Sharp R-990K Microwave started making rapid clicking sound and smoke
    Re: Microwave started making rapid clicking sound and smoke
    Relays typically must operate given 70-75% of their rated coil voltage, so 13.5V minimum spec. If you hear it click with 12VDC, that's good enough, we just want to see if the contacts are pooched and that is where the arcing occurs.
    It's low current the coil, 20mA so even two 9V batteries could be used.
    Careful not to remove a fan relay and then operate the oven, it needs airflow.
      Hey Red, thanks for the info
      I did a rough wiring to the relay, connecting 12v from my PC psu ans 12v car bulb. Seems ok. There was a little crackling but I think that was due to poor contact with the power-in in the leg of the relay.
      I thought about swapping relays with the fan, just to see if the fan still works, but maybe I don't have to if the relay seems to be working?
      Everything on the board seems dry. The only other testing I can think of doing is,
      1. Testing with a incandescent bulb sam_sam suggested,
      2. Plugging it all in, power on, and start checking voltages
      I don't know what to do about the buttons not working correctly though. Heck, for all I know it's a completely unrelated issue and became like that long ago (I rarely used those numbers, usually just hit start or preheat at lower temps).
      Here's a video of the relay test. Sorry about the hand and background chatter.
      https://youtu.be/zAG3H-k7hQA
        update: Microwave is working. I put it back together, and buttons seem ok. Convection oven preheats ok too. Not sure what when wrong with the keypad, perhaps ribbon cable wasn't aligned or had some dirty contacts.
        I tried connecting the bulb to the transformer wires as suggested (to check relay) but nothing happened. As of writing this, it came to mind perhaps it would have only engaged the bulb if the convection was activated ?
        Other than that, all seems ok for now.
        Thanks again for all the suggestions, much appreciated
          Re: Sharp R-990K Microwave started making rapid clicking sound and smoke
          You have to set an amount of time like you would if you did not have the incandescent light bulb instead of the transformer
          9 PC LCD Monitor
          6 LCD Flat Screen TV
          30 Desk Top Switching Power Supply
          10 Battery Charger Switching Power Supply for Power Tool
          6 18v Lithium Battery Power Boards for Tool Battery Packs
          1 XBox 360 Switching Power Supply and M Board
          25 Servo Drives 220/460 3 Phase
          6 De-soldering Station Switching Power Supply 1 Power Supply
          1 Dell Mother Board
          15 Computer Power Supply
          1 HP Printer Supply & Control Board * lighting finished it *
          These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10%
          1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later )
          2 Hem Saw Computer Stack Board
          All of these had CAPs POOF
          All of the mosfet that are taken out by bad caps
