speakers cutting in and out
  • Rusled
    • Oct 2010
    • 5
    Have a problem with " crackling " sounds in HT side surround speakers. the Speakers are cutting in and out. When I turn up the volume, speakers clean up.This is when watch movies in Dolby surround or DTS , 5.1 or 7.1
    When I use 5 or 7 channel stereo, I have no problems. Could be due to the constant feed to the speakers ?
    Speakers are being driven by a Parasound amp, the proccesor is an Outlaw 990. The speakers are Monitor Audio RS 6's
    THe Parasound amp is also powering two MO RS 1's and a MO Center Speaker , yet have not experenced any problem with them.
    THe fronts MO GR 60s are powered by a Carvin amp
    Philips F9217L-50R speakers – build quality impressions and DIY surround repair
    by momaka
    More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
    02-15-2022, 12:43 AM
  • nomoresonys
    Connect pc speakers to tv without 3.5 jack
    by nomoresonys
    Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
    09-19-2025, 05:17 AM
  • Widget
    Logitech R20 speakers - Replacing one of the speakers.
    by Widget
    Hi guys,
    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
    Printed on the back of the Logitech speaker is;
    LOGITECH...
    05-29-2024, 07:07 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • RetroComputingGrotto
    Behringer MS16 Speakers - Low Volume on One Speaker
    by RetroComputingGrotto
    I've had a set of speakers come in with the fault of not powering on.
    I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
    1 random loose nut and part of a BIC Biro pen.
    After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
    05-20-2024, 07:29 AM
