Onkyo receiver/amplifier
  • lmcancu
    • Oct 2009
    • 158
    I have an old Onkyo receiver/amplifier that has a small problem. When listening to FM, one of the channels (I think it is the right one) is very low. However, when listening to any other source (CD player, Satellite receiver, etc) everything works fine: right channel is as strong as left. Any ideas why this could happen? Could a bad cap cause this?
    Thanks for any help
  • smason
    • 1652
    Re: Onkyo receiver/amplifier
    Depending on the design, could be as simple as dirty switch contacts.
    I'd start by cleaning the switch that selects the input.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      but fm is built in, right?
      • lmcancu
        • Oct 2009
        • 158
        yes, FM is built in. CD, and the other sources are inputs in the back of the unit
        • smason
          • 1652
          But still could be switched with a mechanical switch, since we don't know the model or how old it is....
          I fixed an older Pioneer receiver a while ago where the left channel was dropping out. Was a dirty speaker a/b switch.
          • lmcancu
            • Oct 2009
            • 158
            Its a pretty old one. TX sv545. Had it for at least 10 years, and it was a hand me down from my brother in law so he had it for a while. I'll try cleaning to see if that fixes it.
            • lmcancu
              • Oct 2009
              • 158
              I found something suspicious on the FM/AM daughter card. A component lead was broken. Anyone know what this component is and where I can find a replacement. Could this be the cause?
              • Scenic
                o.O
                • Sep 2007
                • 2642
                "L" indicates that it's an inductor/coil..
                http://en.wikipedia.org/wiki/Electronic_symbol
                • steve2
                  • 121
                  I tried uploading the manual 3 times, but it keeps failing. L109 (for 120 volt USA and Canada) models Part # NCH-2140 or 231092 (onkyo #). The schematic has it as a 102j which I don't know if is 1000uh? Yes the 102J is 1000uh, 1mh. The J is 5% tolerance.
                  • Tube_Dude
                    • Feb 2011
                    • 51
                    Measure L110. the value will be the same.
                    Just to be sure about the problem, short L109, and see if the FM work properly, in both channels.
                    L109 are just part of the MPX output filter so, shorting it with a wire link doesn't cause any problem.
                    Cheers
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      there seems to be a filesize bug for .pdf files. the manage attachments thingy says the limit is 9.54MB, but the actual limit is 1.91MB, so any file bigger than that just won't upload.
                      i've PMed topcat about that a while ago..
                      • steve2
                        • 121
                        Thanks Scenic. I put one up earlier , but it was 1.7mb This one is 4mb or so.
                        • lmcancu
                          • Oct 2009
                          • 158
                          Thanks for the help. I searched for the part but could not find the exact part at mouser or digikey. I found the following parts. Would these work? The dimensions of the original part are about 7.5 mm diameter, and 10 mm long.
                          http://ca.mouser.com/ProductDetail/F...1HsY9HzTj8k%3d
                          http://ca.mouser.com/ProductDetail/T...N6NKnHdL2dU%3d
                          http://search.digikey.com/scripts/Dk...=445-3778-1-ND
                          Also, I read up on the MPX filter, and understood that it notches out the 19 KHz pilot tone that indicates stereo info so that it doesn't mess up the audio while recording to tape. Is this the only downside to disabling the MPX filter?
                          • steve2
                            • 121
                            Not sure if I am seeing right, but how many leads are on the L109? Looks like 2 broken and more still in the board. Is there no way to solder the leads back together?
                            • lmcancu
                              • Oct 2009
                              • 158
                              There are only 2 leads. I tried soldering it it place, but it did not bond. It seems the broken lead is ripped from the base. I'll try removing it from the board to see if I can reattach the lead to the base.
                              • lmcancu
                                • Oct 2009
                                • 158
                                it looks like its going to be difficult. My eyes aren't very good anymore! I removed the inductor from the board. The leads are attached to the plastic and then there is a very find wind from the inductor coil on them. For the lead that is broken, it is no longer in the plastic and the inducutor coil is barely next to the platic hole. I would need to figure out a way to attach a lead from an old capacitor or somehting like it to the plastis base, and solder the wind onto it of which there is very little.
                                • steve2
                                  • 121
                                  I am the same with the eyes. I wear a magnifier visor when working small parts. I would try what you said and solder a piece of fine wire to the existing piece to make it long enough to reach the new post.
                                  • lmcancu
                                    • Oct 2009
                                    • 158
                                    Ok, I tried fixing the inductor with no luck. Much too delicate for me! I took Tude_dude's advice and shorted L109 and now both speakers are at the same level. Only catch is that I'm not sure if the Stereo mode is gone now? There is no indication on the display that the FM channel is is Stereo mode, and it seems like both speakers are the same. Anyone know if the display should say Stereo when the FM channel is Stereo? Is this a side effect?
                                    • Tube_Dude
                                      • Feb 2011
                                      • 51
                                      Yes, when the transmission is in stereo, the stereo display must say so.
                                      But the inductor is after the stereo decoder, so without any influence in the stereo operation.
                                      See if the receiver have a switch for stereo mode, many have...
                                      In the pic we can see the inductor L109 have written 183, this means 18 with 3 zeros, so the value is 18 mH or 18000 uH.
                                      • lmcancu
                                        • Oct 2009
                                        • 158
                                        I got the spec from Steve and in the schematic L109 says 102j. 102j is 1 mH with 5%. Are you sure about the 183 markings? Maybe the schematic is out of date?
                                        Also, I'm thinking the inductor is also used for the pilot tone detection as well as removal and makes the stereo detection not work since the inductor is shorted.
                                        • ai.need.help
                                          Onkyo TX-8050 AV-Receiver no sound
                                          by ai.need.help
                                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                          It doesn't play music. There is no real output from:
                                          pre-out
                                          amp-out A and B
                                          phones out
                                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                          I tested with analog-input, usb and radio.
                                          I know that there is a common problem with...
                                          12-20-2022, 05:54 PM
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • benspawn02
                                          Anthem MRX500 - no sound. R2A15218FP issue??
                                          by benspawn02
                                          Dear Electronics Experts:
                                          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                                          08-12-2023, 04:46 AM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
                                        • budwich
                                          onkyo 919 Receiver... hum problem but...
                                          by budwich
                                          I have an onyko 919. It has a hum problem at cold start which eventually dies / goes quiet. I have been "chasing" it for a while. Tightening ground screws and checking a few places. Basically, the problem is in the "back half" of the unit.... that is, if I take the sound out of the "pre-out" and feed it to a stand alone amp, it is good. If I feed in a signal at the external decoder input and play thru the back end of the onkyo, it has the hum.
                                          Anyway, along the way (the chase), a number of components (resistors, capacitors, etc) on the main board...
                                          01-13-2021, 03:31 PM
