Help monitor audio gxw-15 subwoofer
  • exceptional
    • Aug 2023
    • 4
    Have a problem with one of my gxw-15 subwoofers. When pluging in power socket it shows power is ok (red LED), but when trying to turn it on it turns iff immediately (can hear relay clicking sound). Cause i have working second subwoofer i tried replacing several boards. So for now i can say power board is causing this problem. There are no visible damaged element on it. I wrote to Monitor audio and they sent me all schematics. What i have found is defective capacitor C535(short circuit), but after changing it ...same behavior.
    Measured output FETs, diodes. Seems everything is fine...
  • R_J
    • 9557
    Re: Help monitor audio gxw-15 subwoofer
    If C535 was shorted, you may have an open R508 that supplies the AUX supply. Check your AUX voltage and also the VCC voltage
    • exceptional
      • Aug 2023
      • 4
      R508 is ok.D507 too. Checked them. Will check aux voltage and VCC.
      • dobrykamil
        • Jun 2013
        • 62
        What about that swollen cap next to D528? Think it's on the +5V rail which is also used by that black relay.
        • exceptional
          • Aug 2023
          • 4
          Thanks guys! I really missed that capacitor near D528. It was damaged too. Changed it and everything started to work!
          • GriffDeLaGriff
            • Dec 2023
            • Norway
            I have the same subwoofer with the same behaviour. I should see if I have the same problem. Was it actually only that swollen cap?
            • GriffDeLaGriff
              • Dec 2023
              • Norway
              So mine shows the exact same behaviour. But cant see any fault on that or adjacent caps.
              • dobrykamil
                • Jun 2013
                • 62
                I have now joined the club. Trying to fix back plate with clicking issue. In my case, 5VDS is present and has correct, +5V value, but once I manually turn sub on, it drops to +2-3V like something was drawing too much current for standby smps to handle with.Does anyone have service manual for this particular model?
                Thanks in advance.
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • old_marantz
                  Help monitor audio rxw-12 subwoofer
                  by old_marantz
                  I have a monitor audio subwoofer rxw12 that is clicking. Avsforms has a thread on this and I saw someone posted schematics here for it. Since I’m a newbie and no one here in salt lake will work on it, I guess I’m elected.
                  Supposedly the issue is “ smd type and located on the soldering side of the amplifier board”. Can you experts help me identify which one it might be? And what to order? How difficult to put these in? I’ve replaced caps before but just eyeballing what these resisters might be on the board, they look pretty small.
                  I saw some...
                  08-20-2023, 05:46 PM
                • MOSSEP
                  Monitor Audio RSW12 - Green light but no audio
                  by MOSSEP
                  Hi
                  Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                  Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                  The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                  I have already tried replacing all of the...
                  01-26-2025, 08:18 AM
                • Delicieuxz
                  I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                  by Delicieuxz
                  I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                  Here's an audio clip of the sound coming from my speakers:
                  https://vocaroo.com/16HaryHwTx78
                  I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                  11-15-2023, 09:50 PM
                • MOSSEP
                  Monitor Audio RSW12 - Green light, but no sound
                  by MOSSEP
                  Hi
                  01-26-2025, 08:33 AM
