choice-
    http://uk.farnell.com/panasonic/eeue...0mm/dp/1673487
    has a rating of 150 @ 120Hz
    Your choice is much cheaper and seems to last much longer under operating conditions, my question is, how much of a slave to ripple current accuracy (to the original caps) should I be with my replacements?
    : ) - thanks again for all the help, hope you're feeling better : )
    FS
  • firespace
    replied
    god.. I'm waaaay too slow today
    You good sir are frakkin’ awesome today!
    Thanks and I shall put a "good health unto thee and thine kind fellow" wish in the cosmic post to you immediately, the moment i’m done peeling those stamps of the last one I got sent.. - but seriously thank you and get well soon!
    Yippy now to huff on some solder fumes while waiting for Farnell to send my goodies..
    Corrections for others reading this looking to do the same thing -
    Cap number 5. (see picture) (C56 board location) thus Cap 6. (C57 board location) is correct : )
    Thanks to all the contributors of this here thread and this amazing forum in general!
  • Scenic
    replied
    Despite being a bit sick.. here we go:
    1 (C57 board location). Samwha HC series, Model R3D, 400WV 68uF 85°C (M) - Width 22mm Hight 20mm
    As for the primary cap (the 400V 68uF), this one should do. If you really want a 105°C cap in its place, that one should do the trick if you have enough room to fit a 30mm high cap (and put the PSU where it's supposed to go)
    http://uk.farnell.com/rubycon/25zlh4...25v/dp/8126461
    Originally posted by firespace
    4. (C61, C62, C58 board locations). Jamicon 324C4(M), 63V 120uF 105°C (M) - Width 8mm Hight 16mm
    Need a series. I'm guesstimating from the pics that they're WG series, but there's no 63V 120uF in the datasheet. Much less a 8mm dia one
    Doesn't prevent me from finding a replacement cap though
    http://uk.farnell.com/nichicon/uhe1j...ial/dp/1899695
    6. (C57 (?) board location). Samwha SG series, Model R8E, 50V 10uF 85°C (M) - Width 5mm Hight 10mm (might be 11mm hard to tell)
    http://uk.farnell.com/united-chemi-c...ial/dp/1220672
    just grab the right quantities and you should be set
    edit: god.. I'm waaaay too slow today
  • Th3_uN1Qu3
    replied
    50v 10uF sounds like a startup capacitor, you can use basically anything there. But make it 105C.
  • firespace
    replied
    Cool beans, I shall add those replacements to the basket : ) now I just gotta get the others checked by someone, and look up a replacement for
    6. (C57 board location). Samwha SG series, Model R8E, 50V 10uF 85°C (M) - Width 5mm Hight 10mm (might be 11mm hard to tell)
    And then I shall be good to go.
    Thanks Th3_uN1Qu3
  • firespace
    replied
    I have been unable to find a data sheet for the Jamicon WG series that lists the 63V 120uF 105°C can anyplace on this here intereweb thingy, so I have no way of knowing what the ripple current rating was, but I'm gonna guess it was roughly the same as the Rubycon LZ series of the same stats
    Rubycon LZ
    120 8x7 380
    120 6.3x11 405
    I would say it is closer in can size to the 6.3x11mm can so I'm gonna go with 405 for the ripple.
    I would really appreciate it if someone who can spare a minute or two could check these for me and tell me if I have missed anything, or made any noobish mistakes before I order.
    This is the intended replacement
  • Th3_uN1Qu3
    replied
    Panasonic makes very good caps, no reason to search for Rubycon if you already found Panasonic.
  • firespace
    replied
    Ok so today I found these Panasonic as a replacement for the number 5 caps, anyone know of Rubycon Caps of the same specs, I couldn’t find any on Farnell but that doesn’t mean they aren’t there...
    5. (C57 board location). Samwha SD series, Model R7A, 400V 10uF 105°C (M) - Width 10mm Hight 21mm (ripple 115 @120khz)
  • firespace
    replied
    Thank you Th3_uN1Qu3 very useful info.
    I guess all I need now is links to the Farnell site for as many of the replacements as possible, and if some kind person could list what other caps I need I will source the rest myself.
    Sorry if I am being demanding, I’m just learning at this and the guidance and assistance is very much appreciated. So glad I found this awesome forum, you guys are so friendly to share your expertise. - Thanks all : )
  • Th3_uN1Qu3
    replied
    It's recommended to match the ESR as close as you can. Lower ESR will certainly not hurt in terms of filtering, but it may cause the SMPS controller to go crazy because ESR changes the transfer function of the feedback loop, and that would open a whole new can of worms.
  • firespace
    replied
    Just wondering would a lower ESR rating than the original component put more stress on components down stream? Should the ESR be as close to the original, or should I seek to make impedance as low as possible in all the replacement Caps?
    Thanks,
    FS.
  • PeteS in CA
    replied
    Other than Farnell, which I understand is part of Newark Electronics, I'm not aware of another UK-EuroLand distributor like Digi-Key. You might see what Avnet-Abacus might be able to do. It might not hurt to ring up Rubycon's Amsterdam or Munich sales offices to see of they have any suggestions. Also, maybe look on the sites for Panasonic/Matsushita, Nichicon and United (or Nippon) Chemicon to see what distributors and sales offices they have in EuroLand. If you do much repair work, developing sources for stuff would be a good time investment.
  • trickartt
    Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
    by trickartt
    Hello Badcaps!
    I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
    This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
    05-04-2024, 12:07 PM
  • JohnsonJ
    Allen&Heath XONE92 DJ mixer repair
    by JohnsonJ
    Hello everyone.
    I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
    The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
    12-12-2020, 11:19 AM
  • jaifraic
    Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
    by jaifraic
    I have a DJ mixer here, an Xone:92 by Allen & Heath.
    When I turned it on, only magic smoke came out, so I turned it off again.
    An optical troubleshooting has brought me quite fast to the
    source of the smoke: two resistors look disproportionately black (see first pic)
    Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
    Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
    My thought is that one (or more) of those is defective. I've measured...
    03-15-2022, 12:32 PM
  • analogicalmind
    Allen & Heath Xone:92 mixer problem - faulty phono channel outputs on one side only
    by analogicalmind
    Wondering if anyone here can help – I have an Allen and Heath Xone:92 silver mixer with one faulty channel – channel 2 is only outputting on one side (right side) when set to a phono input. It works fine with a line input, and all the other channels work perfectly with phono and line inputs. I'm not sure when this happened as I rarely use the faulty channel – it could well have been like this for years! Any thoughts on what might be causing the fault and how it could be repaired? I can do some basic soldering, so I'm hoping I might be able to fix it myself.
    02-17-2022, 12:33 PM
  • Longon
    Behringer Pro Mixer DJX-750
    by Longon
    Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
    08-11-2025, 02:17 PM
