identify a diode
  • timwebb22
    • Jan 2011
    • 30
    • united states
    identify a diode
    so im working on a amp and i cant figure out what kinda zener diodes these are.the 4 big ones any help?
  • 999999999
    • Sep 2006
    • 774
    Re: identify a diode
    MELF (metal electrode leadless face) form factor, you'll have to measure it to get the size, though from the pic I'm guessing it's 5mm long, 2.5mm diameter, SM1 - LL41 (DO-213), 500mW or 1W, of unknown voltage.
    Example, but something is screwy, it's also listed as through-hole http://www.mouser.com/ProductDetail/...%2f5cxbpMAc%3d
      Did you try taking any DC reading on them yet, or do they check out bad?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        Depending on the manufacturer, the blue stripe could indicate a specific voltage or it just might indicate what you already know, that they are zeners.
        If you don't have a schematic I think you'll have to test one or all of them and find out what they are.
        -David VanHorn
        • timwebb22
          • Jan 2011
          • 30
          • united states
          they all measure about .15 in diode check. they are all dead.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            I don't think the standard diode test function of a multimeter can test a zener correctly, in any case if you are trying to measure some property of the diode in-circuit you may get incorrect results.
            -David VanHorn
            • b700029
              Banned
              • Sep 2010
              • 640
              Or it might just be for polarity.
                "they all measure about .15 in diode check" reading is taken with diodes are off the board right?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  Well sure, it will be for polarity, the stripe is... but often (for SMDs) the colour of it indicates something else as well
                  -David VanHorn
                  • digitalscorpion
                    • Mar 2012
                    • 37
                    Maybe i missed it, but what is the make/model of this amp? Perhaps someone has a schematic/BOM...
                    • 999999999
                      • Sep 2006
                      • 774
                      Pretty sure they are zeners due to "ZD" silkscreen on the board. Not sure how voltage could be designated with only one color band, there are so (too) many different possible voltages...
                      The mosfets on the board are rated to 60V, you could use a variable voltage supply up to that voltage range, increasing supply voltage till you measure zener conduction to get a voltage value, or conclude they are blown if it supply reaches 55V without. They'd have to be off the board to test. Example (though a multimeter is fine, no analog panel meter need): http://www.instructables.com/id/Zene...cker/?ALLSTEPS
                      • selldoor
                        Slow Learner
                        • 7870
                        Hi I believe the blue stripe is for polarity.
                        Digikey have a pile of these - I dont know how you decide which voltage.
                        Have you taken one off the board - perhaps more info underneath?
                        Digikey ones appear to have a white stripe in the middle which may have some id code on it. - Suggest give DK a call and ask them how they id them?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          In general they ID them from the box they come in from the manufacturer. Some SMD parts simply have no useful markings for identification (diodes and some transistors), and SMD ceramic capacitors and inductors generally have nothing at all.
                          Some Zeners have colours to determine voltage, but it's only from some manufacturers, for example: http://www.marsport.org.uk/smd/sod80.htm
                          I think in this case however, the blue stripe is just saying "Zener" which is of course not helpful because we already know that.
                          -David VanHorn
                          • selldoor
                            Slow Learner
                            • 7870
                            It indicates two things , although I dont think all manufacturers stick to the codes!
                            In your link it says: The cathode end is indicated by a coloured band.
                            and for a Mini Delf a Zener is Blue - Id guess it will be the same for a DELF
                              I am still surprised that ALL of them shorted out, otherwise if one is good then it can easily be figure out the Zener voltage using power supply, resistor, and DMM.
                              • hobostove
                                Corsair RM1000e - Help identify 5VSB Zener diode
                                by hobostove
                                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                There's a 22ohm resistor that's melted and open, but it still has the bands.
                                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                It looks like the diode connects the source and drain of a TNY284...
                                03-27-2025, 02:25 PM
                              • unimatrix93
                                TV backlight zener diode
                                by unimatrix93
                                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                The led strips has 9 6V leds.
                                02-10-2025, 12:13 PM
                                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                by sam_sam_sam
                                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                I bought this from an eBay seller but unfortunately they only had one
                                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                I bought three of from them to also make battery packs with this output power limit in mind
                                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                04-23-2025, 05:50 AM
                              • nev1001
                                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                by nev1001
                                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                I think an issue could be a zener diode (or capacitor) which has shorted out.
                                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                04-17-2025, 05:09 PM
                              • Vincenzo2
                                Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                by Vincenzo2
                                My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                I put some pictures here to show that it is labeled "M7"....
                                09-07-2023, 07:43 PM
