Hi guys,
I cleaned the microwave, but now it makes a rapid clicking sound, then smoke appears. I had a look and it appears to be coming from the front touch panel. I have a feeling a little water got into it(I saw very little on the relays but nowhere else), but smoke is not a good sign. I have a video and come pictures.
I was going to desolder and open the relays but Im not sure if you can. It also appears a couple of resistors and a diode are showing signs of heat/burn.
Res #1 - 470Ω
Res #2 - 330Ω
Zener Diode (unknown value/model)
Relay (I could only see info for 1x relay. I'll have to desolder the others to check if they're identical. see picture)
https://youtu.be/TKIxzIIyI1c
Anyone worked on Microwaves before, particularly the front panel ?
Res #1 - 470Ω
Res #2 - 330Ω
