I bought a Kenwood VR-606 Surround Sound Receiver from Goodwill and when I brought it home it would not power on....just a couple clicks and a red stand-by light. So I let it sit in cold storage (Sometimes below 40 Degrees) for a couple months.....I decided today to take it out of storage and try to fix it and when I hit the power button it turned on and the display lit up....I was excited!!! But short lived, it turned off after about 30 seconds. Just a stand-by light again. Can't be a heat issue as the thing just came out of cold storage just a minute before I plugged it in. I included a close-up of a little board attached to the Power Transformer that has a burn on one of the solder points. Could this be causing it? I really don't want to invest $50 for a new transformer. There are about 5 other boards attached to this thing, not including the mainboard. I don't want to take this thing apart just to check everything out. Any clues based on what I stated?
Kenwood VR-606 Receiver No-Power
Re: Kenwood VR-606 Receiver No-Power
Try reworking the joints on the power transformer.
Depending on the temperature, bad solder joints can become good in some cases.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. -
No it says nothing when it shuts down.....the whole screen goes blank and it goes back to red standby led. When I push the power button again I just hear the relay clicks. But then again I don't see any relays where I here the clicking.Comment
try to reset it by doing this: hold the power button down, plug the receiver in, then press the power button again. that should reset the firmware.
if that doesn't help, you likely have a bad stk chip. those are the 2 big black plastic i.c.'s attached to the big heat sink. before replacing the stk's, try reflowing their solder joints.
i think chances are tiny that the power transformer is the culprit.Comment
Helllo,
Do you have the cover off when you listen for the relay clicking noise? I had a Sony receiver once that had a similar clicking noise. I located the source of the noise and it was indeed a relay without a transparent cover. I think it was black or grey in color. So I very carefully pried the hood or cover off that relay if you will and stuck an old flat head screwdriver in the relay after the cover was off and the unit came to life. So my guess is that the receiver either got to hot and the thermal circuit tripped the suspected relay or the speaker wires got shorted together? Maybe the person that owned it before attempted to make extensions on the speaker wires and they touched together that would trip some form of protection circuit maybe? If your brave enough you could try the screwdriver or some other metal tool trick. But be very careful!
Good luck...................
lcdmanComment
These units can be a bear to work on. I would go after the power supply for sure.
When I repaired delco radios I would put them in the freezer to test them or make them inop. solder joints mostly fail in the cold and work when warm. you could put it in your fridge and bring it down to 40 degrees then see if it comes on.
No display means no power from main supply. The amp curcuit will shut down in protect mode, but the display should still work.Comment
Hello all. My first posting. I have a kenwood vr-606 with a fuse blowing problem. Worked fine one day. The next it blew the 8 A fuse on the little board just under the cover. Then it just started to click until i held down the power button for a few seconds. Tried another fuse and it blew also. then i disconnected the plug going from the little board to what looks like a big transformer? and tried it again with another fuse. this time it just kept clicking but the fuse didn't blow. bad transformer?? love the kenwood but need help. thanksComment
by freethinkI have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
11-23-2025, 07:53 PM -
by JRadeWhen I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
I replaced the capacitor C303/0.047F, nothing changes.
I'm asking for help, what should I do next?
Thanks in advance!...-
by learnmoreHello Community,
I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
Peace
LM...11-04-2025, 09:35 AM -
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by mikey5791Hi all,
Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
My questions are
1. How do i test to see if the transformer is in good working condition?
2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
Hope you guys understand what i was asking. My intention is... - Loading...
