Technics ST-S4 Capacitors
  • redrooster
    • May 2011
    • 114
    This Technics tuner has 3 bad caps together in a row they are bulging and leaking. I have never heard of these before? Gold Cap? 1.8volt,3.3f (I presume it means 3.3mf?) The service manual says they are double layer liquid electrolyte. Does anyone know anything about these caps,can I replace them with tantulum caps for instance? The service manual is next to useless I can hardly read it.Any help will be greatly appreciated.
    HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
  • japlytic
    • Oct 2005
    • 2086
    Re: Technics ST-S4 Capacitors
    "3.3f" is 3.3 Farads, of which is regarded as a supercapacitor.
    Supercapacitors (Panasonic calls them Gold Caps) are often used for memory backup during a power failure.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      those are most likely the backup power to keep the stations when it's unplugged (or turned off, if it has a hardware power switch)
      not sure if this link will work, but this would be the cateory on digikey. 1.8V isn't available, but if you select 3.3f and tick "in stock", it'll show 4 results.
      http://search.digikey.com/us/en/cat/...e-layer/131084
      Probably wouldn't hurt if it was 2.7f or 3f either (apart from a somewhat lower amount of time it keeps the stations)
      mind the dimensions though
      • redrooster
        • May 2011
        • 114
        Thats a surprise,I was sure they were ordinary caps LOL. I live in the sticks and the local shop has only (Hy Cap 2.7volt 5farad)$3.50 each,would they work for me or do you think I should get the exact replacements?
        • lti
          • May 2011
          • 2557
          If all three caps are connected in parallel, you could replace them with two of those caps.
          • redrooster
            • May 2011
            • 114
            Thats good I was hoping I could do something like that. Thankyou very much.
            • silver60618
              TANTULUM CAPACITORS SHORT QUESTION ASUS GL504GS
              by silver60618
              Hi Im working on repairing this Asus GL504GS, and with meter in continuity mode, getting short to ground on all of these GPU related tantulum capacitors and .03ohm value in Diode mode (image with arrows). are these readings normal for this type of Board?
              I tested the caps on another non working board, and get the same readings.
              If abnormal, is it safe to inject 1v, 3-4amps to these to monitor with thermal cam?...
              07-20-2024, 12:59 PM
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
